Old Nov 28, 2014, 08:21 AM
FY680 User
AGuerrav's Avatar
Colombia, Antioquia, Medellin
Joined Nov 2014
Thnx for the advice, finally after some wait i get a HDOP = 1.5 and was able to flight
AGuerrav is offline Find More Posts by AGuerrav
Old Nov 28, 2014, 08:29 AM
Wisconsin
United States, WI, Hayward
Joined Jan 2012
Congratulations, good flying!
mike_kelly is online now Find More Posts by mike_kelly
Old Nov 28, 2014, 09:58 AM
FY680 User
AGuerrav's Avatar
Joined Nov 2014
My channel in YouTube is AGuerrav if someone want to check my flights I'm open to any advice that can improve them
Old Nov 28, 2014, 11:20 AM
Wisconsin
Joined Jan 2012
Looks like you are doing great. Your gimbal is nice and smooth.
Old Nov 28, 2014, 02:49 PM
FY680 User
AGuerrav's Avatar
Joined Nov 2014
Tarot FY680 hex
Yeah thnx, for being new I think all is going ok
Old Nov 30, 2014, 06:22 AM
http://www.fpvportugal.com
GhostMaster's Avatar
Portugal
Joined Feb 2012
Nice findings, im about to build a quad similar to the power systems used in the FY680, i want to do aerial video, i read that bigger props generate more vibrations, im thinking more in a 6S 13" prop build.
ESC: Sunrise BlHeli 30A (great ESC)
Motor:?
Emax 3110 480kv or Hengli w42-25 390kv.
Or others...
Weight without lipo would be arround 1.3kg
With a 6600mah 6s arround 2.1kg/2.2kg.
Any suggestion?
GhostMaster is online now Find More Posts by GhostMaster
Old Dec 01, 2014, 01:37 PM
Joined Jun 2014
ESC's calibrating
My build is:
fy680
DYS SymonK 30a
Nada M v2
4c battery
Spectrum DX9
Spectrum 8000
My problem is that when ever I start up the motors I will only get 2 or 3 motors to start up. When I throttle up to about 50% the others will start up. I have read that I must first calibrate the ESC's. How do I do that?
headviking is offline Find More Posts by headviking
Old Dec 01, 2014, 02:27 PM
2Vision-Air
bakchos's Avatar
Canada, QC, Blainville
Joined Aug 2009
Originally Posted by headviking View Post
My build is:
fy680
DYS SymonK 30a
Nada M v2
4c battery
Spectrum DX9
Spectrum 8000
Electronic Speed Controller Calibration guide (0 min 42 sec)
bakchos is online now Find More Posts by bakchos
Old Dec 02, 2014, 01:18 PM
Joined Jun 2014
Originally Posted by bakchos View Post
I tried it and no confirmation beeps or any kind of change. Anything else I could try?
Old Dec 25, 2014, 09:19 AM
Sweden, Västra Götaland County, Trollhättan
Joined Sep 2014
My current setup has flown very well for around 2h.... until now
First off some general info & photos of my little bird.
Fy 680 Pro with extended arms to fit 14" props.
LD power 3508 580kv - 14"x4,7
Afro 30A ECS
DJI Naza v2 combo with iosb
Tarot 2axis gimbal with hero 3 camera
Taranis TX & RX
Conditions for todays flight was looking good with little wind and clear skyes.
Everything was promising and as I went on to arm the copter... then a small flash and spark from one motor followed by 5cm flames below the motors
As you all can see on my third pic the ESC is completely blown/burnt up.
What could possibly be the reason?
Borrsvang is online now Find More Posts by Borrsvang
Old Dec 25, 2014, 10:37 AM
Wisconsin
Joined Jan 2012
Afro 30A ECS
Taranis TX & RX
Sorry for your hassle. I know it is a pain.
You know these ESC handle a lot of current. If there is a bad solder joint with high resistance it can heat up in use. That can cause a FET to fail and even more heat. It is just luck that we get good or bad ESc's these days, they are all so cheap.
Also could be a small chip of metal in the motor shorting the windings is a possibility.
Good Luck
Old Dec 25, 2014, 10:48 AM
Joined Sep 2014
Thank you for your reply Mike_Kelly
I never thought a ESC would die on me in this way, i thought it would just stop the motor and that would be it. But this was quite dramatic with a large spark and 5cm flames bursting out from the ESC... to bad the gopro was mounted on the gimbal facing away from the faulty ESC.
God point Mike Kelly - do i dare use this motor again och should i trash it just in case off.
Even thought the ESC are cheap i would feel even more stupid if i just were to mount a new ESC and the same scenario would repeat it self again because the real cause was the motor...
Old Dec 25, 2014, 11:41 AM
Wisconsin
Joined Jan 2012
I understand. Yes there are ways to test the motor first. Here is a thread where they were recently talking about just this situation.
http://www.rcgroups.com/forums/showt...8#post30187713
But the simplest way would be to just buy a cheap low cost esc of low amp, just to test to see if the motor works before you put on a new expensive ESC.
Discussion Interested in getting a Mikrokopter hex or a droidworx hex. How hard is set up? LMAO Multirotor Talk 8 Dec 28, 2010 08:47 AM
Discussion Tarot 450SE V2 GF helipr0 Mini Helis 12 Oct 19, 2009 05:47 PM
Discussion Tarot 450SE V2 GF Kit? carmen5.3 Electric Heli Talk 8 Sep 18, 2009 09:54 AM
Discussion Align, Tarot, CopterX edfardos Electric Heli Talk 4 Mar 14, 2009 12:15 AM
For Sale Tarot 450 V2 KIT KS-Model Aircraft - Electric - Helis (FS/W) 5 Nov 10, 2008 11:16 AM
