Old Sep 08, 2014, 10:43 PM
Singapore
Joined Nov 2007
Originally Posted by l.aluffi View Post
I mispelled, sorry. I was meaning the other part of the plan.
Sorry, its all I have for the plan, I cut internal parts based on my own estimation. The wing using Clark-Y profile
buratino is online now Find More Posts by buratino
Old Sep 12, 2014, 11:28 AM
United States, AZ, Tucson
Joined Apr 2012
14" NutBall
Built this NutBall from $Tree foam.
14" NutBall (3 min 4 sec)
boa2110 is online now Find More Posts by boa2110
Old Sep 12, 2014, 12:53 PM
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Mine has skids, so it is a snowball, this kit http://kenscadmodels.com/nutball-15-indoor-flyer.html has wheels, and is called a nut ball, but yours has neither, and with your plane retrieval skills, will probably never need either...
My point is, it is not complete enough to decide which it is!
dbacon is offline Find More Posts by dbacon
Old Sep 12, 2014, 02:04 PM
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
low wing twins cargo plane at 25% with longer wings.
with lights for night flying. 4 airhogs 6mm motors an props.
TAER. single aileron.
AUW 31 grams.
nemoskull is offline Find More Posts by nemoskull
Old Sep 12, 2014, 10:27 PM
Nooflyer's Avatar
United States, MO, KCMO
Joined Aug 2005
Micro Chris Pitts 2XL
Here's my newly built micro pitts blown up 200% from the original plans.
WS is 24 inches
weight so far is 48g without electronics.
So i'm estimating it to come up to 120g AUW. Also have full top ailerons and bottom wing half length ailerons. Should be sufficient enough.
Now just waiting on motor and esc in the mail.
Nooflyer is online now Find More Posts by Nooflyer
Old Sep 13, 2014, 12:28 AM
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Very nice! Looks like it could be a handful to fly,
Old Sep 13, 2014, 11:29 AM
Nooflyer's Avatar
Joined Aug 2005
Well the micro version flies graceful so this one should be a breeze to fly.
Old Sep 13, 2014, 07:30 PM
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
No kidding? It looks like a hot rod. Hmmm,maybe I should add it to my wish list. We do have a nice long building season in Michigan...
Old Sep 14, 2014, 03:22 AM
robinson727
USA, MS, Byhalia
Joined Nov 2010
Gray Ghost
Here's ours: I enlarged the P-Nut plan on Outerzone to 19.5 " It weighs 119G w/ 200 mah eFlite battery and the same internals used in the GeeBee..
Ist flight was yesterday.. it's a lot of fun and easy to fly. The motor is midship and a .032" piano wire drives the prop which runs on 2 roller bearings from SDP .. It's different and plenty zippy.. :
Gray Ghost Mini pylon racer (1 min 30 sec)
Sent from my crystal radio
robinson727 is offline Find More Posts by robinson727
Old Sep 14, 2014, 06:45 PM
Life begins at 40
addictedtoplanes's Avatar
Canada, ON, Guelph
Joined Jun 2012
Looks like it flies great!! Here's my latest creation:
22.5" span B-25J, made from Paul Bradley No-Cal plans
So far, it has only had short hops, but these have proved that it needs a rudder.
AUW 45g
addictedtoplanes is online now Find More Posts by addictedtoplanes
Old Yesterday, 05:41 PM
I NEED a micro seaplane lrf!!!
fabersum's Avatar
Torino
Joined May 2007
F6F Hellcat on Truckerboy plans http://www.rcgroups.com/forums/showthread.php?t=1244550
all the stuff is from my old Parkzone UMX Spitfire. The only changes from that setup are a GWS 5043 prop and a 240 mAh 1s Hyperion battery.
I also changed the motor wires: since I needed longer ones I changed them for thicker ones - that gave me an almost 5% thrust increase on thrust stand!
I put all the components as far forward as possible to have the COG around the right place without the battery installed to avoid ballast in the nose, and I put the battery location around the COG too so to be able to try different sizes of batteries without changing the model balance.
The receiver is held in place by a balsa fixture and the motor mount is held by screws. Both features were very useful in the trimming process.
The motor cowl is held in place by two short carbon rod stubs and magnets. The battery cover just by two magnets.
The built-up tail feathers came out heavier than the solid balsa ones..
What can I say more.. the dihedral break on the ailerons control rods is made with two layers of shrink tube.
48 g without battery, 53 AUW ready to fly.
here's a short video:
F6F Hellcat in balsa, voletto pirata alla Reggia di Venaria durante gli MTV Digital Days (1 min 12 sec)
more photos in Truckerboy's F6F thread: http://www.rcgroups.com/forums/showp...&postcount=270
fabersum is offline Find More Posts by fabersum
Old Yesterday, 06:37 PM
Gulf Breeze, FL
Joined Jul 2006
Horten Flying Wing
This is a beta build of Jing Models Horten H VII. See thread here for details. Quite a well engineered kit.
Gene K
speedy01 is online now Find More Posts by speedy01
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 126 Mar 26, 2013 06:30 AM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
