Old May 06, 2015, 01:51 PM
EAC is offline
EAC
Find More Posts by EAC
EAC
Eureka Springs, AR
Joined Jan 2007
Just ignore the error, you don't need the MM2001 driver if you use the GCC. Make sure you select the GCC in the Table config dialog, it will work fine. Nothing complicated.
Don
Originally Posted by Dionysos View Post
Sorry I might be a bit slow on this one because I havent touched on that topic in years.
what do you suggest?
I run win 7 64, gcc v1, hobby cnc pro board. I can install gmfc and got my machine moving using the gcc tester. If I start gmfc it asks for the mm2001 driver. So how would I make it work?
EAC is offline Find More Posts by EAC
Old May 06, 2015, 09:18 PM
Dionysos is offline
Find More Posts by Dionysos
Singapore, Singapore
Joined Apr 2012
Hey Don,
indeed I forgot to check that option. *MANY* thanks for the pointer. it works again.
appreciate your help.
Dio
Dionysos is offline Find More Posts by Dionysos
Old May 14, 2015, 01:47 PM
Marco Vergara is offline
Find More Posts by Marco Vergara
Mexico City
Joined Dec 2005
Please, need help with GGC V2 interface conection
I bought ggcv2 interface and LCD option kit 2 years ago, until now I am getting everything ready to start.
I have an old Tal Barnea Foamlinx motor interface, it is old but works with Hobby cnc timer and GMFC pro, 1/2-10 acme screw.
I changed to GGC V2 to use USB with my new computer, windows 7 64 bit.
Problems:
1.- I am not an electronic guy.
2.- There are 3 resistors on Lcd kit:
2 k ( connected to lcd pin3 text contrast) no problem
what about 180 and 100 resistors ?
3.- LCD screen is working without 180 and 100 resistors, is that ok?
4.- Motors are moving but not in the right way with the cero axis.
5.- My power supply is a Deltron 24V 7.5 amp , it is connected an working but heat is not working , heat led was conect in both ways no light, led is ok it has light with 2 1.2 v batteries.
I use a Variac for inconel heating but i would like to have everything working.
Marco Vergara is offline Find More Posts by Marco Vergara
Old May 14, 2015, 03:12 PM
Wazmo is offline
Find More Posts by Wazmo
Duane
Wazmo's Avatar
No. VA
Joined Nov 2004
Here's the GGC v2 documentation, if you don't have it. Check the datasheet for your LCD, but the other resistors may be for limiting current to the back light.
Does the heat work if you jumper J3.7 to J3.11? Is the LED connected the correct direction (cathode to J3.11, anode to J3.7)? Are you using DC power connected to the PowBow terminals?
You should be able to use the ggc utility to reverse the direction of any axis that is backwards.
Wazmo is offline Find More Posts by Wazmo
Old May 14, 2015, 03:31 PM
danfield is offline
Find More Posts by danfield
Fossilator
danfield's Avatar
Fullerton, CA
Joined Nov 2004
Hi Marco
#3 Resistors - the 2K is just for contrast.
The other resistors are for the LED's. But, IF you feel they are not too bright then you don' t really need them.
For Heat the Heat LED must be installed and working. All LED's have a little FLAT spot on one side. That is the Cathode or Negative side.
danfield is offline Find More Posts by danfield
Old May 15, 2015, 04:04 PM
Mexico City
Joined Dec 2005
Ok, after 15 hours of thinking, soldering, unsoldering, asking information and scratching my head the electronic part is working.
Led heat finally is lighting and heating circuit is functioning , thank you Wazmo and Dan for help the problem was a wrong conection of led and led itself.
I download and run the GGc v2 utility and couldnīt find a guide to use it, is there a guide or instructions about how to use it ? or how to change and chose motorīs movement ?
Old May 20, 2015, 12:24 AM
flybye33 is offline
Find More Posts by flybye33
flybye33's Avatar
Australia, QLD, Gold Coast
Joined Jun 2013
Delta wing error message
I wish to cut a small delta wing. (24" Tailplane) NACA section so nothing fancy
Seems to be well within the allowed travel area and yet I get this message.
"Differing number of points at root and tip"
I haven't used the software in over 12 months and moved house in between so all a bit stressful. Lol
I've played around with offsets etc to no avail, can someone please point me in the right direction here?
Thanks in anticipation,
Brian
flybye33 is offline Find More Posts by flybye33
Discussion CNC Foam Cutting problem with GMFC wimmeke CAD/CAM 0 Jan 14, 2010 12:24 PM
Discussion Foam works foam cutting software issue airmcn_3 The Builders Workshop 5 Aug 29, 2008 10:02 AM
CNC software for foam cutting KAMarks The Builders Workshop 0 Sep 15, 2002 08:20 PM
foam cutting software Dinah Power Systems 0 Mar 19, 2002 10:08 PM
Foam cutting CNC software foam_man Foamies (Kits) 10 Sep 08, 2001 08:50 AM
