Old Aug 26, 2014, 07:15 AM
United States, AR, Jacksonville
Joined Jul 2004
From what you guys have said, and after looking at the stock image for that connector I think I'm getting it.
I think an update to the manual, adding the connection figures for channel 2, is in order. After all, this charger is advertised for 6-10S compatibility
Whiskey Whiskey is offline Find More Posts by Whiskey Whiskey
Old Aug 26, 2014, 09:47 AM
USA
Joined Jan 2002
They make a cable, but it doesn't look like it will fit your balance board. See CP10XP on the page at the link below:
http://www.revolectrix.com/SPA_XH.htm
Ohmic is offline Find More Posts by Ohmic
Old Aug 26, 2014, 10:33 AM
Joined Jul 2004
That board with the 10xP adapter cable would work for what I've been asking, but I failed to leave out some details. I'm building a portable charge box with my chargers mounted in the lid, power supply mounted below a deck in the bottom and with my parallel board hard mounted to that lower deck. My ultimate goal is convenience and tidiness. The two gripes I've had for my 10S and 10XP chargers are having to deal with FMA's uniqueness in balancing plug configurations and the mess of plug adapters I have to swap through (optional side-mounting balance plug modules anyone?).
My construction of the adapter cable is on hold until I configure the box so I can build the cable to the perfect length.
Old Aug 26, 2014, 11:06 AM
USA
Joined Jan 2002
Sounds a lot like my configuration. The JST-PA connector on the charger is really a non-issue. You just need the correct cable to go from the charger to the balance board.
Although I wouldn't recommend it, I believe you could plug the balance board you have into the single port SPA.
I'm using the the single port SPA adapters and will likely order a few more.
My issue is I have some older packs that don't use the XH connectors. I plan to use other balance boards to connect to the single port SPA adapters so I don't have to switch the charger between XH mode and FMA mode. I've done it and it works fine, but I'm trying to streamline and reduce the number of steps required for charging different pack types.
Also, Revolectrix does make balance extensions in 12" and 36" lengths. I'm using the 12" extensions myself.
Old Sep 26, 2014, 07:21 PM
Joined May 2010
Hello, I have a Cellpro 10S and have been thinking about an upgrade to the 10XP next spring. I really like the size of these models; they fit on the desk nicely. I'm essentially asking the question now so I can save your reply for future easy "add to cart" purchasing.
The upgrade to the 10XP would be so that I can charge 4 3S or 4S batteries at once; which is something that the 10S can't do. Could someone post what accessories I'd need for the 10XP in order to do this? i.e. for the 10S I have 3x CP10S-GP/KO6S adapters; that's two in use and one spare. All balance plugs I have are the typical JST-XH. From reading here I need an MPA at a minimum and an SPA (or two?) perhaps. I am not sure if I can re-use my current adapter boards. I'll be keeping the 10S as a backup because my other charger is really small by comparison to this.
Thanks!
Krusher_r is offline Find More Posts by Krusher_r
Old Sep 27, 2014, 12:35 AM
Joined May 2010
It's been some time that I've been on the Revolectrix web site, and I see they offer combos with the MPA and cables. So, please disregard the above question because you can simply pick the combo you need for the 10XP, 6, and 8 models. I'll be watching the black Friday sales to see what comes up.
Old Sep 27, 2014, 04:31 AM
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Thanks!
You could increase the capability of your 10S by getting the MPA and appropriate cable now. The MPA will work as well with the 10S as it does with the 10XP.
http://www.usastore.revolectrix.com/Products_2/MPA_2
PN: MPA-XH-US
PN: MPA-FRC-CP10XP-US
You won't have the power that the 10XP has but you could do multiple batteries although not quite as fast as the 10XP. You can then upgrade to the 10XP later on.
Keep your existing adapters. You will still be able to use them with either the 10S or the 10XP.
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Sep 27, 2014, 06:39 AM
USA
Joined Jan 2002
The combos are a great way to get everything you need in a discounted package.
No need to wait for the black Friday sales, you can use Revolectrix coupon code bisb14 and get 10% off your order today when ordering from the Revolectrix.com website.
Old Yesterday, 09:55 AM
What Goes Up...Must Come Down
abjets's Avatar
United States, NC, Oak Island
Joined Jan 2013
Anyone have the current firmware version for the 10XP...I am showing V1.19 on mine. Haven't had any issues with my 10XP for over three years now, hence if it ain't broke...don't fix it.
BUT curious if there might be any updates...
Thanks!
abjets is offline Find More Posts by abjets
Latest blog entry: SA F-18 50MM Build
Old Yesterday, 10:36 AM
USA, GA, Marietta
Joined Aug 2005
Thanks!
V1.19 is the current version.
Glen
Old Yesterday, 11:28 AM
abjets's Avatar
Joined Jan 2013
Glen
Thanks Glen! Much appreciated!
Adam
Discussion FMA Cellpro 10XP Charger alexf1852 Batteries and Chargers 77 Feb 13, 2014 08:20 AM
New Product Introducing the Scirocco--All Molded, All Carbon Pitcheron Ward Hagaman Slope 174 Nov 16, 2012 08:40 AM
Sold Cellpro 4s Lipo & A123 Charger apex Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jul 02, 2011 09:49 PM
Found all around charger wanted / trade for Cellpro 4S +++ jazzster Aircraft - Electric - Batteries & Chargers (FS/W) 4 Mar 21, 2008 05:55 PM
New Product Introducing the all new Brushless Sensorless Motor Controllers for cars and boats jackson_f Product Announcements 3 Jan 12, 2007 03:13 AM
