Old Jul 22, 2014, 05:46 PM
guyfawkes's Avatar
United Kingdom, England, Cheltenham
Joined Oct 2013
Minim OSD RSSI
Hi
Does anyone know the way to get RSSI on the minim OSD V1.1 (from hobbyking)
I have an APM 2.6 which I was hoping to use to get RSSI on the OSD from, but so far I can only see that people solder the RSSI wire to the processor with a 1kOhm resistor.
Is that the only way to do it or can I get the APM to give rssi to the OSD somehow?
Also how hard is it to solder to the processor ?
Thank you very much.
guyfawkes is offline Find More Posts by guyfawkes
Old Jul 22, 2014, 08:07 PM
Certified Power Juicer
Jack_LaLanne's Avatar
Joined Feb 2009
http://copter.ardupilot.com/wiki/com...th-indication/
You need to connect rssi signal and ground to the corresponding pins of one of the ports designated Analog. It is very easy to solder these. A capacitor is only needed for digital RSSIs because of their pulsed nature if I got it right. Software wise you will write a parameter that defines which analog pin has the rssi.
Jack_LaLanne is offline Find More Posts by Jack_LaLanne
Latest blog entry: Easy Glider DIY FPV canopy
Old Jul 23, 2014, 03:37 AM
guyfawkes's Avatar
Joined Oct 2013
Thank you very much that's so much more convenient, I have an openlrs receiver which gives out RSSI hoping that doesn't have pulsed output?
Discussion Quest For RSSI on my Arkbird OSD FalconFPV FPV Equipment 1 Apr 05, 2014 05:48 PM
Help! Minim OSD v1.1 advice for a noob :) nafan08 Multirotor Electronics 7 Jan 08, 2014 05:43 PM
Discussion Noob question ET OSD,Elogger,GPS,RSSI,RTH. keithsuth Eagle Tree Systems 2 Oct 29, 2013 07:45 AM
Help! Minim OSD Multiwii locks or hangs KVteam HELP! Depron Dave FPV Equipment 1 Oct 25, 2013 11:05 AM
Sold Mavlink 1.0 and Minim 1.1 OSD crtek Aircraft - Electric - Multirotor (FS/W) 0 Oct 04, 2013 02:38 PM
