Old May 31, 2014, 09:52 PM
United States, KS, Topeka
Joined Jan 2010
Got it. Thanks Boa!
AutomanDan is offline Find More Posts by AutomanDan
Old Jun 05, 2014, 09:32 AM
United States, AZ, Tucson
Joined Apr 2012
I had to re-glue my elevon servo. This flight only used 105mA.
$Tree Bug (4 min 10 sec)
boa2110 is offline Find More Posts by boa2110
Old Jun 08, 2014, 12:40 PM
Joined Jan 2010
Battery Mount
Thought I would post my updated battery mount for anyone looking for something a little different. I don't know if this method has been used before but, figured it would be worth a try.
My original mount used low profile Velcro and while it secured the battery very well, it made removal somewhat awkward and time consuming since it stuck so well.
So, I decided to try the elastic band approach. I gently stretched a 1" wide piece around a 300 mah battery and glued it at the overlap. I then removed the battery and stuck the elastic band to a piece of adhesive backed Velcro. Last step was to mate this Velcro/elastic band assembly to the existing Velcro already on the fuse. (Note: the Velcro could probably be eliminated completely).
I've got several flights on this now and the battery stays locked in - even during hard 3D maneuvers. Switching batteries is now quick and easy.
Old Jun 09, 2014, 09:35 AM
Joined Apr 2012
I stopped using Velcro now I prefer to just slide the battery into a hole in the fuse.
Old Jun 09, 2014, 12:17 PM
Joined Jan 2010
Boa - does the hole ever become enlarged over time and result in a lose fit? I experienced this on one of my first foamies.
Old Jun 09, 2014, 01:07 PM
Joined Apr 2012
I just use some scrap foam to shim the battery in if the hole gets bigger or if I use a smaller battery. This also allows lateral CG to be adjusted.
Old Jul 04, 2014, 09:11 AM
Joined Apr 2012
I put on a different motor with a 6030 prop. Less power but nice and quiet.
$Tree Bug (3 min 17 sec)
I noticed there is less torque effect with the smaller prop.
Old Jul 05, 2014, 05:50 PM
a little kid at heart
poulsbobill's Avatar
Poulsbo, Wa
Joined Sep 2004
Any dimensions on this thing if i want to make my own? Or a plan?
Bill
poulsbobill is online now Find More Posts by poulsbobill
Old Jul 05, 2014, 06:56 PM
Joined Apr 2012
I was able to fit the plane on one sheet of Dollar Tree foam (20X30). Don't think the dimensions are that critical.
Old Jul 07, 2014, 09:04 PM
Poulsbo, Wa
Joined Sep 2004
Do you have some rough dimensions to get me started.
Bill
Old Jul 07, 2014, 11:10 PM
Joined Apr 2012
Here are some measurements that I based on the 20"X30" Dollartree foam board.
Old Jul 08, 2014, 03:12 PM
Poulsbo, Wa
Joined Sep 2004
Thank you!! Thats what i needed. One last. Where is your cg at? How many inches back?
Bill
Old Jul 08, 2014, 03:37 PM
Joined Apr 2012
3" is a good starting point for CG.
Sold Lightflite BUG ready to fly. Back up for sale. 1987tc Aircraft - Electric - Airplanes (FS/W) 14 Jun 30, 2007 10:34 PM
Sold Lightflite Bug ready to fly! $135.00 Shipped with 2 lipos. 1987tc Aircraft - Electric - Airplanes (FS/W) 12 May 04, 2007 02:54 PM
Discussion Lightflite Bug "heavy duty" landing gear. Scott_S. Foamies (Kits) 11 Apr 18, 2007 01:09 PM
Discussion Plane Review: The Lightflite Bug CitaFly Electric Plane Talk 1 Apr 11, 2007 09:25 AM
