Old Aug 05, 2015, 11:35 AM
tonykof is offline
Find More Posts by tonykof
United States, MN, Williams
Joined Jul 2015
Need arm for a smartech servo - cross reference?
My servo arm cracked. Does anyone know what other brand arms would work on a Smartech servo? it has a splined plastic shaft. Thanks
[IMG][/IMG]
tonykof is offline Find More Posts by tonykof
Old Aug 05, 2015, 02:26 PM
CG Bob is offline
Find More Posts by CG Bob
KC8WPF
CG Bob's Avatar
Euclid, Ohio, United States
Joined Sep 2004
How many splines are on the shaft? Different brands of servos have different numbers of splines. Different size servos by the same maker may have different number of splines.
Futaba - 25 tooth is most common, also uses 15 and 21 tooth
Hitec - old standard was 24 tooth, new standard is 25 tooth, also uses 15 tooth
Do a search for "servo spline chart".
CG Bob is offline Find More Posts by CG Bob
Old Aug 05, 2015, 02:52 PM
tonykof is offline
Joined Jul 2015
Awesome, good to know.
thanks
Tony
Found servo arms and servos needed for 50cc/100cc mdtang Aircraft - General - Miscellaneous (FS/W) 9 Jan 02, 2014 09:05 AM
Discussion servo cross reference rcflyer165 Electric Plane Talk 2 Dec 17, 2012 08:20 PM
Discussion Need to cross reference Mabuchi motor jeff262 DIY Electronics 2 Sep 30, 2012 04:38 AM
Discussion What servos cross reference the HS-55 or HS-56 servos fonz316 Power Systems 4 Nov 08, 2008 05:38 AM
Looking for color cross reference between spray paint and covering Riserflier The Builders Workshop 0 Nov 30, 2004 05:18 PM
