Old Mar 15, 2004, 02:46 PM
Joined Feb 2004
Transmitter Battery
I am looking for a Futaba transmitter battery (NT8LP ) and reciever battery (?) to replace old one in an old futaba conquest radio. I would appreciate any input as to the most reasonable place to buy.
TNX Chad
Chad Hazel is offline Find More Posts by Chad Hazel
Old Aug 10, 2014, 07:17 PM
Joined Jun 2013
Futaba NT8LP for a FP-T7UAF or similar, has no replacement battery according to Futaba or tech. serv. But they're WRONG !
a NT8iB works Great. You need to put a female Futaba "J" plug on the transmitter power cable. And That's All ! It "Fits" the battery compartment, it's a 9.6v , 600mAh nicad. Use the same "factory charger" and "times" ! I did a quick charge it, it ran for 45min. before the
"low bat" chirped. Then I did the full 15hr slow charge, and got 8hr 20min run time. Anyone need more ?
Check out this link for replacement connectors:
http://www.allerc.com/advanced_searc...+plug&x=14&y=9
Rlyons is offline Find More Posts by Rlyons
Old Aug 11, 2014, 12:14 PM
United States, WA, Woodinville
Joined May 2014
Well they're not wrong, the battery won't work without a modification. Sure it's dead simple to change the connector but it's still true that there (apparently) isn't a turnkey replacement available.
James_S is offline Find More Posts by James_S
Old Aug 11, 2014, 04:47 PM
Zeeb's Avatar
United States, UT, Highland
Joined Jun 2006
This gentleman will make you a pack for your radio as will a number of other vendors but I've had really good experiences with NoBS.
http://www.hangtimes.com/txpacks.html
Zeeb is offline Find More Posts by Zeeb
Old Aug 20, 2014, 09:02 AM
Joined Jun 2013
If you want "turn key", Batteries plus will rebuild one for you, if you take your old core in.
Turn Key ? Are you really that limited ?
Try a battery pack that uses "AA" batteries
http://www3.towerhobbies.com/cgi-bin...?&I=LXH351&P=7
Old Aug 20, 2014, 11:12 PM
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
You guys do realize that the OP of this thread is >10 years old, right?
mw
Mark Wood is offline Find More Posts by Mark Wood
Transmitter Battery Pack Connector? rtucker Radios 6 Jan 08, 2008 07:02 AM
Hitec transmitter battery problem? ScottsdaleFlyer Parkflyers 10 Sep 06, 2002 10:21 PM
Making A Transmitter Battery Pack? putt_13 Electric Plane Talk 0 Sep 02, 2002 04:01 PM
Transmitter battery bypass tony houk Electric Plane Talk 3 May 27, 2001 03:59 PM
