Old Jun 19, 2014, 10:30 AM
Joined Mar 2007
Marine Steam fron Deans Marine
DEANS MARINE / MAMOD STEAM PLANT no.1
First production run of the new steam plants available now.
The No.1 marine steam set consists of a gas fired boiler unit, with pre assembled mounting plate and bracket.
Assembled ceramic burner unit.
Refillable butane gas tank, gas connector pipe and a pre- fitted burner,.
A long stroke, twin cylinder oscillator vertical inline engine, with fwd and reverse control, fitted with twin flywheels for smooth running.
Displacement lubricator. Steam connector pipe.
Set of operating instructions
Introductory price for the first batch only 385..00 plus we will include, free of charge, a pressure gauge, and a aluminum condenser tank, value 62..00.
START IN STEAM SET.
To get you started in steam without all the hassle of having to design a boat, or find a hull that may fit, find a shaft and coupling and a prop that will get the best from the engine, and make it all work, maybe.
Deans Marine are offering the following set to match the No 1 plant
Consisting of.
Condenser tank / oil trap
8" Brass proptube with stainless steel shaft and oiler tube.
Heavy duty Raboesch coupling
4 blade brass prop to match the engine.
Complete rudder assembly and tiller arm.
Silicone tube connecting pipes
Top up syringe.
Thames steam launch glass fibre hull, 38" x 6" with gingerbread and plating detail.
Full size plan showing location and layout details
A C/D of build picture of our prototype model, as seen on forums and U Tube.
Introductory price of 135..00 plus delivery.
We will have these units on Display at the Kirklees open days on 13 July
Regards
Deans Marine
rondean1 is offline Find More Posts by rondean1
Old Jun 20, 2014, 07:17 AM
United States, LA, Houma
Joined Jun 2008
Any test bids of assembly running?
You kit looks very nice.
igotit is offline Find More Posts by igotit
Old Jun 20, 2014, 09:15 AM
Joined Mar 2007
deans marine steamu tube
see U tune for the first test run
DEANS MARINE - NEW STEAM ENGINE & HULL - 1ST TEST RUN (8 min 18 sec)
Old Jun 20, 2014, 09:47 AM
oldtribefan
oldtribefan's Avatar
Walnut Creek, CA
Joined May 2007
Wow! Nice!
oldtribefan is online now Find More Posts by oldtribefan
Discussion deans marine steam at the South West model show rondean1 Scale Boats 0 May 01, 2014 04:28 AM
Sold Maxwell Hemmens Marine steam engine with Cheddar boiler for sale mistairjoe Boats (FS/W) 2 Sep 30, 2013 08:29 AM
Discussion LCM 6 release from Deans Marine rondean1 Scale Boats 6 Sep 21, 2013 01:15 PM
Discussion Marine steam from deans marine rondean1 Scale Boats 0 Sep 19, 2013 08:18 AM
Discussion NEW STEAM PLANT FROM DEAN MARINE on test runs rondean1 Scale Boats 0 Aug 20, 2013 07:10 AM
