Closed Thread
Old Mar 21, 2013, 09:48 AM
xrx1113's Avatar
United States, FL, Lehigh Acres
Joined Aug 2011
Who has the best x plane set up?
top speed?
Motor ,prop, esc used and number of cells?
xrx1113 is online now Find More Posts by xrx1113
Old Mar 21, 2013, 10:33 AM
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Best at which category? Flat speed, climbing, weight, watts, battery time, price, etc...
I do think Yuri might have the best in any category except price for now. But I do know someone who might claim a speed record soon....
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Mar 21, 2013, 11:26 AM
xrx1113's Avatar
Joined Aug 2011
Honestly i'm trying to decide what to put in my new yellow one; i have been reading the build thread and its not really helping because its so long between motor posts and no real descriptions of how fast its going with a particular set up.
I like hotliner type flying , i want 150 mph with 10-15 second motor runs and a folding prop. Lighter is good for the glide, duration of 2-3 min would be fine as i will be doing short motor runs anyway. i dont want to say price is no object but you dont scrimp on an x plane
yuri sent me his set up but when i put it in the calculator it doesn't make sence to me there are several "red issues"
I was hoping to get a better idea of what other x plane owners are running so i only have to buy the equip. one time and not need to fix a bad set up.
that being said i'm not opposed to used equip. if its in good order so if you have a set up that meets my goals and you want to sell let me know.
Mark, in Florida
Old Mar 21, 2013, 12:00 PM
Arcteryxxx's Avatar
Joined Feb 2010
As I'm sure you know already, the mega 16/35/1 and a Kontronik KPG gearbox is the most common setup for 4S and 5S... I would get that one if I were to buy another setup for mine. Currently I use an ARC28-58-1 and KPG gear. Not bad either, but needs 5S to get going.
Old Mar 21, 2013, 12:17 PM
Crashing into the sky!
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Red issues in the calculator mean its good I havent seen one yet that can deal with a hotliner setup without freaking out.
If you want top speed, setting it up as a hotliner is probably not ideal. Direct drive pylon racer will be the key. A 16/40 direct drive would be fun.
As a hotliner -
Run the 16/35/1 kpg 25/27 5.2:1 on 4S with 14.5x14s, and then 16x17s. Thats safe on the gear and will make you grin. If you want faster, run 5S. 4S should be fine on an ICE100 lite, I wouldnt try it on 5S though. 4S - 180mph, 5S 200+ mph (16x17s)
10-15 second motor runs will put the 16/35/1 setup into orbit 2-3minutes of motor on isnt a hotliner either, thats pylon racer material. Typical hotliner setups allow for 30S motor run time (which is plenty in reality)
A mega 16/25/2 5.2:1 on 6S (~1600mah) ICE100 lite with 14.5x14 is a nice setup too. Not as crazy as the 35/1, but not as stressfull either.
jackosmeister is online now Find More Posts by jackosmeister
Old Mar 21, 2013, 12:49 PM
Kansas City, MO
Joined Sep 2010
I've not had luck finding the MEGA 16/35/1 with Kontronik 5:1 gearbox. anywhere...Just me?
rcwarrior is offline Find More Posts by rcwarrior
Old Mar 21, 2013, 12:51 PM
Arcteryxxx's Avatar
Joined Feb 2010
Have to buy them separately and put the drive together yourself.
Old Mar 21, 2013, 01:02 PM
Lenny970's Avatar
Greeley, Colorado, USA
Joined Feb 2000
As a hotliner -
I was going to say about the same things, but Jacko beat me to it.
Lenny
Lenny970 is online now Find More Posts by Lenny970
Old Mar 21, 2013, 01:19 PM
Kansas City, MO
Joined Sep 2010
6-8 weeks delivery from Mega ..I'm going to cry!
Old Mar 21, 2013, 01:24 PM
One Idiot is plenty...
Dbox's Avatar
Planet Earth
Joined Jun 2005
icare-rc.com
Dbox is online now Find More Posts by Dbox
Old Mar 21, 2013, 01:26 PM
xrx1113's Avatar
Joined Aug 2011
Jacko lol on the " red issues" and yes it will only be 10-15 second motor runs so it should cool a bit between runs.
Lenny i'm probobly going to ship this to you for the build out i just want to see it first lol.
Old Mar 21, 2013, 01:33 PM
What is Highspeed ?
Rolf D.'s Avatar
Germany, BY, Bergen
Joined Feb 2011
Lucky guys
You guys all lucky guys because your X is delivered,mine is laying by the custom since 4 days 45 Kilometer away from here and this Dudes working with a Speed from a snail
Rolf D. is offline Find More Posts by Rolf D.
Old Mar 21, 2013, 01:42 PM
Arcteryxxx's Avatar
Joined Feb 2010
Well.... still waiting for a package from Germany posted a week ago. You're not the only one suffering from German snailmail
Old Mar 21, 2013, 05:26 PM
Auckland NZ
Joined Aug 2007
10-15s motor runs with the 16/35/1 setup will melt it, esc and battery will just go bang, and itll be in orbit
2-3s motor on times, it sounds short, but itll literally go from one side of the sky to other in 3 seconds.
Old Mar 21, 2013, 06:19 PM
Dbox's Avatar
Planet Earth
Joined Jun 2005
My motor run on launch according to radio timer is 0.3sec
it does the trick without much of a torque roll.
Total motor run time for about 3/4 of battery drain is 25 sec.
Learned how to convert potential energy to kinetic (village people call it DIVING)
I dont use throttle more then 1.5sec in flight anymore.
I do have heat sink on my CC125 and it sits right against cooling hole.
Batt and CC are hot enough after flight but not burned.
I give it a cool time after each flight for about 15 min.
Yuri
Closed Thread
Discussion Someone who has had experience buying at toysonics??? ivanborrelly Hobby Stores 11 Feb 05, 2013 06:34 PM
Discussion best/cheap TX for control of an fpv set up Disp0sablehero FPV Talk 18 Feb 04, 2013 12:26 AM
Question Hacker A10-9L best set up? TMAC4123 Indoor Pattern/F3P 6 Jan 25, 2013 07:01 AM
Help! Need to know the set up for a Hydro Plane Foamie. SHoffman1971 Power Systems 13 Jan 15, 2013 07:25 PM
Alert Threat has been detected who do i tell? 57sailplane Site Chat 4 Jan 04, 2013 01:56 PM
