Old Jul 24, 2015, 05:38 PM
HSPalm is offline
Find More Posts by HSPalm
Joined May 2011
Mini-HowTo
Super cheap FrSky receiver antenna
Yes I know they are cheap to buy readu made but DIY is fun.
First you buy these http://www.ebay.com/itm/321739149292...%3AMEBIDX%3AIT. Each cable gives two 15cm antennas (slightly longer than D4R-II I think).
You have broken one or two antennas
Measure the length of the active part of the antenna if one is uncut, or look at this picture
Bend one cable and cut it in two equal lengths.
With a very sharp hobby knife, aim at 40mm from the "free" end and press the knife gently against the cable while rolling it one revolution with your fingertips at the connector end. If you apply too much pressure with your knife it's easy to cut too deep and into the dielectric. Pull the sheathing off, exposing the shielding copper braid.
Push back the shielding braid so it's diameter expands
Cut the shielding braid where sheathing ends with a side cutter.
Now cut the active part down to the exact length and you are done!
Make many more at the same time and bring to an RC event to share
HSPalm is offline Find More Posts by HSPalm
Old Jul 24, 2015, 06:34 PM
srnet is offline
Find More Posts by srnet
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
Why 'exactly' 33mm ?
srnet is offline Find More Posts by srnet
Old Jul 24, 2015, 07:09 PM
HSPalm is offline
Joined May 2011
The stripped part is the actual antenna. The antenna length decides which frequency it's appropriate for. You can either calculate the length yourself quite easily or just look at what FrSky them self chose to use, like I did.
Old Jul 24, 2015, 08:15 PM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
Should be 30-31mm for 2.4GHz.
ivanc is offline Find More Posts by ivanc
Old Jul 25, 2015, 01:45 AM
srnet is offline
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
To calculate the 'exact' length you would need to know the velocity factor of the wire, the insulation on it does have an effect.
The wires on my Frsjy antennas are 33mm long.
Old Jul 25, 2015, 06:01 AM
Jet_Flyer is online now
Find More Posts by Jet_Flyer
AKA 8178
Jet_Flyer's Avatar
Joined May 2004
Interesting, but how in the world are you damaging so many antennas? I've never had one get damaged and I have twenty receivers.
Jet_Flyer is online now Find More Posts by Jet_Flyer
Old Jul 25, 2015, 06:24 AM
FrankS is offline
Find More Posts by FrankS
United Kingdom, Glos
Joined Feb 2009
You are maybe not trying hard enough
FrankS is offline Find More Posts by FrankS
Old Jul 25, 2015, 09:07 AM
HSPalm is offline
Joined May 2011
Trees, branches, propellers... Just landing upside down a lot makes it eventually weaken where it's bent.
Sold FRSKY X8R - 8/16 CHANNEL RECEIVER with extra Antenna's & frsky LIPO VOLTAGE SENSOR Chad2323 FPV Equipment (FS/W) 1 Jul 09, 2015 09:24 AM
Sold FRSKY X8R - 8/16 CHANNEL RECEIVER with extra Antenna's & frsky LIPO VOLTAGE SENSOR Chad2323 Aircraft - General - Radio Equipment (FS/W) 2 Jul 07, 2015 10:46 PM
For Sale 2x FrSky X6R Receivers w/extra antenna workshop FPV Equipment (FS/W) 3 May 18, 2015 12:22 AM
Sold Futaba T9CHP Super W/FRSKY 2.4 Module & Receiver & Original FM Equipment Yardbee Aircraft - General - Radio Equipment (FS/W) 3 May 10, 2015 06:44 PM
Sold 5.8ghz antennas, receiver, FrSky receiver CarbonFlite FPV Equipment (FS/W) 4 Jul 01, 2013 05:16 PM
