Old Apr 26, 2015, 09:23 PM
morockpow is offline
Find More Posts by morockpow
United States, CA, Vacaville
Joined Apr 2011
Question
Rare Bear
Help...what is with this Rare Bear going straight up? I read a little, but it did not tell how to correct the problem....i saw pics as well, but the control surface didn't seem to be different then the one i have., It does seem to be the elevator is where the issue is ? Can any one give me specific corrections or a starting place, such as, if the elevator needs to be adjusted then by how much in mm or in. if something else CG which is set to manual specs.
Please let me know what i need to do to keep the plane from flying up up and away!
Other then that it OK...thanks moe
morockpow is offline Find More Posts by morockpow
Old Apr 26, 2015, 10:27 PM
Clive66 is offline
Find More Posts by Clive66
Clive66's Avatar
United States, CA, Fontana
Joined May 2011
What Rare Bear are you talking about ?
I see you posted this in the Sport Plane Forum also (looking for a shotgun effect with no plane info)
Clive66 is offline Find More Posts by Clive66
Old Yesterday, 12:15 AM
PRNDL is offline
Find More Posts by PRNDL
What Goes Up Must Come Down
PRNDL's Avatar
United States, NJ
Joined Jan 2013
Check post #634 in the warbird forum
http://www.rcgroups.com/forums/showt...334985&page=43
There is a thread on this plane in the parkflyer forum as well.
http://www.rcgroups.com/forums/showthread.php?t=2334924
Sounds like you have your elevator out of trim...did you adjust it while flying?
I have this plane but haven't maiden it so I can not give a specific answer other than the elevator should line up with the extended portion of the fuselage per my pic.
Description:
PRNDL is offline Find More Posts by PRNDL
Discussion Ultimate Mini Rare Bear Mods aka Bearcat RacingJake Electric Warbirds 2 Jan 06, 2015 01:55 PM
Discussion Ultimate Mini Rare Bear Mods aka Bearcat RacingJake Combat 0 Jan 05, 2015 09:34 AM
For Sale 1400mm Hobby King Rare Bear flyncoastie Aircraft - Electric - Airplanes (FS/W) 1 Dec 07, 2014 02:29 PM
Discussion Eot Models Rare Bear and Hacker Rare Bear chrisorbics Foamies (Kits) 0 May 02, 2012 06:25 PM
Rare Bear is a Rare Treat! Steve McBride Parkflyers 0 Sep 14, 2002 11:36 PM
