Old May 15, 2013, 03:18 PM
Vik_'s Avatar
Prague CZ
Joined May 2010
Hi All
Thank you for interest.
I thing I do have most of the dremel work done
Last thing I need to do on the wings are servo mounts and retcracts t-nuts installation.
So one motivation shot
And as we will have to move to new apartment within a month I have no idea how long I would be able to work on Anton
Vik_ is offline Find More Posts by Vik_
Old May 18, 2013, 01:54 PM
Vik_'s Avatar
Prague CZ
Joined May 2010
Hi All
Small update today
Finished servo mounts today on one wing.
They are made from L shape dural and servos are attached by 2,5mm screws
Now repeat same procedure on the second wing
Old May 20, 2013, 09:50 AM
so. cal.
Joined Jan 2006
Vik, can you show the bottom of the wing mounted to the fuselage in close up? Just curious how it all fits together.
s2000 is offline Find More Posts by s2000
Old May 20, 2013, 02:32 PM
Vik_'s Avatar
Prague CZ
Joined May 2010
Hi All
The motor mount had arrived
S2000 - sure will try to do it tommorow
Old May 26, 2013, 11:05 AM
Vik_'s Avatar
Prague CZ
Joined May 2010
Hi All
A Hysol madness today
Most formers in the fuse are glued as well as firewall.
And retracts are installed with help of t-nuts and blind nuts.
Old May 26, 2013, 07:29 PM
Ldm
Ldm's Avatar
United States, PA, Conestoga
Joined Jun 2006
Nice Job !!!
Ldm is offline Find More Posts by Ldm
Old May 27, 2013, 03:10 PM
Vik_'s Avatar
Prague CZ
Joined May 2010
Thank you LDM
This kit is not cheap, but worth it really easy to work on. Most of the parts need only minor trimming etc. If I will use the recommended retracts it will be even easier.
Just few minutes today and the motor is mounted on the firewall. The cooling fan is such cool thing.
And the ESC come as well over. I thought the HK YEP may worth a try. It is interesting how close it look as the YGE
Old May 27, 2013, 08:09 PM
Ldm
Ldm's Avatar
Joined Jun 2006
Hi Vic , '
Yes agreed that fan blade is sweet , I did not know it would work with the eletric motor !!.
Dont know if your planning on a sliding canopy or not , I did one in my CMP Fw190 (its in my blog ) and it was done the old fashion way . Now with the new Figelli linear servos , it would be snap to make your canopy slide . They are about $70 bucks but its 100% plug and play , nothing else needed to get it to work .
Cant wait to see this project progress , your giving us all a new education in Giant Scale E-flight
Old Mar 26, 2014, 07:50 PM
low, left, & fast
nuts-n-volts's Avatar
Albuquerque, New Mexico
Joined Dec 2004
Vic, any more updates on your Fw? I'd like to see how it's coming and what your AUW is gonna be. How does the Sist compare to others weight-wise?
nuts-n-volts is offline Find More Posts by nuts-n-volts
Old Mar 29, 2014, 02:33 PM
Vik_'s Avatar
Prague CZ
Joined May 2010
Hi,
Well I shall have some update soon. But not too much.
With my wife we bought a flat which needed lot of work. Now I'm finishing a workshop (tad smaller that the old one. But I'm happy to have one).
Next week I hope to finish rudder and elevators from balsa covered with solartex.
Now I'm considering two things:
- originally I planned single servo for elevator which would be permanently glued on the fuselage. But due to the limits of my new storage an detachable elevators would be much better. But two 5085MGs in the back will bring me weight penalty up front.
- battery size. 12S 5000mAh or to go big with 12S 8000mAh
I need to get rest of the plane from the storage after I will come back from a business trip...
Regards
Vik
Old Mar 30, 2014, 08:57 AM
low, left, & fast
Joined Dec 2004
Ah, no wonder we had't heard from you. Well, I sincerely hope your new digs will accommodate a nice enough shop to finish your Wulfs. They both are looking grand!
Old Apr 07, 2014, 03:12 PM
Vik_'s Avatar
Prague CZ
Joined May 2010
Hi All,
I finally have done something on my Fw
The elevators are ready for covering and the rudder needs just touch up sanding
Without the covering I'm roughly on 1/3 weight if I will compare to the kit items. With bit Solartex it looks like I will be on 1/2
Old Apr 13, 2014, 02:59 PM
Vik_'s Avatar
Prague CZ
Joined May 2010
Hallo All,
I do have some update on the build.
The hinges for the gun hood are done and it will be great access door for the batteries
I wanted to drill the bolt holes in the wing and fuse, but lets say my workshop is bit tight for this size of the plane.
And I played bit with the Hysol
Can't wait to see it in the air
Old Apr 14, 2014, 01:04 AM
Vik_'s Avatar
Prague CZ
Joined May 2010
Hi All,
I do have a question. The 2,4GHz receiver mounting. Basically all fuselage front is done with CF.
Only the gun hood is from fiberglass. Do you thing mounting receiver there will be sufficient for signal strength?
Question II. NanoTech batteries? Are they ok? I red that they like to puff...
So far I had mostly Zippy and they are ok.
This is how the Sierra tailwheel looks:
Old Apr 15, 2014, 08:41 AM
low, left, & fast
Joined Dec 2004
Vik, Pretty much all batteries will puff if you get on them too hard. Try to get as high a C rating as you can afford and don't fly past 75% as a general rule. Nanos are pretty good. I've used them in big warbirds and jets. Everyone will have a favorite.
Sold Holman 1/5th scale FW190A kit demire Aircraft - Fuel - Airplanes (FS/W) 5 Jul 19, 2012 07:24 PM
For Sale Glennis 5" FW190A wheels demire Aircraft - Fuel - Airplanes (FS/W) 0 Mar 04, 2011 11:47 AM
For Sale Vailly FW190A 1/4.5 kit partially built. demire Aircraft - Fuel - Airplanes (FS/W) 1 Jan 01, 2011 05:19 PM
Wanted Sist 1/5 FW190 A8 scale wheels and spinner w/ fan invertmast Aircraft - Fuel - Airplanes (FS/W) 0 Nov 30, 2010 12:34 PM
For Sale Pro Built 1/48 Fw190a-6 Checkerboard Nose ASAMech Non R/C Items (FS/W) 0 Sep 30, 2008 07:03 AM
