Old Sep 13, 2014, 09:17 PM
Joined May 2012
I did try to fly today with V1 in GPS mode my hexa was trying to fly away for a min it was not responding to stick and I have to release throttle to land since it was 2 meter up so I broke one of my props never had this issue scary i donot want to lose my expansive hexa any reason for fly away what could be the cause????
paktazh is offline Find More Posts by paktazh
Old Sep 14, 2014, 01:26 AM
Geneva, Switzerland
Joined Jan 2009
There's actually a solar storm that could affect GPS signal, you should check sun status before flying to be in the safe side.
helicoblast is offline Find More Posts by helicoblast
Old Sep 14, 2014, 07:51 AM
Slovenia
Joined Feb 2011
I have three Wookongs with the latest FW and the same voltage protection settings.
But with one I get readings from DJI OSD 0,35V less than actual voltage when in the air. On the ground it shows the same value as the battery monitor.
On two other Wookongs I get the same voltage reading on OSD as the actual voltage is in the air.
What could be wrong here?
quadslo is offline Find More Posts by quadslo
Old Sep 15, 2014, 03:25 AM
tigar's Avatar
Athens, Greece
Joined Sep 2001
try to shitch the psu around to see if the problem follows.
tigar is offline Find More Posts by tigar
Old Sep 15, 2014, 08:24 AM
Slovenia
Joined Feb 2011
Tigar, can you explain little bit more please?
thanks
Old Sep 15, 2014, 09:15 AM
tigar's Avatar
Athens, Greece
Joined Sep 2001
thanks
I meant PMU. try to switch around the PMU of your multies. See if the problem of the wrong voltage follows a pmu or it sticks to a specific controller.
Old Today, 06:24 AM
Joined Sep 2011
Anyone could help me with the yellow and green led flash at boot up? Abnormal GPS data is what it says in the manual, but I have re calibrated many many times and sometimes the Led goes white, which is good, some time it goes into solid purple and most of the time it would go straight back into flashing green and yellow. The weird thing is it flashing green and yellow WITHOUT the GPS pug plugged in.
This is a WKM unit that hasn't been used for about 10 months.
I left it outside for 20 mins and it was able to pick up 7 sats.
I move the quad on the ground as little as a few inches and green/yelow flash
FW 2.26 is where it happened. Downgraded to 5.18 and it seems fine.
There is a thread where people experiencing this on 5.24 and 5.26, but no confirmed fix.
Any help? I am scratching my head. Thanks.
Here is a short video of the error
WKM error (1 min 10 sec)
M
flashervn is offline Find More Posts by flashervn
Old Today, 09:02 PM
DJI Support
Las Vegas/Lake Tahoe
Joined Feb 2010
http://youtu.be/g3g1CsGsLzM
M
You cannot calibrate your compass if the GPS/Compass is disconnected.
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Latest blog entry: Landing Gear Reset S800
Discussion Ballistic Recovery System for Multirotors Duck! Aerial Photography 65 Feb 26, 2014 09:58 PM
Discussion DJI - WooKong eStab for Scale sidneyw Scale Helicopters 97 Dec 30, 2012 10:48 AM
Discussion FY3ZT Autopilot for Aerial Photography feiyudz Aerial Photography 116 May 07, 2012 04:58 PM
Discussion DJI AceOne autopilot for sale... hazchem88 Aerial Photography 4 Mar 31, 2011 03:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
