Old Sep 04, 2014, 12:57 PM
Joined Jun 2013
v977 5x 520 mah Battery - Charger Potentially Dangerous!
http://www.tmart.com/Wltoys-V977-V93...t_p250064.html
Anyone who has got this set of batterys that come with the little USB charger. Keep an eye on your batteries.
The first time i used it not trusting it i kept an eye on voltages. I had 1 battery hooked up and after the light came on mayeb 5 minutes as i didnt notice, checked on a muiltimeter and the battery votlage was 4.24v!
After that, when i was charging all 5 seemingly taking a while (over 2 hours) i checked 1 battery. it was at 4.19. fine leave it another 15-20 minutes.... Light still not come on.. Check battery 4.21v. I check the rest and all at 4.21
I dont know if this charger actually cuts of the power or if it just turns on the light but i do not trust it.
If it doesnt cut off then you could find yourself with batteries that not only will be damaged but risk exploding!
bazsound is offline Find More Posts by bazsound
Old Sep 04, 2014, 11:59 PM
Not here, very busy, PM me.
FyreSG's Avatar
United States, CA, Monterey
Joined Apr 2012
Parallel charging
It is just a parallel charging harness connected to a USB charger. I have been using one (without the USB charger) for a long time, but I connect mine to a computerized charger via JST-to-banana cable.
Over or under charging is common for USB chargers. They are made up of cheap components are are not calibrated. If you want precision, you need a computerized charger. Often, it lets you calibrate / fine tune the full charge level i.e. 4.20V. If you want full precision while charging multiple batteries, don't charge them in parallel. There are 3S-to-3x1S charging harnesses for such purposes. The computer will monitor each 1S cell of the 3S combo to prevent anyone from over charging.
The "fault" you have highlighted does not lie with the charger, but the fact that different batteries have different internal resistances. This results in uneven charging. While this is considered "normal", it may not be acceptable to some users.
Unplug the charger from the power source and allow the batteries to equalize the charge amongst themselves. They should have the same voltage after a few minutes.
FyreSG is offline Find More Posts by FyreSG
Old Sep 05, 2014, 05:03 AM
Joined Jun 2013
The charger that came with my v977 charges fine, it shuts off when charge is complete . Both batteries will meter 4.20v
This other charger im not sure if it even shuts of so i see that as potentially dangerous, maybe its charging to 4.24 before shutting of but i really dont want to risk leaving it plugged in to see if the voltage still rises.
What you said all makes sense, though it did manage to charge all the batteries to the same voltage despite not being a balance charger.
Anyway this is just to warn other people that this charger may damage batteries or at worst could caus an accident so to keep an eye on it.
Old Sep 05, 2014, 10:42 AM
Tucson, Az
Joined Feb 2007
4.2 is pretty strong charge. Over that is over charge.
dankar04 is online now Find More Posts by dankar04
Old Sep 05, 2014, 10:59 AM
Never let it down
Pachapapa's Avatar
France, RA, Lyon
Joined Oct 2013
It is the max charge. Imax B6 charges @ 4.2, and then stops (4.19 exactly). I always charge @4.2, and then they go down to 3.75 / 3.8 after flight
Pachapapa is offline Find More Posts by Pachapapa
Old Jan 07, 2015, 12:21 AM
Joined Jan 2015
I would NOT suggest using the parallel cable when charging more than one Lipo Cell as the USB portion has a charging circuit using a single MCP73831 which is only designed to supply a maximum of 500mA of charging current for ONE CELL ONLY.
I Repeat, the MCP73831 (and it's clones) are NOT designed to charge cells in parallel!
In fact, the MCP73831 Clone used in the USB charger portion is charging the cells to 4.4 volts which will vastly reduce cell life!
Get the 5-way charger found on ebay, it has five MCP73831 charging circuits, so each cell will get charged properly, and you avoid overcharging the cells with the least discharge which is what happens when you charge them in parallel with a single MCP73831.
Throw away the parallel cable, and the USB charger cable that came with it, they will not properly charge your cells, and they will damage them.
Doom2pro is offline Find More Posts by Doom2pro
Old Feb 12, 2015, 05:58 PM
United Kingdom, England, Egham
Joined Sep 2006
Hi,
What's the battery connector on the V977 called? It's hard to look for cables without knowing its official name.
Thanks.
cyclonite is offline Find More Posts by cyclonite
Old Feb 13, 2015, 08:40 AM
Joined Sep 2006
it's OK I've just found out they're called micro losi
Old Feb 18, 2015, 01:57 AM
Crash and learn
United States, PA
Joined Dec 2011
Five LEDs, likely five chargers, one for each battery
Five Ports Balance USB Charger for V977 V930 3.7V Batteries
http://www.banggood.com/Five-Ports-B...-p-967816.html
I have one similar to this for V911-Pro and it does act like four independent chargers.
Ribble is online now Find More Posts by Ribble
Help! WL V977 Battery Charger aht45 Beginner Training Area (Heli-Electric) 3 May 14, 2014 10:44 AM
Discussion Dangerous or bad to leave batteries connected to charger? Rangie5169 Batteries and Chargers 8 Mar 20, 2014 01:30 PM
Sold helimax 1sq vcam with 5x batterys rtf gregka Aircraft - Electric - Multirotor (FS/W) 6 Oct 16, 2013 06:55 PM
Discussion 12V 6800 mAh battery pack - dangerous or not? Injection Batteries and Chargers 1 Aug 20, 2013 02:24 PM
FS: Hitec Flash 5X with 9.6v 1800 mah nimh battery Nik-rc Aircraft - Electric - Airplanes (FS/W) 3 May 24, 2004 07:02 AM
