Old Mar 04, 2014, 11:22 AM
Joined Feb 2014
Question
Must-have components for first Hubsan X4 purchase
Hello,
I am planning to buy a Hubsan X4 H107C, with its HD camera.
Reading this forum, I have made a list of the items I am prepared to order along with the quad (this is my very first purchase!).
As I will order from HK shop, I don't want to forget anything.
Please tell me whether this list is relevant, whether if I forgot anything, etc.
  • 1 x Hubsan X4 H107C 2MP Camera RTF
  • 1 x Spare Parts Body Shell
  • 2 x Spare Parts Blade Set
  • 1 x Protection Cover
  • 1 x Spare Parts Rubber Feet
  • 5 x 3.7V 500mAh Battery For Hubsan X4
  • 1 x iMAX B6 Digital RC Lipo NiMH battery Balance Charger
  • 1 x 12V 5A AC Power Adapter For iMAX B6 Charger
  • 1 x Hubsan X4 1-to-5 Balance Charging Cable For 3.7V Battery
LP
jameslp is offline Find More Posts by jameslp
Old Mar 04, 2014, 11:55 AM
United States, PA, Bethlehem
Joined Jan 2014
To save money and energy, just buy a crash set. Such as http://www.ebay.com/itm/like/360822300971?lpid=82
And I'd recommend a blade protector too, such as http://www.ebay.com/itm/like/191068967479?lpid=82
Without a protector.. you'll go through blades fast when learning.
Both are just examples.. you can find them online in numerous places. Probably cheaper and more reliable sales places too.
bschuler is offline Find More Posts by bschuler
Old Mar 04, 2014, 12:03 PM
Joined Dec 2012
My 2 cent.
The Body is not as important. You can always glue and still fly. Plus you can get them easily on Amazon and eBay from US sellers at a reasonable price.
Get some motors extra motors to have on hand. (remember like the props, there is CW and CCW)
The rubber feet stay on a lot better then the v252's, mine have never fallen off, so optional
I thought the recommended batteries were the UDI 380s because the 500's change the cg
Are you planning on moving up/adding to your fleet? maybe look at a devo tx too
ver2go is offline Find More Posts by ver2go
Old Mar 04, 2014, 12:05 PM
Joined Jan 2014
I'm with bschuler's recommendations. The prop guard is really great when fling indoors.
A battery changes in about 30min with the USB change cable that comes with the X4 so you may not need the IMAX etc.
The crash kit has spare motors which will be needed at some point.
Do you have tools: small Philips screw drive and soldering iron?
waltr is online now Find More Posts by waltr
Old Mar 05, 2014, 08:47 AM
Joined Feb 2014
Lots of great feedback, thanks a lot!
Blade protection was already in my initial list.
I'll look into motors indeed. But do you really need the soldering iron to plug them back upon replacement??
Re: batteries, I read that the 500mAh batteries work great with H107C, even if they don't exactly fit inside the body.
What do you mean by: "they change the cg"?
Old Mar 05, 2014, 09:02 AM
Joined Oct 2009
Cg center of gravity, but yes you will need a soldering iron
Jetboatftw is offline Find More Posts by Jetboatftw
Old Mar 05, 2014, 09:25 AM
Joined Jan 2014
Yes, replacing motors or LEDs requires soldering. Search YouTube for videos on doing this.
Old Mar 05, 2014, 10:58 AM
Joined Jan 2014
Soldering is a bit of a nightmare if you haven't done it before
Rubber feet mine have never come off either
Spare screws maybe
Prop Guard is must if Flying indoors
Got Spare body shell never had to use it
Micro CARD and USB Reader for video
Motors a must
Prop Removal tool
(some companies like BG include Protector and tool )
Most of all Get Flying and Enjoy. It will be the best 60 you will ever spend!
Droneguy is offline Find More Posts by Droneguy
Old Mar 05, 2014, 01:32 PM
Joined Feb 2014
Good inputs, thanks.
Well, I guess I'll have to get used to the soldering iron if I break a motor!
About the modified cg when using 500mAh battery, I suppose that I can use the tx trims to correct the balance, right?
About microSD card, what are the recommendations: maximum supported capacity? minimum class/speed? other?
Cheers!
LP
Old Mar 05, 2014, 01:55 PM
Joined Feb 2014
Ditto on the MicroSD question, would these be suitable?
Patriot 32GB Signature microSDHC Card Product Description
The Patriot LX Class 10 MicroSDHC flash memory cards offer blazing performance for mobile devices. The LX Class 10 MicroSDHC memory cards meet the latest SD Association specifications and provide a minimum sustained write speed of 10MB/s. Fast enough to record High Definition video, our LX Class 10 MicroSDHC cards keep up with the most demanding hardware. Patriot LX Class 10 MicroSDHC memory cards are available in 4GB, 8GB, 16GB and 32GB capacities and offer a 5 year warranty. Remove the bottleneck of slow memory. Capture every image or video without missing a moment. Depend on the Patriot LX Class 10 SDHC card.
Features
High level of copy protection
Write protection switch to avoid accidental data deletion
SD Adapter included
5 Year Manufacturer Warranty
Specification
Capacity: 32GB
Class: 10
Voltage: 2.7 - 3.6V
Operating Temperature: -25C to 85C
Storage Temperature: -40 to 85C
D_an_W is online now Find More Posts by D_an_W
Old Mar 06, 2014, 12:17 PM
Joined Feb 2014
Same question: would this Lexar 16GB Class 10 work?
http://www.amazon.com/Lexar-High-Per.../dp/B00BQ5UWXI
LP
Old Mar 06, 2014, 07:37 PM
Joined Dec 2012
Originally Posted by ver2go View Post
My 2 cent.
Aren't these DC motors? Couldn't the polarity be reversed?
As for things you need, I bought the 107L a month or so ago, bought extra props and batteries. Put a prop protector on and they have been fine since. I have 3 brand new sets for the outdoors when the snow melts.
I have broken my body and I need to replace it. Motors have been great and haven't had any fail yet, and have I would guess well over 30+ flights into them.
calde043 is offline Find More Posts by calde043
Old Mar 06, 2014, 09:23 PM
United States, MD, Stevensville
Joined Jun 2013
Reversing the motors will likely make them fail sooner than later as the brushed are made for specific rotations.
Waterbound is online now Find More Posts by Waterbound
Old Mar 06, 2014, 09:27 PM
Joined Jun 2013
LP
Any micro sd will work, the class 10 is overkill IMO. The processor on these micro cameras most likely won't see any benefit over class 4 or 6. I may be wrong with this specific camera but highly doubtful. That said, avoid cheap made SDs that could result in corrupted files etc., but super high speed micro SDs are not necessary to get the results you want.
Old Mar 07, 2014, 08:11 AM
Joined Jan 2014
I'm sure the brush to commuter timing is different for the CW verse CCW motors. If you reversed the motor leads, to reverse the rotation, I'll bet you will not see the RPM or power required to fly from that motor.
Has anyone tested this?
Discussion Dealer list for Hubsan X4 Family (H107/H107L/H107C/H107D) and spareparts! bangkomit Mini Multirotors 461 Apr 05, 2014 03:01 AM
For Sale HS-65MG BNINB x 4 + a lot of quality components!!!! MUST SEE! XstarWake Non R/C Items (FS/W) 1 Dec 23, 2013 01:37 PM
Discussion brightest leds for hubsan x4 AnthonysQuad Mini Multirotors 20 Apr 29, 2013 02:01 PM
Discussion Hubsan X4 H107 Quadcopter spare parts for sale (Singapore only) ric2sin Singapore 0 Dec 24, 2012 03:30 AM
Discussion Must have tools "First Aid kit" for RC newbies EarthDog Beginner Training Area (Aircraft-Electric) 20 Apr 01, 2010 09:13 AM
