Old Oct 05, 2014, 05:34 AM
RFJ
RFJ's Avatar
Northern Ireland
Joined Dec 2004
Build Log
Fred Dunn 75% Astro Hog for AMPLAN Build Off
Although I can't begin the actual build until next month I though I would start a thread anyway.
The Astro Hog was first flown in late 1957 and is essentially a low wing version of the Smog Hog. Apart from the ailerons and tips the wings are identical. The nose is slightly longer but the moment arm is the same. Tailplane has a slightly greater aspect ratio.
Bob Dunham's Astro Hog won the 1958 and 1959 US Nats.
Ray
RFJ is offline Find More Posts by RFJ
Old Oct 05, 2014, 05:46 AM
Paul_BB's Avatar
France, IdF, Lagny-sur-Marne
Joined Feb 2007
Good luck Ray!
-Paul
Paul_BB is offline Find More Posts by Paul_BB
Old Oct 05, 2014, 05:55 AM
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
Should be a cracker Ray.
Sundancer is offline Find More Posts by Sundancer
Old Oct 05, 2014, 06:24 AM
Warren B's Avatar
Mt Evelyn, Melbourne, OZ
Joined Dec 2008
I'm still intending to do a 100% version starting in a month or two
..... But I think there is room in two hemisphere's enough for both of us!
Are you making any changes Ray?
I note the positive incidence on both wing and tail (I think, bye eyeball).
I guess this is roughly equivalent to a bit more down thrust.
I'm planning to use all the interesting hinge details too.
Not sure about all the rubber bands, they look nice and vintage, but bolts aremoreconvenient.
Warren B is offline Find More Posts by Warren B
Old Oct 05, 2014, 10:25 AM
RFJ
RFJ's Avatar
Northern Ireland
Joined Dec 2004
Warren,
The more the merrier - good luck with your "real" version and I look forward to the build log.
As you say the plan shows positive wing and tailplane incidence and no downthrust. I have changed this to zero tailplane incidence, about 1 degree positive on the wing and a couple of degrees of downthrust. This can affect the "sit" of the model in the air slightly but is easier to build accurately and is well proven.
The "interesting" hinge details will also have to go - too much work I will hinge the rudder conventionally and fit my usual center hinged ailerons.
I also don't care much for rubber bands. They were necessary on the Smog Hog as the front cabin dowels are such a prominent feature. Less so on the Astro Hog so I will use a front tongue and a rear bolt on the wing. The tailplane will be permanently glued on and the hatch held by magnets - no rubber bands anywhere.
As you can tell I'm not a purist in these matters - if I don't like something I will change it provided it does not alter the character of the original model too much. Basically the outline is sacrosanct but everything else is open to offers
Ray
Old Oct 06, 2014, 05:02 AM
United Kingdom, England, Richmond
Joined Apr 2011
Are you going to keep the original dihedral Ray? Personally I hate to see Astro Hogs with reduced dihedral as it is such an important part of the plane's character.
ukengineman is offline Find More Posts by ukengineman
Old Oct 06, 2014, 07:33 AM
RFJ
RFJ's Avatar
Northern Ireland
Joined Dec 2004
A very good question Alan
I had a bit of a dilemma with this. The original dihedral is 7 degrees per side which frankly looks ridiculous to me but, as you say, is a big factor in the design's character. Modern thinking would have this at about 1 degree per side just to avoid the droopy wing illusion but that would certainly destroy the distinctive Astro Hog look.
So for me a compromise is necessary. I settled on 5 degrees per side which still looks "too much" but is the maximum I can live with. Sorry to all you purists out there
Warren - perhaps, just to be different, you might fancy a Dunham Astro Hog as shown below. Note in particular his changes to the longitudinal dihedral.
Ray
Old Oct 06, 2014, 08:01 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
I appreciate your dilemma on the dihedral Ray, and for what it's worth I think you have arrived at a most reasonable compromise which should preserve the Astro Hog look whilst not looking excessive.
Old Oct 06, 2014, 04:57 PM
pd1
United States, MA, Haverhill
Joined Jun 2006
Ray I love the idea of a 70% Astro Hog. I built a full sized Sig Hog last year and it's too big for my small workshop.
The Sig Hog has reduced dihedral, my plane looks fine but it doesn't look like an original Astro Hog without the dihedral.
If I build a 70% Hog, I will use the stock dihedral.
I did zero the wing and stab incidences, my plane flies fine set up that way.
This is my second Hog, the first was over 50 years ago, maybe next year a third.
I just got a kit of a contemporary of the Hog, the DeBolt Pursuit, it too has ridiculous dihedral.
Gotta love the old designs.
Paul
pd1 is offline Find More Posts by pd1
Old Oct 06, 2014, 05:58 PM
RFJ
RFJ's Avatar
Northern Ireland
Joined Dec 2004
Paul,
I started to build a Sig Astro Hog kit when they first came out but didn't have the heart to finish it - just too many changes. High set tailplane, strip ailerons, too little dihedral and even a tricycle undercarriage.
Being a Sig product the kit was superb and the guy I sold it to still has it today. I did keep the rather nice decal sheet and will probably use some of it on my small version.
....and quite right too. We should all build our models the way we want them
A very similar concept. Note "with built in inherent stability". Not exactly what you want in an aerobatic model - probably too much dihedral
Ray
Old Oct 07, 2014, 03:36 AM
Joined Apr 2011
Ray
I think I could live with 5 degrees per side
Alan
Old Oct 08, 2014, 01:29 PM
pd1
Joined Jun 2006
All the airplanes I've built seem to give the dihedral angle expressed in inches under the wing tip. So I've not gotten familiar with using degrees, I went and measured the dihedral angle of the Pursuit to see what it looked like.
The plans called for 5 1/2 inches under each wingtip and it measure to 10 degrees per panel.
Is that 10 degrees total or 20 degrees total?
I don't want to drag your thread off topic so I'll stop at that question.
Paul
Old Oct 08, 2014, 04:11 PM
Sundancer's Avatar
South-west France
Joined Sep 2007
Paul
It's normal when quoting dihedral in degrees to mean the amount on one panel, so in this case you would say "10 degrees". Which is a lot!
Old Oct 08, 2014, 06:31 PM
RFJ
RFJ's Avatar
Northern Ireland
Joined Dec 2004
Drag away Paul. Got to be more interesting than reading my ramblings
Yes it can be confusing when people don't stick to the convention described by George. I tend to write "X degrees each side" when talking about dihedral.
Degrees are a better measure than inches as they stay the same when you enlarge or reduce the size of the model.
The Smog Hog used 5 degrees each side, still a normal high wing R/E type model figure but I imagine than when these radical aileron equipped aerobatic low wingers were first being tried the designers were playing it very safe with the dihedral hence the excessive angles of 7 degrees each side (Astro Hog) and 10 degrees each side (Pursuit)
Experience soon showed that a low wing aerobatic model with ailerons performed much better with considerably smaller (even zero) dihedral angles.
I also like to see control surface deflections given in degrees but that's another story
Ray
Old Oct 09, 2014, 10:41 AM
pd1
Joined Jun 2006
I measured the dihedral of my Sig Astro Hog, it measured 10 degrees total or 5 degrees per panel. I like the plane but for a vintage Astro hog the wing seems a bit flat.
Now I'm in a quandary with the Pursuit, 10 degrees really looks funny and 5 looks a bit flat.
I think I'll wait until you show some progress and see how your Hog looks, I'm not looking for performance but a bit more for nostalgia.
Raising the stabilizer, We have always gone with the higher stabs do to having to fly off grass. The cut stalks of grass cut the underside covering of the low stabs quite often.
The high stab is less prone to damage.
Here's a couple pictures of my full sized Hog and a small jpeg of the Pursuit, check out the spar joiner.
You are right, I couldn't go with the tri cycle gear set up either.
Build Log Bill Winter's "Airknocker" for AMPLAN Build Off - finished and flown Sundancer Vintage & Old-Timer Designs 105 Oct 24, 2014 12:47 AM
Build Log Phil Kraft GIMLET, 1956 single-channel low-winger for AMPLAN Build Off JMP_blackfoot Vintage & Old-Timer Designs 33 Oct 23, 2014 03:32 PM
Build Log Walt Musciano's Classy Gassy for AMPLAN Build Off brokenspar Vintage & Old-Timer Designs 68 Oct 14, 2014 06:04 AM
Build Log Howard Bonner 75% Smog Hog for AMPLAN Build Off RFJ Vintage & Old-Timer Designs 67 Oct 12, 2014 05:57 AM
Discussion Ben Shereshaw 1937 "Champion" - AMPLAN Build Off September 2014 to March 2015 cpmcgraw Vintage & Old-Timer Designs 38 Oct 10, 2014 09:30 PM
