Old Aug 05, 2015, 11:39 PM
thrashaero is offline
Find More Posts by thrashaero
anti-wind activist
thrashaero's Avatar
United States, IL, Urbana
Joined Dec 2002
A durable/protective yet light clear coat safe for foam?
I've got several micros I would like to cover in a clear coat. (parkzone cessna centurion/citabria, snap and fly, etc)
I had a can of minwax polycrylic clear gloss spray, but apparently sitting in storage for a while has caused it to gum up and shoot out in clumps. I was trying to test on an old peice of foam but it's just not really working.
I'm not sure if this type is good for the job anyway, given I was trying to test it.
I was wanting to make sure it doesn't dissolve the foam, like I just did with some white liquid electrical tape thinking it would fill a gap, only to make it bigger. Before I go buy another can does anybody know if what I had is good for the job or if there are better options?
I want it to be light too and have it basically there to keep the foam from getting dents and scratches so easily, as well as a nice shiny finish would be cool, or would it be a waste of time?
thrashaero is offline Find More Posts by thrashaero
Old Aug 06, 2015, 02:37 AM
Pile It is offline
Find More Posts by Pile It
Joined Feb 2014
Generally any added surface coat which is structurally strong enough to protect EP/EPS-type foam will add sufficient weight to seriously degrade flight performance. Lightweight tissue-covered freeflight models often use a very thinned-down coat of model airplane dope [lacquer] to water-proof the tissue, but such a thin coat provides very little structural strength per se.
Adding color for looks is one thing, but putting on a ding-protective "shine" is quite another. An easy scientific test is to closely estimate the total surface area of the model, weigh a large flat piece of foam having the same area both without and then with the "*protective" coating, temporarily add that weight very slightly ahead of the CG and see how much you like the "new" flying ability. And see how much real protection the coating gave the foam test sheet. Then you can really see if the trade-off is worth it.
Pile It is offline Find More Posts by Pile It
Old Aug 07, 2015, 02:41 PM
SRAdair is offline
Find More Posts by SRAdair
Joined Oct 2010
Clear Acrylic
Give this a read and then decide if the desired end goal is worth the additional weight added.
http://www.swannysmodels.com/TheCompleteFuture.html
SRAdair is offline Find More Posts by SRAdair
Old Aug 08, 2015, 01:12 AM
papadwight is online now
Find More Posts by papadwight
papadwight's Avatar
United States, TN, Murfreesboro
Joined Apr 2013
I use packing tape I built a control line plane foam wing you could beat the wing on a table when done on my ready to fly I cover only the weak spot's. But have built a few planes this way.
papadwight is online now Find More Posts by papadwight
Question what to use for clear coat jbh1103 Scale Boats 7 May 06, 2015 11:50 AM
Question Clear coat for foam? Tony_Fletcher Painting and Finishing Tips 7 Oct 26, 2009 03:51 PM
Discussion Protective coating for foam? Plateshooter Foamies (Kits) 1 Oct 14, 2007 02:18 PM
Foam safe clear coat? megawatt Foamies (Kits) 7 Aug 17, 2005 01:53 PM
Safe clear coat over poly orectolobus Electric Plane Talk 3 Jan 08, 2002 01:58 PM
