Old Dec 11, 2015, 05:02 AM
handyman 220 is online now
Find More Posts by handyman 220
United States, CT, East Hartford
Joined Jul 2008
Originally Posted by dsa44 View Post
hmmmm, i have a little bit of time, and not enough planes! Nudge nudge, wink wink!
lol!!
handyman 220 is online now Find More Posts by handyman 220
Old Dec 13, 2015, 03:27 PM
panzercreation is online now
Find More Posts by panzercreation
TSHobbies
panzercreation's Avatar
Georgia
Joined Jun 2010
hey folks, finally got mine assembled enough to test out the retracts,but Im having an issue with the front gear door..it'll work if I hook it straight to the receiver,but going through the gear control sequencer it wont work..just the door. the gear works fine, as well as the main doors. any ideas? or do I need to call BH? btw, they had that wire labeled wrong..took me forever to figure out it was for that door. it was labeled CH4 (Direction)
panzercreation is online now Find More Posts by panzercreation
Old Dec 13, 2015, 07:54 PM
TSHobbies
Georgia
Joined Jun 2010
sorry for the crappy vid..need to get another light ,and an extra set of hands to make a better one...but trying to show whats going on....out of camera sight the gear door was closed when the gear decided to go up unexpectedly a broke a part off the door.
20151024 (1 min 38 sec)
Old Dec 13, 2015, 08:28 PM
TSHobbies
Georgia
Joined Jun 2010
ok after playing with it alittle more, the door servo is working ,however it trys to close BEFORE the gear comes up...looks like that servo is reversed . and swapping the direction of the plug doesnt work ..is there anyway for me to reverse it? or do I have a bad sequencer (programmed wrong)?
Old Dec 13, 2015, 08:43 PM
Cubcrazy is online now
Find More Posts by Cubcrazy
Scale Foam Flyer
Cubcrazy's Avatar
United States, AR, Cabot
Joined Oct 2007
Are you wanting to reverse the operation of the worm gear retract, or the door servo?
If you just want to reverse the door servo (or any servo) you can use this method It is a bigger servo in the video, but the process is the same. I've reversed servos as small as 5 gram using this method.
If I remember right, the worm gear motor only has 2 wires (+ and -). I was under the impression that turning the plug around on the control board would make this type of retract operate in reverse???
Did you try maxing out your retract channel ATV? The Sequencer might see signal to open the door, but not to command the retract. Just spit-balling here.
Cubcrazy is online now Find More Posts by Cubcrazy
Latest blog entry: Warning!! Graphic images of...
Old Dec 14, 2015, 07:18 AM
TSHobbies
Georgia
Joined Jun 2010
The door servo.. when Im retracting the gear, the nose gear door closes before the gear comes up. Its suppose to open first, gear comes up,then closes.
Old Dec 14, 2015, 02:13 PM
TSHobbies
Georgia
Joined Jun 2010
just got off the phone with BH, its a bad sequencer ,which theyre sending me a new one.
Old Dec 14, 2015, 02:16 PM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
Thats good to hear. I really think that BH is turning themselves around after many years of being labeled as a "bad vendor". I have bought a few planes from them, and had a good experience.
-CC
Old Dec 14, 2015, 02:28 PM
brandonmoon is online now
Find More Posts by brandonmoon
Fly & Have Fun..Enjoy the Ride
brandonmoon's Avatar
United States, AZ, Gilbert
Joined Mar 2009
I just got this a moment ago from RC flight deck. Just thought I would pass it along to all my RC friends to FYI. I'll be posting this on my blog page as well
Mandatory registration begins December 21st.
PLEASE READ THIS ENTIRE MESSAGE IF YOU FLY ANY RC AIRCRAFT.
The FAA has announced a registration process for hobbyists who fly RC aircraft. I STRONGLY suggest that EVERYBODY read the FAQ page they have (link at the end) and demonstrate that we modelers are responsible pilots by registering as soon as possible after the website opens on December 21, 2015.
Here are relevant highlights:
1. Registration is free for the first 30 days. You pay 5 bucks online via credit card and they refund it.
2. You only register YOURSELF, get a number and put it somewhere on each of your aircraft.
HERE IS WHAT THE FAA SAYS ABOUT THAT:
A. You will receive a unique registration number that applies to any and all UAS that you own. You must mark all of your UAS with the unique registration number before operating. A registration certificate that contains the unique FAA registration number, the issue and expiration dates, and the name of the certificate holder will be sent to your email address immediately.
B. You will receive a unique registration number, not an N-number, and you must mark the registration number on your UAS by some means that is legible and allows the number to be readily seen. The registration number may be placed in a battery compartment as long as it can be accessed without the use of tools.
C. You may use any method to affix the number, such as permanent marker, label, engraving, or other means, as long as the number is readily accessible and maintained in a condition that is readable and legible upon close visual inspection. If your unmanned aircraft has an easily accessible battery compartment you may affix the number in that compartment.
3. You can continue to operate your RC aircraft as we have done for decades (http://www.faa.gov/uas/faq/#qn2).
HERE IS THE LINK TO REGISTER:
http://www.faa.gov/uas/registration/
brandonmoon is online now Find More Posts by brandonmoon
Old Dec 20, 2015, 08:20 AM
TSHobbies
Georgia
Joined Jun 2010
got the new sequencer from BH yesterday...installed it ..same problem..which led me to think (shouldve thought of this before) did they install the servo backwards? sure enough,all I did was flip the servo around and it works in time like it should.. duh.
Old Dec 20, 2015, 05:58 PM
buffetbob is offline
Find More Posts by buffetbob
buffetbob's Avatar
United States, FL, Valrico
Joined Nov 2010
HOLD ON! STOP THE PRESSES. LOOKS LIKE AMA IS APPEALING. Check out the AMA site for more details but they're taking the FAA to court.
buffetbob is offline Find More Posts by buffetbob
Old Dec 26, 2015, 08:00 PM
cherubs 9 is online now
Find More Posts by cherubs 9
cherubs 9's Avatar
Joined Jan 2013
Nuts!!
cherubs 9 is online now Find More Posts by cherubs 9
Old Jan 06, 2016, 06:36 PM
J Breyman is offline
Find More Posts by J Breyman
United States, OH, Arcadia
Joined Jan 2007
Glad I found this thread lots of great info on LX B-25. Just got mine before Christmas haven't tried any of the electronics crossing my fingers.
J Breyman is offline Find More Posts by J Breyman
Old Feb 07, 2016, 11:38 AM
sharkbyte is online now
Find More Posts by sharkbyte
sharkbyte's Avatar
Agoura Hills, CA
Joined Jan 2006
Cockpit/battery hatch cover
Does anyone know where I can get a battery hatch cover/cockpit unit for this plane? I want to utilize a different size battery that will require some cockpit modification. I would like to retain the original cockpit as it has pilot figures. New setup would probably lose the cockpit floor and pilots. I tried BH but they do not list the part. Any suggestions would be appreciated.
sharkbyte is online now Find More Posts by sharkbyte
Old Feb 07, 2016, 01:37 PM
AussieHoppy is online now
Find More Posts by AussieHoppy
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
Could try contacting f-hobby http://www.f-hobby.com/index.php?gOo...0&productname= , they've helped out a lot in the past with things like this, email Rose f-hobby@hotmail.com
Also pw-rc http://pw-rc.com/ has performed some miracles too, not sure if he can source LX spares but certainly worth contacting Phil Info@pw-rc.com
That's about the best I can offer atm
AussieHoppy is online now Find More Posts by AussieHoppy
Build Log New LX FA-18 twin 70mm EDF {from LX models & Blitz works R/C} brandonmoon Foamy EDFs 1444 Apr 05, 2012 01:38 AM
Video LX B-2 Landing Gear RGS2010 Electric Plane Talk 3 Oct 03, 2011 07:16 AM
Wanted JR models B-25 parts wingman11570 Aircraft - Electric - Airplanes (FS/W) 0 Aug 04, 2011 01:14 AM
Wanted JR Models B-25 jricchio Aircraft - Electric - Airplanes (FS/W) 0 Jul 16, 2011 01:36 PM
Sold JR Models B-25 onio condor Aircraft - Electric - Airplanes (FS/W) 2 Jun 25, 2011 08:12 AM
