Old Mar 04, 2015, 10:17 AM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
New Product
TwoDee EVO NG DSLR size DIY gimbal
Hi,
After manufactured a couple of kind gimbals,we decided to design a new product for who likes DIY projects.A DIY gimbal project has some advantages for us and our users; like customizable dimensions,different electronics and motors usage varieties,personal wiring and equipments usage abilities and of course better pricing cause of 3d party electronics and motors.
We worked on some of our designing ideas and decided on one of them,which named as TwoDee EVO NG.It is not an ordinary design cause of some innovative touches.
First extra ordinary speciality is it is a CopterFrames product and you can find replacement mechanical parts when you need,with regular pricing.
An other one is that, it is DIY and you can find all industrial replacement parts (like bearings,spacers) on the market.
TwoDee EVO NG has 2 bearings for all axises.Using two bearings saves all axises from radial loads. Dual bearings serve smooth movements and provides more efficiency.
TwoDee EVO NG kit, comes as cnc machined aluminium parts and with all necessary harware.
You need 4 pieces 16mm outer diameter carbon booms for starting assembly. 2 of them must be dimensioned for inner width and 2 of them must be 18mm longer.
Assembly time is near 1.5 hours.
And finally,marketing price.
$439
We are open for ideas and suggestions about mounting style for your frame.
Greetings
Ozan
ozanozkok is offline Find More Posts by ozanozkok
Old Mar 05, 2015, 02:06 PM
Joined Sep 2013
Interested in this. Do you have more specifications? What are the dimensions and weight when fully installed? What is the bolt pattern for the motor mounts? Why not include the carbon tubes in your kit?
zerstorer78 is offline Find More Posts by zerstorer78
Old Mar 06, 2015, 02:24 AM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
Hi zerstorer,
Dimensions:
Outer Height 260mm
Outer Width 225mm
Outer Depth 210mm
Inner Height 180mm
Inner Width 158mm
Inner Depth 100mm
Weight 1500gr
Motor mounting pattern is same with rctimer's 5208-200t and iflight's 5208-180t.You can use same patterned motors without modification or you can use another one with easy modifications.
We dont include carbon booms for kit version but rtf and assembled version has carbon booms.Our idea is that, you can change the carbon boom dimensions for kit version and you can build your gimbal with bigger or smaller camera space.
Greetings
Ozan
Old Mar 08, 2015, 06:51 AM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
TwoDee EVO NG has enough space for additional equipment with Gh4 and similar cameras
Old Mar 08, 2015, 12:38 PM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
Easy to balance camera tray and tilt arms.
Old Mar 11, 2015, 11:02 AM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
All axises ready for hollow shaft motors.
Old Mar 20, 2015, 11:00 AM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
Onboard vibration dampening
Old Mar 24, 2015, 11:12 PM
United States, LA, West Monroe
Joined Oct 2012
Looks great!
AerialVid is offline Find More Posts by AerialVid
New Product TwoDee EVO NG DSLR size DIY gimbal ozanozkok Multirotor Talk 7 Mar 20, 2015 11:01 AM
For Sale TwoDee EVO 2 axis gimbal $200 i love nachos Aircraft - Electric - Multirotor (FS/W) 2 Aug 08, 2013 07:25 PM
Sold Copterframes Evo TwoDee Gimbal with Hitec HS-5565MH knichefilms Aircraft - Electric - Multirotor (FS/W) 0 Jun 30, 2013 01:26 AM
For Sale DIY 3 axis Camera Gimbal for DSLR helisfreak Aircraft - Electric - Helis (FS/W) 14 Nov 11, 2012 09:08 AM
Build Log "DIY" DJI 450/550 Comp. DSLR Gimbal with Landing Gear peoples Multirotor Talk 7 Oct 31, 2012 03:40 PM
