Old Jun 16, 2014, 02:48 PM
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
test tank day,, 9lbs 2oz to a nice waterline, hull and running gear 2lbs 11oz.. 6 lbs 7oz left for decking, details, fittings, radio gear and main batteries.. should be easy if I keep a good eye on the weight of the deck gear and ordnance.. hope to leave about a pound for final adjustment ballast..
tghsmith is online now Find More Posts by tghsmith
Old Jun 23, 2014, 12:27 PM
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
test method for making portholes, 3/16ths (equals 18inches 1/96th scale) brass eyelets, roughed up on inside and filled with a resin mix,, hole drilled in hull, burr and reamers used to get tight fit (hull is a "fail" brooklyn section) eyelet flange makes glueing in from inside easy.. tape to protect hull while sanding down porthole to needed level.. hull and porthole painted over , porthole sanded to remove paint and a drop of clear gloss added to surface.. (test hull paint was not dry during final sanding) 90 some portholes to make now..
Old Jun 23, 2014, 02:28 PM
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
three more, this time on a little better surface..
Old Jun 24, 2014, 01:38 PM
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
while working on the porthole project the gun deck and the main deck have started to take shape, along with starting to get the gun-ports opened up.. 100 portholes prepped and filled with resin this morning..
Old Jul 10, 2014, 05:32 PM
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
put around 86 holes in the hull today,
Old Jul 10, 2014, 06:06 PM
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
about 3/4 of the portholes were epoxied in place, the rest will get installed in the morning, once sanded down the rest of the basic hull details will get installed..
Old Jul 11, 2014, 12:27 PM
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
final count, 90 hull portholes all epoxied into place
Old Jul 18, 2014, 05:25 PM
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
the steering mechanism is all in place(and tested), hull portholes all sanded down to proper thickness, some hull fittings started.. shafts threaded for props,
Old Today, 03:37 PM
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
my evergreen plastic order showed up on monday, so the hull rub-rails were added, running gear was all given its final fitment and bench tested, though very tempted holding off on hull painting until most of the details are in place..
For Sale Multiplex MiniMag RTF - LPU Raleigh, NC area cshepherd Aircraft - Electric - Airplanes (FS/W) 3 Feb 03, 2014 01:54 PM
For Sale Relisting for my Glider can be seen in person at Raleigh Hobby in Raleigh NC WallsRoofing71 Aircraft - Sailplanes (FS/W) 0 Jan 30, 2011 06:36 PM
Mini-Review C.C. Lee 1/400 USS Enterprise (CVN-65) Plastic Kit In-box Review...A kit for RC fun? Kronosaur Scale Boats 1 Sep 12, 2009 08:22 AM
Raleigh N.C. nightflying strat919 3D Flying 7 Aug 05, 2005 05:40 PM
RAMS 3rd annual electric funfly 2 day even in Raleigh, NC August 7 + 8 Steve H. Electric Flight Events 76 Aug 17, 2004 11:41 PM
