Old May 27, 2014, 07:27 AM
James not bond
jy0933's Avatar
Joined May 2012
Data
Airbot Micro Titan 2204 test result
Thanks to the friend over at Airbot(myairbot.com) sending these motor to me for testing. Interestingly they are quite good. I am not sure if they can beat T motor up. But I believe at least they are pretty much the best at their price.
The setup is pretty simple, vertical test stand on a digital scale. I personally do not like angled ones because it is difficult to get the moment right and the moment can cause very bad accuracy problem. But unfortunately, I only have 2 5" prop to test with. might just buy a few more to see how it works with others.
Close Look,
Good matte finish
Flat base and interesting thick semi hollow shaft
About 6 inches long of silicone motor wire
CF prop adapter
Thrust - Current test. (using fixed voltage lab power supply 8v and 12v)
in comparison with Sunnysky (lower current the better)
adding the 4s test
Thrust- efficient(g/W) Curve
test v log
https://www.youtube.com/playlist?lis...BJrf4hBX8J3x9V
Summary, comparing with sunnysky, this one is definitely much better made. The sunnysky heats up after a few mins of testing, but this one you can barely feel the heat. It might have to do with its height which is about 3mm higher than the other one. Also the flat base is quite interesting, I used to have problem that the shaft and eclip rub into motor mount or something else when it didn't line up. This one all you need is the right 16/19mm mounting holes and no more worries about lining up.
What is to improve, I think adding cw/ccw set will probably be a big bonus to it, especially people are getting more aware of tighting up the prop right way to prevent it from loosing.
It actually came in set of 5, I am planning to put it on a mini frame and see how many flight time i can squeeze from it. ( I got 10mins out of sunnysky with 5" prop, 3s2200 and a GoPro on it.)
jy0933 is offline Find More Posts by jy0933
Old May 27, 2014, 08:26 AM
Quad On!!
nate25j's Avatar
United States, AL, Auburn
Joined Dec 2012
The motor does look very well made!! Hope to see more of this...looks promising!
nate25j is online now Find More Posts by nate25j
Old May 27, 2014, 08:30 AM
James not bond
jy0933's Avatar
Joined May 2012
they are actually pretty good comparing to sunnysky on a quad. at least not as much vibration.
Old May 27, 2014, 08:35 AM
Quad On!!
nate25j's Avatar
Joined Dec 2012
Yeah I'll definitely try these....Especially the connectors look a lot sturdier.
Old May 27, 2014, 08:37 AM
James not bond
jy0933's Avatar
Joined May 2012
i soldered the connectors myself.. but I do like the silicone wires more than solid copper wire. longer and more flexible
Old May 27, 2014, 08:51 AM
Quad On!!
nate25j's Avatar
Joined Dec 2012
I see...yeah I agree that is still much better.
Old May 27, 2014, 09:38 AM
panyator's Avatar
Singapore
Joined Jul 2013
Those motors looks very nice! I have high esteem for the Sunnys, if those are even better for the same price, then I am sold... However I am surprised that there's no mention of a very crucial piece of information: the weight of the motor...
panyator is offline Find More Posts by panyator
Latest blog entry: Moving from Simonk to BLHeli
Old May 27, 2014, 10:57 AM
Firmware Fiend
The Quasar's Avatar
United States, CA, San Diego
Joined Nov 2013
I'd like to see how they perform using 4S. I'm leaning towards Cobras at the moment, but I'll give these a little more time to develop before making my purchase.
The Quasar is online now Find More Posts by The Quasar
Latest blog entry: Cap-bill Mobius Mount
Old May 27, 2014, 08:00 PM
Certified Heli Addict
RaymondM's Avatar
United States, MI, Cadillac
Joined Apr 2011
Nice looking motors, wondering how the prop adapter or whatever that is fits together, never seen that before??
RaymondM is online now Find More Posts by RaymondM
Old May 27, 2014, 08:31 PM
James not bond
jy0933's Avatar
Joined May 2012
weights about 40g with bullet
tested in comparision with sunny sky..
@The Quasar 4s with 5030 prop? sure .. data coming in later...
in case of asking data source
GOPR0077 (1 min 29 sec)
GOPR0078 (0 min 45 sec)
GOPR0079 (0 min 52 sec)
GOPR0080 (1 min 32 sec)
Old May 27, 2014, 09:53 PM
Firmware Fiend
The Quasar's Avatar
Joined Nov 2013
So are these the same or similar motors as the new Witespy advanced mini house motors? They look almost identical. Paul never has good descriptions of his products, so I have to rely on others for information.
Old May 27, 2014, 09:59 PM
James not bond
jy0933's Avatar
Joined May 2012
16v hq5030
Airbot Micro Titan 2204 test result_16V ~max throttle (1 min 21 sec)
this should be what you are looking for and i can tell you that sunnysky heats up like hell while this stays pretty coll
the vibration near middle is the test bed's resonate
Old May 27, 2014, 10:22 PM
panyator's Avatar
Singapore
Joined Jul 2013
mmh at 39g, it's getting pretty close to 2208 size category and almost double the weight of the Sunnies... Though with 6x4.5 props, this thing should be a screamer while staying relatively cool...
Old May 27, 2014, 10:36 PM
James not bond
jy0933's Avatar
Joined May 2012
it doesn't warm up at all... when I was testing with 4s, the air is pumping up, I can't put my finger on sunnysky, but I can hold this one in hand.
Old May 27, 2014, 10:51 PM
James not bond
jy0933's Avatar
Joined May 2012
kind of processed data for 4s... it is pretty amazing..
Data [IMPRESSIE] Airbot Mini Titan 2212 test result jy0933 Multirotor Power Systems 3 Oct 20, 2014 03:26 PM
Sold mini titan e325s fbl eschult Aircraft - Electric - Helis (FS/W) 3 Sep 30, 2013 06:34 PM
Discussion Gaui X3 vs TT Mini Titan v2 FBL ? Hexperience Mini Helis 0 Sep 26, 2013 08:14 PM
Discussion Mini servo comparison - my own test results smeggyhead Radios 2 Jul 29, 2012 06:42 PM
Discussion Kasama Head for Mini-Titan e325 video review and new test flight!!! brovic777 Mini Helis 16 Oct 02, 2007 05:48 AM
