Old Aug 12, 2014, 06:25 AM
Joined May 2014
retractable vtx omni antenna
hi guys... just a little thing i made that greatly improved the video on my x8 wing covered with ultracote chrome
arnauddecotter is offline Find More Posts by arnauddecotter
Old Aug 12, 2014, 03:31 PM
Project Tormentor is flying!
United States, WA, White Salmon
Joined Nov 2005
Why and when would you retract it?
philthyy is offline Find More Posts by philthyy
Old Aug 12, 2014, 06:56 PM
Joined May 2014
I would retract it for landing.. it will come out as soon as I lauch the plane. The antenna is pointing vertical down when extracted.. because it is at the bottom of the plane. Instead on top of it. You get always clear line of sight signal from it. There is no shadowing the signal by the fuselage
Old Aug 13, 2014, 09:30 AM
peter.braswell's Avatar
United States, VA, Chesterfield
Joined Apr 2008
That's cool. Wouldn't think you'd get much shadowing passing vtx through foam though. Where you having issues? Has this improved your range any?
-p
peter.braswell is offline Find More Posts by peter.braswell
Old Aug 16, 2014, 05:46 PM
cadders's Avatar
Joined Jul 2004
I'm just about to do the same thing on my ES*. I just opened a thread over on FPVLab and someone kindly directed me here.
Flying out 8km+ is no problem at all...it's just when you turn 180 deg to come back the motor, camera, battery etc blocks a clear LOS for antenna.
How do you find it works?
Cadders
cadders is offline Find More Posts by cadders
Old Aug 18, 2014, 08:51 AM
Canada, ON, Mississauga
Joined Apr 2006
tried wingtip mount? there shouldn't be much block from there
modelerchina is offline Find More Posts by modelerchina
Old Aug 20, 2014, 04:51 AM
Joined May 2014
it made a massive difference,, because the antena is directly mounted to the vtx, thus reducing any rf loss from the cable if mounted on the wing,, yes the signal goes through foam,, but not through all the stuff in the canopy,,motor,, battery.esc,,etc etc, having it under the plane at its centerline.. keeps it direct los to ur vrx, as long as you dont turn to tight.. a longer antenna would be even better.... just make sure u retract it back on landing... btw the X8 is just a awesome plane.. so much space and so stable..
Wanted 1 X 5.8 ghz circular polarized antenna for vTx (Omni directional) nesal FPV Equipment (FS/W) 1 May 31, 2014 12:54 PM
Discussion Opinions please: Same frequency - Larger vs Smaller omni antenna theroots123 FPV Talk 2 Nov 14, 2013 01:27 PM
Sold ImmersionRC 600mW 5.8 GHz Transmitter V2 & 5.8 GHz SpiroNET Omni SMA Antenna Set Chad2323 FPV Equipment (FS/W) 5 Nov 12, 2013 04:03 PM
Found 5.8ghz fatshark/immersion SpiroNET Omni transmitter antenna 3d astronaut FPV Equipment (FS/W) 4 Nov 01, 2013 12:30 AM
Discussion Changing vTx omni orientation in flight? JIMOOO FPV Talk 0 May 01, 2009 08:05 PM
