Old Dec 12, 2015, 08:05 AM
mick666 is offline
Find More Posts by mick666
Joined Jul 2012
Carbon tube spar - 3m glider
Hello
I'm looking to build a replacement centre section panel for a CircleDancer 3000. It is a one piece centre section with plug in tip panels.. Its a built up wing based around a 10mm carbon spar. Don't have the original centre
section.
I can source carbon tubes but my question is ... should I use a pultruded carbon or woven fabric carbon tube?
To give you an idea of the model ... there are photos on hyperflights site. There is an electric version also ... but i'm guessing they are the same build.
http://www.hyperflight.co.uk/product...e=CDG-3000-RES
http://www.hyperflight.co.uk/product...ode=CD-3000-FH
Cheers
mick666 is offline Find More Posts by mick666
Old Dec 12, 2015, 11:31 AM
jkettu is offline
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
Either one will be more than adequate for that kind of a plane. Woven will give you a little more torsional stiffness, but I doubt you will ever get into a situation where you would notice the difference. If the tip panel joiners plug into the spar tube, woven one will be more resistant to splitting - or you could wrap the tips of a pultruded tube with kevlar thread, dental floss or something.
In summary: if you have a convinient source of woven fabric tube (please share, if you do), go ahead and use it. If not, pultruded will do the job just fine.
jkettu is offline Find More Posts by jkettu
Old Dec 12, 2015, 01:46 PM
faldomak is offline
Find More Posts by faldomak
Croatia, City of Zagreb, Zagreb
Joined Oct 2012
'... convenient source of woven fabric tubes...'
http://seta-tech.de/themes/kategorie...?kategorieid=6
faldomak is offline Find More Posts by faldomak
Old Dec 13, 2015, 04:13 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
For me pultruded are a joke if not filled with anything light and solid enough to not them ovalise at effort and finally crack.
Broke two 10 mm tubes so far, in planes even smaller than 2 meters, just flying, not hard landings ! They crack even if pressed with two fingers !
But when filled with 8mm balsa round rod, the things change, a lot !
If they are used as joiners, wrapping pultruded with kevlar is mandatory.
renatoa is online now Find More Posts by renatoa
Question Carbon tube spars Wolphe Flying Wings 3 Aug 01, 2014 06:12 AM
Sold carbon fiber wing spar tube psychoticflyer Aircraft - General - Miscellaneous (FS/W) 0 Jan 05, 2014 12:10 PM
Discussion Wind your own Carbon tube spars eagle4 Foamies (Scratchbuilt) 0 Sep 30, 2013 11:40 AM
Discussion Carbon tube spar and fusalage, simple, foam wing glider? exhornet Free Flight 3 May 07, 2013 04:50 PM
Carbon tube 4 spar on dlg? Redster Electric Sailplanes 1 Jul 09, 2001 03:06 PM
