View Poll Results: Which type of combat do you prefer?
One design (same plane shape/size) with common and battery) 1 4.35%
Similiar planes (Kens single motor combat planes) and common motor and battery. 14 60.87%
No limits except battery size (900 mAh 2S) 3 13.04%
Anything that flies....no limits 5 21.74%
Voters: 23. You may not vote on this poll
Old Yesterday, 08:37 AM
treefinder
springer's Avatar
SE MI
Priorities.........
springer is offline Find More Posts by springer
Latest blog entry: OneSheeter#17 OSC140 debut
Old Yesterday, 09:39 AM
abieex's Avatar
United States, OH, Cuyahoga Falls
Joined Oct 2011
Can anybody tell me if bows or warps can be removed from MPF with an iron? Building a couple of Kens' Zeros and some of my foam is a bit wonky!
abieex is online now Find More Posts by abieex
Old Yesterday, 10:35 AM
treefinder
springer's Avatar
SE MI
I have had limited success trying to flatten foam. The best i heard was gpw's method. He put the foam on a flat surface, under a glass plate and sat outside in the Louisiana sun. Tough to do in a MI/OH winter! If the un-flatness is in pieces to be laminated, then just go ahead and laminate them, using weights or clamps to keep everything flat. The waves will be gone. If it is on a wing or tail, you can try an iron (i haven't yet) or heat gun. It is tricky to overbend just the right amount, but i have done it.
Old Yesterday, 10:39 AM
abieex's Avatar
Joined Oct 2011
Thanks Springer, I also have an idea or two so I'll just wing it (no pun intended) on this one. Grateful for your response and I hope the cold winter finds all you folks of SEMFF well. Steve
Old Yesterday, 12:29 PM
Slipping the Surly Bonds
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Between a couple of pieces of glass in the oven for 10 minutes at 200 degrees F will do the job.
Ken
dz1sfb is offline Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Flyers in SE Michigan Fungoo Electric Plane Talk 18 Aug 15, 2014 01:14 PM
E-flyer clubs in SE Michigan? LBM Electric Plane Talk 8 Dec 17, 2008 06:31 AM
Yippee! Any Foamy Flyers On Or Near Elizabeth City, N.c??? nieves50 Foamies (Kits) 31 Mar 06, 2004 09:11 PM
Flint, Michigan E-Flyers ??? crashnburn Electric Plane Talk 21 Dec 04, 2001 05:54 PM
Slope sites SE Michigan or NW Ohio? daveh Electric Sailplanes 4 Jul 27, 2001 07:37 PM
