Old Jan 03, 2016, 01:46 PM
ipscwolle is online now
Find More Posts by ipscwolle
ipscwolle's Avatar
Germany, BW, Eislingen
Joined Jun 2014
Originally Posted by jk6672 View Post
1+, you may break props with a 14. I put taller and skinnier tires on from a Top Flite 60 P-47 plane to give me more ground clearance with the 13x8. I like the 13x8.
Ok, I found a 13x8 in my stock. But it's labeled APC 13x8 Sport LP13080 Landing Product. Think this is not suitable for electric motors, or am I wrong?
Wolfgang
ipscwolle is online now Find More Posts by ipscwolle
Old Jan 03, 2016, 02:24 PM
jk6672 is online now
Find More Posts by jk6672
John
jk6672's Avatar
United States, CA, Heber
Joined Sep 2012
IDK, I'm using a VOX electric prop.
jk6672 is online now Find More Posts by jk6672
Old Jan 03, 2016, 03:59 PM
3rd Try is online now
Find More Posts by 3rd Try
United States, NY, Champlain
Joined Jul 2012
Wolfgang
The sport is heavier than the electric and a little less efficient, but will work fine. Please check you setup with a wattmeter before flying to insure your not exceeding max amps or watts on you esc or motor.
Regards
Dennis
3rd Try is online now Find More Posts by 3rd Try
Old Jan 04, 2016, 02:52 PM
ipscwolle's Avatar
Joined Jun 2014
Hello Dennis,
it's unbelievable what you can find in a hobby room if you dig deep enough
Found a bench of 48 props, among them 2 pcs 12x8 APC electric! Just one hour after I have ordered wooden VOX props, one 13x8 and two 12x8.
Will make an Excel list now and hang it onto the wall in my hobby room.....
So, let's hope for better weather and then test them all
TNX and greets
Wolfgang
Old Jan 19, 2016, 08:57 PM
cbinfl is offline
Find More Posts by cbinfl
United States, FL, Clearwater
Joined Jun 2009
I received my ElectroStik tonight, and the covering's not too bad. I think I can clean it up, but the left aileron has a "click" and some play in the control wire and the aileron. I see that "rkleinhenz" had a problem with his and wonder about dripping CA down the vertical wire ? I would like to cut the wire where it enters the end of the aileron and exits the wing bottom with a Dremel and going with two aileron servos. Any hints on the least damaging way to remove the existing aileron linkage ?
cbinfl is offline Find More Posts by cbinfl
Old Jan 20, 2016, 08:32 AM
Joined Jul 2012
CB; I highly recommend using 2 servos for the ailerons, that said, your issue with the loose/noisy torque rod is probably not important. Please check and insure that the torque rod is not hitting the inside of the fuselage.
Regards
Dennis
Old Jan 20, 2016, 09:38 AM
cbinfl is offline
Joined Jun 2009
3try, thanks for the reply. I cleaned and dug out around the wire down in where it sticks out of the wing bottom with an Exacto knife and freed it up. I think there was dried CA? hitting the wire enough that it clicked and inhibited the movement. The wire is still a little loose in the end of the aileron but now that the aileron moves freely I will use 2 servos and leave the wires in place.
