Old Sep 18, 2014, 09:00 AM
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Originally Posted by FloBau View Post
I did notice the problem with the HS5070MH on the rudder as well, but it does fit without any changes. To be honest I don't know how I did it, because at first it didn't want to enter at all. I just screwed the servo with force in and it fits perfectly now.
I can't imagine how you got it to fit. Can you post a picture of it?
Which spinner do you use?
Extreme Flight 52mm.
Doc Austin is offline Find More Posts by Doc Austin
Old Sep 18, 2014, 04:16 PM
FloBau's Avatar
Germany, BW, Weinheim
Joined Sep 2012
I really just pushed the servo in. Here are the pictures attached of the rudder and the elevator.
Mine is nearly finsihed, but did you adjust the motor opening in the cowl?
The motor hasn't that much space, at least my hacker motor A30 14L hasn't.
The elevator deflections are incredible. I have to adjust the down ellevator ar it will hit istelf.
FloBau is offline Find More Posts by FloBau
Old Sep 19, 2014, 02:16 AM
FloBau's Avatar
Joined Sep 2012
The cowl doesn't leave much space for the motor.
Did you cut out the cowling a bit?
Old Sep 19, 2014, 08:03 AM
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
I generally don't, but on this one I wanted to run the bigger prop and needed more cooling, so I opened the hole a little with a Dremel sanding drum.
Old Sep 23, 2014, 07:56 AM
FloBau's Avatar
Joined Sep 2012
I finished my yak, now I just need a spinner, a receiver and the Cortex and I'm ready to go.
Old Sep 24, 2014, 08:29 AM
FloBau's Avatar
Joined Sep 2012
About the spinner:
Do you know the measurements of the drilled hole in the aluminum backplate?
I ordered a Aeronaut 51mm spinner now, which has a 7 mm drilled hole with spacers.
This is not perfect as the motor shaft is only 6 mm.
Old Sep 24, 2014, 08:36 AM
Joined Nov 2013
nice pix
louay is offline Find More Posts by louay
Old Sep 24, 2014, 05:20 PM
Honeybadger don't care...
Luv3d's Avatar
Orlando, FL
Joined May 2010
Flew my newly-acquired Yak- it's a honey! very smooth, clean lines. Found a great CG spot I like and now I'm just doing some KE coupling trimming for it. It flies beautifully and looks so nice. I really enjoy this airframe!
Luv3d is online now Find More Posts by Luv3d
Old Sep 25, 2014, 05:59 PM
wkener2's Avatar
United States, GA, Lilburn
Joined Jul 2010
Luv3D,
Awesome, I love my 48" Yak. Taking her to E-Week this Saturday
Doesn't this plane just beg you to do rollers? Yet she still gets down for low and slow with the best of them
wkener2 is offline Find More Posts by wkener2
Old Sep 25, 2014, 08:02 PM
Luv3d's Avatar
Orlando, FL
Joined May 2010
I do love flying pattern with it, but I really have it set up to do XA. I'm flying mine on a 14x7 with a 685kv motor, 60A airboss ESC. it is really fun to toss around and rolls better than any plane I have owned.
Discussion Extreme Flight Yak-54 e-Profile 48" Malves 3D Flying 385 Jun 14, 2013 04:23 AM
Found Wanted: Extreme Flight Profile Yak 54 ARF. *Found* jbj620 Aircraft - Electric - Airplanes (FS/W) 4 Jan 16, 2013 10:56 AM
Found Extreme Flight 47" Yak or 48" Extra EXP 3DKid1995 Aircraft - Electric - Airplanes (FS/W) 7 Dec 27, 2009 09:34 AM
Wanted Extreme Flight 48" Yak-54 Electric Profile ARF Hitech1 Aircraft - Electric - Airplanes (FS/W) 2 Jun 24, 2009 02:42 PM
Sold 48" EXTREME FLIGHT YAK-54 PROFILE RTF, Now Just $250! dizzane Aircraft - Electric - Airplanes (FS/W) 3 Nov 16, 2008 04:42 PM
