Old Jan 16, 2016, 08:20 PM
2Doggs is online now
Find More Posts by 2Doggs
Ask Mike
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
The Turnigy 306G/KST115/215 is a great tail servo for a 450, and only small too. I'd say way better than a 9257.
2Doggs is online now Find More Posts by 2Doggs
Old Jan 16, 2016, 08:32 PM
dcb103 is online now
Find More Posts by dcb103
Dave
dcb103's Avatar
The Netherlands, NB, Breda
Joined Aug 2013
totally agree
dcb103 is online now Find More Posts by dcb103
Old Jan 17, 2016, 12:31 PM
peso is offline
Find More Posts by peso
Joined Apr 2004
A friend of mine has 500 FBL heli with tailwag that seems impossible to solve. Now he thought of using a separate 401 gyro for the tail and let the Kbar control the swach. Do you think that it is possible to do so?
peso is offline Find More Posts by peso
Old Jan 17, 2016, 01:17 PM
Ask Mike
2Doggs's Avatar
Joined Nov 2009
Possible, but unlikely to solve the problem.
If the wag doesn't respond to changes in gain, it suggests a mechanical problem.
If there is no binding under load (i.e. With the heli spooled up, not just static) I might suspect the tail servo.
Old Jan 17, 2016, 02:23 PM
Dave
dcb103's Avatar
Joined Aug 2013
he might try to loosen the screws in his tailblade holders by 1/4 i if then it is less your bearings bind under pressure
Old Jan 17, 2016, 05:41 PM
intelectual is offline
Find More Posts by intelectual
Joined Nov 2014
Should it be easy for me to move the tail link rod while the heli is spinning (without blades of course)? If i'm having a hard time moving it by hand, wont the servo be struggling too?
intelectual is offline Find More Posts by intelectual
Old Jan 17, 2016, 06:58 PM
Ask Mike
2Doggs's Avatar
Joined Nov 2009
It should be easy! As you move the rod either side of neutral, you should feel a progressive resistance - it should feel almost "elastic".
(if you add "Chinese weights", you can get it completely neutral, so that virtually no force is needed to move it.)
There are lots of things that can be wrong in a tail linkage to cause binding - so you need to go thru every part to find what's causing your problem.
Old Jan 18, 2016, 09:00 AM
yakky is offline
Find More Posts by yakky
Joined Mar 2015
None of my clone 9257's, including a Fitec 9357 lasted more than 50 - 100 flights. The motor burned out on all of them, starting with a small dead zone on the commutator which spreads till it quits. It gives a very waggy tail on the way to complete failure.
What settings were you using with them?
yakky is offline Find More Posts by yakky
Old Jan 18, 2016, 10:00 AM
Ask Mike
2Doggs's Avatar
Joined Nov 2009
4.8v, 333Hz, even tried 250Hz. Most of them claim to be able to run 6v, but the original Futaba 9257 was strictly 4.8v only.
Old Jan 18, 2016, 08:43 PM
Dave778 is offline
Find More Posts by Dave778
United States, WA, Seattle
Joined Jun 2014
I also had 3 of those 9257 clone $10 tail servos, and all 3 failed with dead spot in the potentiometer or just died. 20-40 flights at 5V and 250 to 333Hz. (they were paired with the Futaba GY401, I can't remember the details of how I tried different frequency rates) I still have a couple genuine Futaba S9257s from about 6 years ago, one is still on a 450 of mine, perfect running at 5.5V with a YEP ESC.
Dave778 is offline Find More Posts by Dave778
Old Jan 25, 2016, 07:38 AM
johnzm is offline
Find More Posts by johnzm
United States, GA, Atlanta
Joined Sep 2014
can anyone give me a good place to look for starting out? I read the first post, and I've gone through the setup but I was looking for a good spot that had everything from description of the tuning parameters to best practices and known issues. is that available in one spot?
johnzm is offline Find More Posts by johnzm
Old Jan 25, 2016, 08:13 AM
Ask Mike
2Doggs's Avatar
Joined Nov 2009
You might check out the Mr Mel Vbar and Mini Vbar videos on Youtube.
For Sale Vintage Techi Models Mini Bar Fli pattern kit nero1156 Aircraft - Fuel - Airplanes (FS/W) 0 Feb 15, 2013 08:40 PM
For Sale Vintage Techi Models Mini Bar Fli pattern kit nero1156 Aircraft - Fuel - Airplanes (FS/W) 1 Jan 28, 2013 03:27 PM
Sold Mikado Mini V-Bar Pro with 2 DSMX satts. e-heliflyer Aircraft - Electric - Helis (FS/W) 0 Jan 16, 2013 05:11 PM
Sold Mini V-Bar "Blueline" 5.3 Pro xxrando Aircraft - Electric - Helis (FS/W) 0 Jan 02, 2013 10:36 AM
Sold Vintage Free Flight Midwest FU-BAR '36' 1/2A Kit NIB $45.00 FREE SHIPPING!! stevster Aircraft - Fuel - Airplanes (FS/W) 2 Jan 14, 2012 09:07 PM
