Old Dec 19, 2014, 07:05 AM
RC-JG's Avatar
United Kingdom, Holbeach Saint Johns
Joined Mar 2005
Which Battery !!!
Hello Everyone,
Merry Christmas.
I have brought a small electric glider with a Grauper Speed 400 Plus motor in with a BEC, Brake fitted to the rear of it, it also says6 ... 9'6v/15a and it has a Cam prop 15-8 or 6-3", what size battery would i need to power it ?
Thanks.
RC-JG is offline Find More Posts by RC-JG
Old Dec 19, 2014, 07:26 AM
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
It looks like it is this one, with Kv around 3000. 2S max! it was designed for 6 or 7 NiCd. Even on 2S it will likely get fairly warm if you run continuous full throttle
scirocco is offline Find More Posts by scirocco
Old Dec 19, 2014, 07:46 AM
RC-JG's Avatar
Joined Mar 2005
Yes that's the 1 by the looks of it
So a 2s i will get, will a Ripmax Pro Peak Prodigy 12v charger be ok with a Lipo ?
Old Dec 19, 2014, 03:55 PM
scirocco's Avatar
Joined Feb 2001
Only if it specifically says on the charger that it can charge LiPo batteries. If there is no explicit mention of LiPo capability, do not assume!
Old Dec 20, 2014, 04:37 PM
Chasin' that Neon Rainbow
Grantham Kid's Avatar
Australia, QLD, Grantham
Joined Oct 2012
I would be worried about running such a high kV motor with a folding prop.
Most of mine are around 900 to 1200 kV.
Grantham Kid is online now Find More Posts by Grantham Kid
Old Dec 20, 2014, 07:32 PM
Lou
AMA? Not needed, too expensive
United States, VA, Waynesboro
Joined Dec 2005
Yep ... kind of leary of the high kV on that folding prop. Not to mention that a brushed motor can be kinda hard on a lipo.
What is the plane that you are flying? Any pictures?
Lou is offline Find More Posts by Lou
Old Dec 20, 2014, 07:49 PM
Northumberland, England
Joined Jan 2007
I can't see where the product details or instructions say it's a 3000kv motor. There is one spec - No-load speed 18000 m-1 - whatever m-1 means (?). It does specify that it's for 5 - 8 cells (6v - 9.6v) so perhaps the kv is 18000/max voltage - i.e. 18000/9.6 = 1875kv.
Be that as it may, I used to run a similar speed 400 on 7 or 8 cells nimhs with grey Graupner 6x3 folding prop & sometimes on a non folding Master 6x4 ic prop. Current draw was around 10.2A with 7 cells & 12A with 8.
I used this set up in Henry, an OD model, that had previously flown using a Cox 049. With EP the model was about 100g heavier & overall the performance was similar. When it was Cox powered the model was flown more often as a slope soarer with prop removed than it was flown under power. Henry was published as a free pull out plan in the old Silent Flight mag about 15 years ago.
If you use the combo with 2s lipo the current draw (& therefore power) would be well down compared with using 7 or 8 nimhs but it could be improved by using a larger prop to get the current draw up to around the 12 - 15A range. The achievable power with 2s lipo would be about 15 - 20% down on what it would be with 7 or 8 nimh cells but there would be a significant weight saving.
The 8 cell nimh batteries I used were 1050mAH & weighed about 180g, for the equivalent energy from 2s lipo would need to be around 1300mAH but would only weigh about 75g. This should allow about 5.5 - 6 mins run time per charge which could be upwards of 30 mins flying time depending on thermic conditions etc.
The Pro-Peak Prodigy is able to charge lipos, AFAIK there were two versions . The first could only charge up to 3s lipo the second version could charge up to 5s but neither had a cell balance function. I used the early version without any problems (still do occasionaly).
As an addendum Henry was later converted to a 1100kv outrunner weighing 57g using 3s 2500mAh early lipo that were only rated at 8C (but only weighed the same as the nimhs) driving a 9x5 folder. Performance was transformed & a single charge was enough for over 90 mins flying time with no thermal assistance.
Personally I'd dump the Speed 400/esc combo & replace it with a 50 - 70g 1000 - 1500 kv outrunner & 3s lipo.
patmcc is online now Find More Posts by patmcc
Old Dec 20, 2014, 09:17 PM
320pilot's Avatar
Joined Mar 2009
Personally I'd dump the Speed 400/esc combo & replace it with a 50 - 70g 1000 - 1500 kv brushless outrunner & 3s lipo.
(fixed it for you..)
320pilot is offline Find More Posts by 320pilot
Old Dec 21, 2014, 01:27 AM
scirocco's Avatar
Joined Feb 2001
m-1 is per minute. While the range says 6=9.6V, that particular motor is known as a 6V S400, hence about Kv of 3000 for 18000 rpm at 6V no load. There are older motor calcs that still have the specs for brushed Graupner Speed motors. S400 6V cat #3321 is listed as 3075
A 6x3 folder on s400 used to be routine, eg it was the stock prop on the Graupner Terry (circa 2000) for 6 or 7 cells, and was used in much more sophisticated setups. And it won't be turning 18000rpm loaded on 2S , maybe 13-14000.
Old Dec 21, 2014, 02:40 PM
Joined Jan 2007
Thanks for the explanation. Just had another look at my old notes on this motor, using 8 cells with a little plastic Gunther I recorded 14400rpm but not the current. I think I may have been alarmed that the revs were to much for the Gunther & closed the throttle in a hurry.
Old Dec 21, 2014, 02:42 PM
Joined Jan 2007
Do you think it needed fixing ?
I can't think of any brushed outrunners, can you ?
Discussion Need advice. Which OSD supports 2 flight battery current sensors BadgerRC FPV Equipment 1 Oct 29, 2014 08:33 AM
Discussion Which Icharger to charge 6 5200 ma batteries via psu?? Doctorpaul Batteries and Chargers 1 Oct 27, 2014 07:06 AM
Discussion Which battery xOJx Electric Plane Talk 9 Oct 20, 2014 11:21 PM
Discussion New Member - ProBoat Black Jack 29 - Which Batteries?? At Law Racing Boats - Electric 4 Oct 10, 2014 12:43 PM
Question Which Battery kidd51 Multirotor Power Systems 0 Oct 05, 2014 12:43 PM
