Old Nov 03, 2008, 08:21 PM
sruelle's Avatar
United States, MI, Ann Arbor
Joined Feb 2005
3 blades for a sls on a DG800S
I am thinking about the settings for puting a sls unit in my DG800 1:4, and as I don't like to cut too much of the fuselage for the doors, I would like to make the arms as short as possible.
My project is to use 42mm diameter outrunner with 11 or 12 inches fording blades using aeronaut hub for 3 blades. like the one available at icare
http://www.icare-rc.com/self_launch_...lding_Prop_SLS
Question, does anybody tried that? is 3 prop a good solution?
Stephane
sruelle is offline Find More Posts by sruelle
Old Nov 04, 2008, 04:46 PM
glider guider
glider guider's Avatar
Winnipeg, MB
Joined Mar 2005
I see no reason it would be a problem. The ICARE unit with four blades produces 10 lbs thrust.
glider guider is offline Find More Posts by glider guider
Old Sep 28, 2014, 08:53 PM
sruelle's Avatar
Joined Feb 2005
The project went well,
here is a short video of the system in action at the bench
DG800 SLS2.wmv (0 min 26 sec)
Old Sep 28, 2014, 08:54 PM
sruelle's Avatar
Joined Feb 2005
And one in flight today,
DG800S SLS in action (3 min 40 sec)
Stéphane
Old Sep 29, 2014, 12:19 AM
Keep calm and don't blink
KiwiKid's Avatar
Hamilton, New Zealand
Joined Jun 2005
Well done Stephane and very nice vid. Is there any cg variance when the motor is extended or is it compensated for?
KiwiKid is online now Find More Posts by KiwiKid
Latest blog entry: ModelAero Polaris Ultra
Old Sep 29, 2014, 05:50 AM
sruelle's Avatar
Joined Feb 2005
the cg change is not really visible in flight as you have first to fight again the moment given by the prop that has a tendency to put the nose of the glider down, it is why I use a flight mode with some up trim. Also dual rate helps as the wind generated by the SLS on the elevator make it quite sensitive
Old Sep 29, 2014, 04:08 PM
Quebec Aerotow Association
Charlescd's Avatar
Canada, QC, st-jean-sur-richelieu
Joined May 2010
Stephane,
Is that the FlyFly DG800S?
Charlescd is offline Find More Posts by Charlescd
Old Sep 29, 2014, 05:59 PM
sruelle's Avatar
Joined Feb 2005
Charles
It is not a fly fly, the kit comes from S2G, same one that is on Icare website
Stephane
Old Sep 30, 2014, 05:27 AM
Charlescd's Avatar
Joined May 2010
Thought so.
By the video it didn't look the same but you never know.
Please recommend a prop for GWS Tiny and 010 Astro on 3 kokams poobs Parkflyers 6 May 02, 2003 10:12 AM
FS: Graupner CAM 6x3 Folding prop - for 3.2mm motor shaft JohnM Aircraft - Electric - Airplanes (FS/W) 16 Apr 08, 2003 06:27 AM
Prop for 2/3 Lithium on GWS DX A-D ChrisE Scratchbuilt Indoor and Micro Models 13 Feb 23, 2003 09:35 AM
Prop for Endo at 3.8:1? Ben74 Electric Sailplanes 11 May 29, 2002 11:07 PM
Prop for Titanic Airlines S280 2.3:1 geardrive PeterH Power Systems 0 May 26, 2001 11:53 AM
