Old Apr 05, 2011, 11:45 PM
kcchiefdawg is offline
Find More Posts by kcchiefdawg
Joined Jan 2011
3s vs 4s 2200mah difference
I am new to RC electric RC and have two planes, the PZ P-47 which takes a 3s 2200mah lipo and an Airfiled bf109 which came with a 4s 2200mah lipo. Apparently the bf109 can take batteries from 2-4s. My question is what is the difference between a 3s and a 4s lipo that has the same mah (2200 in this case) assuming the C rating was the same on both batteries (20C)
Would I get longer flight times with the 4s 14.8v battery than with the 11.1v 3s battery?
kcchiefdawg is offline Find More Posts by kcchiefdawg
Old Apr 05, 2011, 11:58 PM
Hance is online now
Find More Posts by Hance
Expo is built into my thumbs
Hance's Avatar
USA, ID, Niter
Joined Jul 2008
With throttle management flight time should be similar. Full throttle the current draw will be much higher don't go from 3s to 4s with out checking amp draws and probably propping down several sizes.
Hance is online now Find More Posts by Hance
Old Apr 06, 2011, 12:05 AM
Joined Jan 2011
Does current draw translate into torque or power? I am not switching from a 2s to a 4s lipo in my bf109, it came with a 4s lipo. I am asking because I already have two other 2s lipos of the same mah so I was wondering what I would notice by using those 3s lipos or if it is a bad idea.
Old Apr 06, 2011, 12:12 AM
Hance is online now
Hance's Avatar
USA, ID, Niter
Joined Jul 2008
If you go down in cell count there will be a decrease in power but it shouldn't hurt anything.
VoltsXamps=watts. Most people relate power out put to watts so
Say 12 volts X 20 amps = 240 watts for a 3s setup versus 16 volts X 20 amps = 320 watts for a 4s setup. Not a perfect example but it gets the point across.
Old Apr 06, 2011, 12:17 AM
Joined Jan 2011
ok so the plane will have less power but the flight time should be comparable to that of a 3s lipo with the same mah and C rating?
Old Apr 06, 2011, 12:22 AM
Joined Jan 2011
Thanks, I think I get the idea of it being more powerful, so my only remaining question is about the flight times. I am assuming that the flight times should be about the same with both batteries due to the mah being the same. Am I correct?
Old Apr 06, 2011, 12:42 AM
Hance is online now
Hance's Avatar
USA, ID, Niter
Joined Jul 2008
Flying the same flight yes it should be similar.
Old Apr 06, 2011, 02:32 AM
abenn is online now
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
... Apparently the bf109 can take batteries from 2-4s. My question is what is the difference between a 3s and a 4s lipo that has the same mah (2200 in this case) assuming the C rating was the same on both batteries (20C)
Power is measured in watts, and watts = volts x amps, so if you want the same power from a 4S battery as from the 3S, you'll have to reduce the amps. Provided you do that (by using a smaller prop), you will then get longer flight time from the same mAh because you're using less amps
But you must be careful when switching battery volts; even though the motor and ESC are designed for 2S to 4S (7.2v to 14.4v), it does not necessarily mean that you can just put a 4S pack into a model that's been set up for 3S or 2S. The number of volts and the prop size determine how many amps the motor will draw, and putting in more volts without reducing the prop size will usually burn up the motor and/or ESC -- unless the motor is running at only half it's potential power output on 2S.
If you give us a link to your model, maybe someone with hands-on experience of it can say what prop you need to use -- or maybe it's in the instructions somewhere.
abenn is online now Find More Posts by abenn
Old Apr 06, 2011, 09:13 AM
Joined Jan 2011
Thanks!
Old Apr 06, 2011, 01:27 PM
cliffh is offline
Find More Posts by cliffh
Gustavus, OH
Joined Oct 2007
(snip)
Not quite correct. But the end result is the same ;-)
Watts = volts x amps. Even if you prop down to keep the power level the same (fewer amps) with the 4 cell, you must remember the volts are HIGHER.
Example: 11 volts x 20 amps = 220 watts
but: 14 volts x 15.7amps= 220 watts
You will get longer flight times with the 4 cell, but it is because of the extra cell. Think of a gas tank that holds 4 gallons instead of 3 gallons. In round easy to understand numbers, use the example of a 1000mah lipo pack. A 3 cell pack contains 11 volts x 1000mah = 11,000mah while a 4 cell pack contains 14 volts x 1000mah = 14,000mah.
How long you can fly depends on the mah (milliamperhours) contained in the battery divided by the mah used by the motor and equipment.
Cliff
cliffh is offline Find More Posts by cliffh
Old Apr 06, 2011, 01:41 PM
abenn is online now
Joined Jul 2004
Originally Posted by cliffh View Post
... You will get longer flight times with the 4 cell, but it is because of the extra cell. Think of a gas tank that holds 4 gallons instead of 3 gallons. In round easy to understand numbers, use the example of a 1000mah lipo pack. A 3 cell pack contains 11 volts x 1000mah = 11,000mah while a 4 cell pack contains 14 volts x 1000mah = 14,000mah.
Cliff
Another way to look at it, but you need to get the units right
Since volts x amps = watts, the units in your example need to be 11,000mWh and 14,000mWh (mWh is milliwatt-hours).
Old Apr 06, 2011, 04:56 PM
cliffh is offline
Gustavus, OH
Joined Oct 2007
You are absolutely correct. It is milliwatt-hours.
Thanks for correcting me.
Cliff
Old Today, 02:04 AM
Webtaha is offline
Find More Posts by Webtaha
Joined May 2015
Hi that information was really useful
but just to make sure as I'm a beginner in this field can u please tell me if I'm right or wrong in my new and first setup:
-hex-copter with 6 motors A/2212 /1000kv + 6 ESC 30A
-DJI Naza- Lite Flight controller
-10X45 propeller 1045
-Lion Power Lipo 14.8v 5200mah 30C - 40C 4S1P Battery 156A Continuous discharge
- FS+i6 Flysky 2.4-Ghz 6 channels RC Remote transmitter
- DJI 2 axis gimbal for go-pro hero 3
thanks for your advice
Webtaha is offline Find More Posts by Webtaha
Discussion 3S Full Throttle Vs 4S Partial Throttle, same motor and ESC, performance difference? CATPart Power Systems 152 Oct 11, 2013 04:05 AM
Discussion Gens Ace 3S 1550 25C vs. Sky Lipo 3S 1600 40C EricJ320 Batteries and Chargers 28 May 24, 2011 09:24 PM
Sold (2) New Turnigy 4S 2200mah 40C packs mjbennett9 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 17, 2011 10:46 PM
Sold Brand new 4S-2200mah from Nitro planes P-51 $22 shipped RCGill Aircraft - Electric - Batteries & Chargers (FS/W) 0 Mar 05, 2011 05:32 PM
Discussion Flightmax 3s 25c 2200mah vs Zippy R 3s 20c 2300mah................ mtdoramike Hot Online Deals 16 Apr 29, 2009 12:46 PM
