Old Sep 22, 2013, 07:00 PM
Joined Aug 2013
burnt fuse on boscam transmitter?
Is this a burnt fuse on this thing? I'm pretty certain I had it wired correctly. Is it true boscam has the red and black wires switched? Could anybody point me in the direction of the correct wiring diagram? This is what I'm tracking as of now.
Yellow to yellow (video)
Red to white (audio) not necessary
Brown to black (ground)
Correct?
Looking to use the replacement one I just ordered on my gopro black.
riryorourke is offline Find More Posts by riryorourke
Old Sep 22, 2013, 07:19 PM
Joined Aug 2013
I should add it was being run off of a 3s lipo too.
Old Sep 22, 2013, 07:26 PM
natscape's Avatar
Philippines, NCR, Makati City
Joined Sep 2012
I don't know if that's a burnt fuse but I have that same vtx and that red and black wires are correctly labeled as in your 2nd pic.
I also run it off the balance plugs of a 3S battery with no issues, barely gets hot, just a bit warm.
natscape is offline Find More Posts by natscape
Old Sep 22, 2013, 07:55 PM
Joined Aug 2013
Would running it off of a xt60 cause this? I've seen it done before. I've also seen this burnt exactly like this as well.
Old Sep 23, 2013, 12:49 AM
wexter's Avatar
Joined May 2013
Have the same problem. My problem was that i connected Mobius Action Cam power input into Tx video in.
Now everything works but cant powersupply camera through Tx. Would be nice to know how to repair it, because it cost quite a lot.
wexter is offline Find More Posts by wexter
Old Sep 23, 2013, 11:39 AM
United States, TX
Joined Oct 2009
I'll buy it if your interested in selling it...
nige838 is offline Find More Posts by nige838
Old Sep 23, 2013, 04:35 PM
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
Quite common to happen when there is a polarity inversion.
What TX is that is it the 400mW? I only have the 500mW and 200mW to check the parts.
IceWind is offline Find More Posts by IceWind
Old Sep 23, 2013, 04:50 PM
wexter's Avatar
Joined May 2013
I have 400mW
Old Sep 23, 2013, 05:02 PM
Joined Aug 2013
So you put the cameras positive lead power supply in the transmitters video in? Camera red wire to transmitter yellow?
Old Sep 23, 2013, 11:29 PM
natscape's Avatar
Joined Sep 2012
I don't think the type of battery plug has anything to do with it as long as the polarity is correct.
Old Sep 24, 2013, 01:10 AM
wexter's Avatar
Joined May 2013
nono, camera red wire to transmitter yellow.
Old Sep 25, 2013, 11:06 AM
Joined Aug 2013
I'm confused, isn't that what I said? And on yours, you can still transmit, just not power anything? How did you test it. I'm afraid to hook anything up to this.
Old Apr 22, 2014, 07:51 AM
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
What part is it that was damaged? Find out the values of it and replace it.
boopidoo is online now Find More Posts by boopidoo
Old Oct 16, 2014, 10:32 PM
Joined Sep 2014
I also had one burn up like that, not sure what the problem is with these tx. I know I had it correctly wired as I have two others. Just more wasted money
ConcretePhil is offline Find More Posts by ConcretePhil
Old Oct 25, 2014, 09:19 AM
Joined Oct 2014
Hi there, I did wire my mobius to ts353 with an hobbyking osd ..
Did not check the polarity is reversed for the ts353 supply .. It did an electric spark as soon a I plugged the battery balance to the fat shark regulator ..
Then I soldered to swap the polarities .. but the ts353 don't seem to work properly : no red led on, the output of fatshark balancer is still 11.4 V ..
I'm kinda lost .. do anyone have a clue how to solve / repair this ?
ben749 is offline Find More Posts by ben749
For Sale Boscam 5.8G 2W 2000mW 12Ch FPV Wireless Audio Video Transmitter AV + RC305 Receiver uuustore1 FPV Equipment (FS/W) 3 May 20, 2014 07:15 AM
Discussion Boscam TS 353 transmitter: Sound but no video signal Aliquis FPV Talk 3 Feb 28, 2014 11:44 PM
Sold Boscam 5.8GHz 200mW Transmitters Mr.RC-CAM FPV Equipment (FS/W) 4 Jul 24, 2013 11:07 PM
Discussion Boscam 200mw transmitter, Need help identifying the wires on the 5 pin plug jasper7821 FPV Talk 5 Feb 22, 2013 10:41 PM
Discussion Video Transmitters Boscam TS35? 400mW vs Boscam TS352 500mW WhiteNite1971 FPV Talk 0 Jun 17, 2012 05:56 AM
