Old Jan 27, 2016, 03:58 PM
mycaptain is offline
Find More Posts by mycaptain
mycaptain's Avatar
United States, MI, Kalamazoo
Joined Jan 2012
AR400 rx question answer
Problem was NOT my AR400 rx. It was my DX4e Radio!
I swapped out my AR400 rx with another one I had and I still had the same problem. I then bound a different DX4e to the plane and bingo, problem went away. I then took her out and flew 2 batteries through her to make sure.
Many thanks to those who wrote with suggestions. Happy fly'n... Capt'n
whirlcap... Thanks for your suggestion on the radio distance from the plane. I had already had tried that. Learned that one on another plane I have to do that with.
Blaze... Really like that cc you got there. I bought a yellow cub for this summer but it's a little bigger in size.
mycaptain is offline Find More Posts by mycaptain
Old Jan 27, 2016, 04:04 PM
Blaze0021 is online now
Find More Posts by Blaze0021
Blaze0021's Avatar
United States, CO, Highlands Ranch
Joined Apr 2015
Thanks Captain! It's the new UMX J-3 Cub . Great 2S flyer.
Glad to hear that your issues went away!
Blaze0021 is online now Find More Posts by Blaze0021
Old Jan 27, 2016, 06:18 PM
dalecheek1 is online now
Find More Posts by dalecheek1
United States, NC, Garner
Joined Nov 2012
QQ Extra 300
QQ EXTRA 300 Low an Slow (3 min 10 sec)
dalecheek1 is online now Find More Posts by dalecheek1
Old Jan 28, 2016, 12:52 AM
Bluhammer is offline
Find More Posts by Bluhammer
Bay Area Prop Buster
Bluhammer's Avatar
Bay Area CA
Joined Jan 2011
Super sweet Dale! I'd post that to if I could fly like that. Well done
Bluhammer is offline Find More Posts by Bluhammer
Old Jan 29, 2016, 12:09 PM
Blaze0021's Avatar
Joined Apr 2015
Eflite UMX J-3 Cub (2S BL) 3000KV - Custom Dubro 2" Tundra Tires Flight Demo
Here is the touch and go, take-off and landings flight demo of my UMX J-3 Cub (2S BL) 3000KV using my custom Dubro 2" Tundra Tires.
Eflite UMX J-3 Cub (2S BL) 3000KV - Custom Dubro 2" Tundra Tires Flight (6 min 6 sec)
The process to make your own custom Dubro Tundra Tires set is as follows:
I gently pried off the Foam from a set of these Dubro 2" Super Lite Wheels: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAZE3
The Foam is a PITA to remove and requires patience as well as a blunt nose pair of pliers as you grip the edge of the Hub and pull.. and pull your way around. The Foam will eventually give, but will not tear.
Then I took the Hubs from these Wheels: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXBNB8
I spray painted these Hubs a metallic black, then added the lug nut details and finally press-fitted them directly on the Dubro 2" Super Lite Foam. They are a direct fit (not loose or wobbly) and will not come off. The Hubs are also a direct Landing Gear Fit which makes installation very simple.
"How did you make your Tundra Tires?" is the question I get asked most often with regards to my UMX J-3 Cub (2S BL), Hobbyzone Sport Cub S (2S Brushless) "Icarus", as well as my Hobbyzone (2S Brushless) Champ Crophopper. These custom Dubro Tundras have proven themselves time and time again to be extremely durable and reliable, providing shock absorbing qualities and enhanced ground handling over rough terrain, as well as providing a more rugged look.
OTHER PLANES IN MY FLEET USING THE CUSTOM 2" DUBRO TIRES:
Hobbyzone Sport Cub S (2S Brushless) "Icarus" with custom 2" Dubro Tundra Tires:
Hobbyzone Sport Cub S (2S Brushless) - Yak/Pitts Prop 3000KV Flight (6 min 56 sec)
Hobbyzone (2S Brushless w/Ailerons) Champ Crophopper with custom 1.75" Dubro Tundra Tires:
Hobbyzone "Champ Crophopper" (2S Brushless w/ Ailerons) - Music Video (3 min 3 sec)
UMX J-3 CUB (2S BL) MODIFICATIONS / UPGRADES
Motor: Eflite 180BL 3000KV Motor
Prop Adapter: Small Parts CNC Aluminum UMX Prop Adapter
Lighting: UMX Carbon Cub SS Navigation Lights
Wheels: Custom 2" Dubro Tundra Tires
Transmitter: Spektrum DX6
Battery: Eflite 2S 280mAh 30C
Timer: 5 Minutes
Battery Discharge: 7.66 Volts out of 8.40 Volts
Control Rates: 100%
Expo: None
Aileron Control Rod Adjustment - One Hole In from Stock
Elevator Control Rod Adjustment - One Hole In from Stock
Rudder Control Rod Adjustment - No Adjustment from Stock
Camera: iPhone 6 at 1080P / 60 FPS
Headmount: http://www.amazon.com/gp/product/B00..._detailpages00
Thanks for watching and if you haven't already please click the Thumbs Up and Subscribe!
Old Feb 05, 2016, 03:19 PM
Bluhammer's Avatar
Bay Area CA
Joined Jan 2011
Is that crickets I hear chirping?
Old Feb 05, 2016, 06:49 PM
whirlcap is offline
Find More Posts by whirlcap
If it spins, wear it.
whirlcap's Avatar
Northern Nevada
Joined Jan 2011
Snow makes no sound
whirlcap is offline Find More Posts by whirlcap
Old Feb 06, 2016, 09:53 PM
Bluhammer's Avatar
Bay Area CA
Joined Jan 2011
Tomorrow will be first float flights for my Sportscub S2 and Pitos new Durafly Tundra. Weather looks to be great.
Old Feb 06, 2016, 09:55 PM
Blaze0021's Avatar
Joined Apr 2015
Good luck Bluhammer!
Old Feb 07, 2016, 01:06 AM
foamyflyerr is online now
Find More Posts by foamyflyerr
Joined Jun 2012
Will be there with camera in hand to record the occasion
foamyflyerr is online now Find More Posts by foamyflyerr
Old Feb 07, 2016, 07:10 AM
helibard is offline
Find More Posts by helibard
CRASH, FIX, REPEAT
helibard's Avatar
United States, KY, Bardstown
Joined Apr 2010
Good luck with the floats Dave.
helibard is offline Find More Posts by helibard
Old Feb 07, 2016, 08:27 AM
Joined Jun 2012
hey there helibard, good to see you ........
how yeah been ?
been working hard ?
Old Feb 07, 2016, 09:19 AM
Bluhammer's Avatar
Bay Area CA
Joined Jan 2011
how yeah been ?
been working hard ?
Him and his wife are out there patching people like us up, God bless em
Old Feb 07, 2016, 09:55 AM
benz11 is online now
Find More Posts by benz11
Australia, WA, North Perth
Joined Jan 2014
Edit: moved
benz11 is online now Find More Posts by benz11
Old Feb 07, 2016, 04:03 PM
helibard is offline
CRASH, FIX, REPEAT
helibard's Avatar
Joined Apr 2010
Yes, working a lot of overtime this time of year, hospitals get pretty busy until March. Still read up on all you guys here daily, just no flying here. When I get a nice off day the wind acts up. Once spring hits I'll slow down and get some stick time.
Discussion Another Topic on Champ Vs Mini Cub :) Tcragun56 Beginner Training Area (Aircraft-Electric) 36 Mar 17, 2011 04:39 AM
The Off Topic, Off Topic Thread #2 Spadplanter Life, The Universe, and Politics 13 Jun 25, 2004 08:33 AM
The Off Topic, Off Topic Thread Spadplanter Life, The Universe, and Politics 76 Jun 17, 2004 01:40 AM
