Old Feb 05, 2016, 05:34 AM
VTPete is online now
Find More Posts by VTPete
United States, NH, Claremont
Joined May 2014
Need advice: Can I run 4S on my DJI E300 based F450?
Hi All,
Pete here. The simple question, that I can't find a clear answer to is, can I run my F450 flame wheel with E300 power system and Naza M Lite on four cells rather than three?
I love my flame wheel, but with the mobius 3-axis gimbal I have on it, it's less than spritely and I'm getting about seven minutes of flight time from the 3300ma 3-cells I'm running.
I have some four cell batteries from a plane that I could use... around 3500ma (don't remember exactly.)
Oh, and I'm running the stock nine inch props as well.
The part I'm a bit confused about is whether the Naza M Lite can handle 4 cells, whether the E300 ESCs and motors can handle it and whether the voltage going to the receiver will be correct.
Lots of posts of people talking about this, but I'd much rather have a "You'll be fine, Pete!" response before I plug it in!
-Pete
VTPete is online now Find More Posts by VTPete
Old Feb 05, 2016, 05:38 AM
MultiRotR is offline
Find More Posts by MultiRotR
MultiRotR's Avatar
United States, GA, Atlanta
Joined Nov 2014
I run 4S on my Naza M V2 with E300. Most DJI stuff handles 3S-6S without a problem but I've never use a lite. Look on the PMU and see if it says anything or check the manual.
MultiRotR is offline Find More Posts by MultiRotR
Old Feb 05, 2016, 06:31 AM
BuffaloJustin is offline
Find More Posts by BuffaloJustin
BuffaloJustin's Avatar
United States, SC, Lexington
Joined May 2014
Yes, the E300 will handle 4S.
Yes, the Naza lite PMU (old style "VU" or new separate PMU and LED) will handle 4S. All DJI multirotor flight controllers accept 3-6S input for their respective PMUs. I am running 4S on two Naza lites presently
BuffaloJustin is offline Find More Posts by BuffaloJustin
Old Feb 05, 2016, 06:36 AM
Repaid1 is offline
Find More Posts by Repaid1
What goes up, hopefully lands!
Repaid1's Avatar
United States, OH, Johnstown
Joined Sep 2014
From the above post, I will say it, You'll be fine, Pete!
Repaid1 is offline Find More Posts by Repaid1
Old Feb 05, 2016, 11:31 AM
Joined May 2014
Thanks guys, I'm going to try it out ASAP!
And, I apologize... I should have posted this in the F450 master thread that I just found. I feel like a newbie! -Pete
Old Feb 06, 2016, 10:07 AM
Joined May 2014
FWIW,
I tried out a 4S battery today and the quad worked great. The gimbal, however (a Tarot controller) wasn't happy about going beyond the recommended voltage range. I didn't kill it, but it was overreacting and bouncing quite a bit. It's possible I could change it's settings, but for now I'll probably stick with 3S.
-Pete
Old Feb 06, 2016, 03:27 PM
Joined May 2014
Originally Posted by VTPete View Post
FWIW,
-Pete
Stick a 12v BEC between the gimbal and flight battery to make the gimbal happy. Or, you could use a separate small 3S battery. I did that once on a 4S hexacopter that used a t-2D.
Old Feb 07, 2016, 05:47 AM
Joined May 2014
I don't have a 12v BEC handy, but I have lots of smaller 3S lipos. I'm worried about the weight now... my F450 is beginning to look a bit like a Frankenquad! I just added the telemetry module that came with the Spektrum AR8000 receiver I'm using, so I suppose I could remove the little low-voltage alarm I have on it to save a few grams.
Thanks for the suggestion about the BEC. You know, some of the cheap $5 ghost FPV quads I bought during Hobby King's Christmas sale have 12V BECs built in; I'll check the rating to see if they could power to two axis gimbal because they're pretty small!
Question Does anyone have bumblebee 930 kv motor data ? can it run on 4s? Root_ender Power Systems 6 Jan 17, 2016 10:48 AM
Question Can i run the DYS 1806 motors on 4s? rc monkey Mini Multirotors 7 Dec 13, 2015 07:19 AM
Discussion Advice needed about my motor choice, & which 4S capacity needed for 78" Kadet. Randall Miller Electric Plane Talk 16 Oct 07, 2015 10:58 AM
Sold Parting out my dji f450 naza v2 e300 propulsion system JosephKing 87 Aircraft - Electric - Multirotor (FS/W) 0 Jul 09, 2015 08:14 PM
Help! Need a motor that can run on 4s saucisse Multirotor Talk 6 Nov 21, 2011 04:54 PM
