Old Nov 24, 2014, 10:53 AM
United States, GA, Woodstock
Joined Sep 2013
Flaperons vs Spoilerons
I need to slow the plane down onceI have landed. I have limited runway and do not want the plane to continue to roll on the pavement. Any suggestions, my guess would be flaperons. Let try to make this clear since I new at this. I have plane with elevons. So when I touch down and try to slow the plane elevons up or elevons down or neither and I chase the plane lol
decreale is offline Find More Posts by decreale
Old Nov 24, 2014, 11:07 AM
Joined May 2005
Why not try them and see which works best for you.
Personally I've found spoilerons to be far more useful, particularly on approach as they allow the plane to descend steeply without building up speed, or stalling.
Once the plane is on the ground, I don't think flapperons will do much good, and I'm not sure spoilerons will do that much either.
caseih is offline Find More Posts by caseih
Old Nov 24, 2014, 11:09 AM
Disarray's Avatar
United States, GA, Gray
Joined Apr 2007
I find that deploying spoilerons on a Telemaster after landing will help the plane stick to the runway. Flapperons will make it leap in the air at the same speed.
Disarray is offline Find More Posts by Disarray
Old Nov 24, 2014, 12:00 PM
WJH
United States, FL, Spring Hill
Joined Aug 2005
Flaperons on my 4*20 allow it to land slowly enough that rollout is a non issue. But again rollout is not an issue to begin with
WJH is offline Find More Posts by WJH
Old Nov 24, 2014, 12:23 PM
Joined Jul 2014
BOTH-- I use a 3 way switch.
Switch up = lotsa spoilers
switch mid = normal flight
switch down = 12% flaps (obviously the rate for spoilers and flaps is model dependent and you should understand their behavior with plenty of altitude before using near the ground)
this works great- I can throw on the spoilers on final , then often flip right down to flaps for flare and land. This allows the landing to be at very low airspeed. If your touchdown speed is low enough the braking problem is solved. If you need to come in hot, the spoilers might help on the ground but I think reducing your landing speed will be more beneficial.
EastCoastGuy is offline Find More Posts by EastCoastGuy
Old Nov 24, 2014, 12:52 PM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
If you can't land the model slower, (too heavy ?), you could try wheel brakes.
eflightray is online now Find More Posts by eflightray
Old Nov 24, 2014, 01:44 PM
Old age is not for sissies
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
When I used to fly off blacktop I just used a simple brake system. For Trike gear it can be as simple as a lever the presses against the wheel with up elevator.
Azarr
Azarr is offline Find More Posts by Azarr
Old Nov 24, 2014, 01:53 PM
Disarray's Avatar
Joined Apr 2007
I use the spoilerons in high winds. Helps the plane stay on the ground.
Old Nov 24, 2014, 01:56 PM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
With elevons you already have both spoilerons and flaperons.
Spoilerons simply move both ailerons up. With elevons that has the same effect as applying up elevator. Flaperons simply move both ailerons down. With elevons that has the same effect as applying down elevator. In other words, applying up elevator would have the same effect as deploying spoilerons and applying down elevator would have the same effect as deploying flaperons.
Larry
Lnagel is offline Find More Posts by Lnagel
Old Nov 24, 2014, 03:23 PM
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
I was wondering when you all would notice that the OP said that he has elevons. Lol.
Leave it to Larry to notice first.
decreale: You can't use spoilerons or flaperons on your plane since it doesn't have separate ailerons and elevator.
What you have is up or down elevator. Learn how to land properly with what you have because that's all you've got.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Nov 24, 2014, 03:44 PM
Carlsbad, CA
Joined Sep 2004
I want to see a picture of your plane decreale.
rockbus is offline Find More Posts by rockbus
Old Nov 24, 2014, 08:18 PM
WJH
Joined Aug 2005
mw
Doh!
Old Yesterday, 12:03 PM
Joined Sep 2013
Picture of plane
Here is a picture of the plane. It is interesting if the plane touches the ground and I kill power wait 2 seconds and apply down elevator would that not cause drag and slow the plane. If I apply up elevator would I not get the same affect. The plane cannot lift off not enough speed just drag
Old Yesterday, 12:43 PM
poppopfox's Avatar
United States, PA, Reading
Joined Jan 2010
I need to slow the plane down once I have landed.
An old school solution would be to place a thin cross-section of fuel tubing between the wheel collar and the wheel, adjusting the braking pressure by pushing in slightly on the wheel collar as you tighten it.
poppopfox is offline Find More Posts by poppopfox
Old Yesterday, 01:18 PM
Carlsbad, CA
Joined Sep 2004
Decreale,
Interesting plane. I have no experience with a ducted fan plane with wheels. The closest plane I've flown like that was a Multiplex funjet (4S 3600kv - scooted pretty fast) which was a belly lander and a pusher prop, but when you cut the power it dropped in nice and slow.
Good luck hope you figure out how to slow your plane down.
Ray
Discussion Spoilerons or Flaperons? Lost_Dawg Slope 9 Nov 01, 2013 08:51 PM
Discussion Flaperon/Spoileron help flygilmore Radios 1 Oct 15, 2013 01:22 PM
Flaperons vs. Spoilerons drone Electric Sailplanes 17 Aug 17, 2008 01:44 AM
Flaperons vs. Spoilerons? dklassen 3D Flying 32 Feb 06, 2004 07:29 PM
Flaperons vs. Spoilerons? dklassen Sport Planes 3 Feb 04, 2004 10:24 PM
