Old Jun 14, 2014, 07:16 AM
GhostMaster's Avatar
Portugal
Joined Feb 2012
And less 69g.
GhostMaster is online now Find More Posts by GhostMaster
Old Jun 14, 2014, 09:53 AM
Joined Feb 2013
Until now, the MiniMOVI remains among the lightest in spite of the strong structure and easy assembly for those who buy the kit.
For diet, we are working...
Markuc is offline Find More Posts by Markuc
Old Jun 15, 2014, 02:33 AM
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Slightly improved version of my "very-simple" gimbal - made it stronger and lighter.
Total carbon parts weight - 7.2g (alu was 15.8g, but oversized), better vibration resistance (stronger than carbon) and third axis mount.
Best part - gimbal without mobius and third axis fits into 90g.
(few more images here, here, here and here)
I attached drawing in case someone wants to replicate - just print it 100% size, cut any group (they're different shape, pick one which suits your carbon plate), glue it to carbon (or CF - should work well, but will be slightly heavier and more flexible) and cut with fretsaw. Glue with epoxy, done. Total work - probably less than 2 hours, more time - waiting until epoxy hardens ;-)
Next version will use custom rewound motors and uncased mobius. I plan to fit into 88g all included (3 axis, controller, mobius - everything into 88g).
ABLomas is online now Find More Posts by ABLomas
Old Jun 15, 2014, 07:39 AM
Flight cadet
The Netherlands, OV, Enschede
Joined Jul 2012
cool!
which motors and controller did you use? (I would be interested in the 2D solution)
when do you start selling?
oxygen is online now Find More Posts by oxygen
Old Jun 15, 2014, 08:39 AM
Portugal
Joined Feb 2012
88g a 3D gimbal with camera is very impressive.
Old Jun 15, 2014, 08:52 AM
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Motors: http://www.goodluckbuy.com/ax-gm-220...ography-1.html
Yaw axis: http://www.rctimer.com/index.php?gOo...5&productname=
Controller: afrobgc, but you can't get this one, so pick anything - stormbgc, evvgc or even old tested alexmos (i had 18$ HMBGC on alu gimbal). All work well, just different form factor/weight.
Never, i do not mass-produce them. Pick drawing, spend two hours and get gimbal!
Old Jun 15, 2014, 03:30 PM
Joined Feb 2013
Great job! But it is not too flexible?
The declared weight is comprised of a suspension system?
How do you weigh 90g if:
2x2206 (no screws) = 62g
1x2804 (no screws) = 42g
1x Gimbal controller + imu with all cables (your version) = 12g
1x = 7.2 g carbon structure
1x aluminum bracket pitch =
Total | 123g (weight exceeded)
If I also add 10g of the original mobius support that you are using ...
123 + 10 = 133g
aluminum pitch bracket with various screws (10/15g)
133 + 10 = 143
An anti-vibration mount carbon standardized 2mm with four suspension weighs 20/25g.
143 + 20 = 163g
Not bad for a 3-axis, but if we want to declare the weights ... all people should calculate them well.
Opinion:
As long as there will be no mikro motor will not be possible to overcome the barrier of weight really, not even using the single lens of the mobius that still needs its hardware.
I do not think that a 2206 engine is able to handle the weight of the only mobius lens, it will be too light for him and will come into vibration.
Old Jun 15, 2014, 04:24 PM
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
No, try to bend 1.6mm carbon plate with hands ;-)
At least, less flex than alu (6063) version, tested on bike (alu version vibrated a lot when driving).
Probably best would be something like 7075 T6 plate for gimbal - slightly heavier compared to carbon, but very stiff and could bend on impact. But it won't be cheap...
No, i do not use this one on left, mini multicopters do not vibrate much, and such mounting does not help on bicycles..
I will put video in few days, weather here sucks :/
Old Jun 15, 2014, 04:29 PM
Joined Feb 2013
It is a true mini quad vibrates a little, I saw this in your video with aluminum gimbal.
In any case, congratulations for your work, I really appreciate the people who know how to create!
Thanks for the explanation, a greeting
Old Jun 15, 2014, 05:04 PM
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Just now noticed that you added info:
So, not third axis motor, also i do not know why you think that 2206 weight 31g - IIRC they're 26g with cut shaft.
Yes, with yaw motor it's much heavier, motor itself is big and heavy...
And alu bracket weights 4g, not 10-15 as you stated - it's small ;-)
As i said, it's too heavy for minis, so i will try to make different version:
  • HK 2403 motors, rewound and with cut axis (have maybe 9 of them, tried to make minicopter on them, failed, so need to put them to work). Weight with all mods ~15g/ea
  • not sure if i will keep something around 2206 for yaw, probably the same 2403 motor, they should have lots of holding torque, and with high pole count - should not skip steps1
  • completely disassembled mobius - PCB with PRF202, to isolate, put lens on top, supercap on bottom, solder power wires directly. I already done this with one of my mobius, final weight is ~18g (!) with stock "A" lens, should be more with wide lens (now do not have photo or can't check exact weight - crashed plane and re-assembled everything again into case).
  • no support plates for cam - mount it directly on motor axis. It's not hard with wide motor, there's enough space, few drops of epoxy and done. Also easy to reach buttons on mobius...
  • not sure about arms - best option would be 0.6mm carbon construction (glued into rectangle tubes), but too much work. Would be uber-stiff and could handle light crashes, but really lots of work without CNC. So i will probably just do similar handles from 1.5-1.8mm carbon...
This one should be true mini-multi gimbal - comparable to mini-cam weight, lots of torque, small (so can be hidden into copter cage, to protect from crashes). Just... Rewinding motors require lots of patience and time, won't be soon for sure - summer is for flying, not building :P
Old Jun 15, 2014, 05:55 PM
P.I.Engineer's Avatar
United States, CA, Redondo Beach
Joined Mar 2005
I'll also have a gimbal available soon for the mobius. It is designed completely around the cg of all the parts. So it's a very specific mount. The first iteration was almost perfect. I have a little tweaking to do before it's perfect.
it's designed to only be used with these gimbal motors
http://www.hobbyking.com/hobbyking/s...dProduct=43037
it's mostly 3d printed but will have cnc'd g10 damper plates.
will come will all needed fasteners and dampers.
thanks
keep an eye out on my website for availability.
http://www.pureimaginationengineering.com/store.html
P.I.Engineer is offline Find More Posts by P.I.Engineer
Old Jun 16, 2014, 02:57 AM
Joined May 2014
Here is the answer from Zero:
"Hello,
the YS-S4 supports only 2-axis servo gimbal.for the manual please kindly find the attached file."
It means I can connect the signal to the gimbal motor?
The motors I have bougth are
2206-140Kv Brushless Gimbal Motor
also attach the YS-s4 manual
pataro is offline Find More Posts by pataro
Old Jun 16, 2014, 03:48 AM
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Originally Posted by pataro View Post
the YS-S4 supports only 2-axis servo gimbal<...>
Please, read again...
Old Jun 16, 2014, 05:21 AM
Joined May 2014
Yeah, but my gimbal does not have servos, only brushless motors, can I use an ESC?
Which ESC will fit good?
Old Jun 16, 2014, 05:32 AM
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
You can use ESC - flashed to work as bl controllers. For example, ESC32 have this mode, also others (look for Olliw FW).
But usually it's much cheaper and better (based on your questions) to get BLGC...
Discussion Mobius Action Cam $71 shipped tomcor Hot Online Deals 26 May 12, 2014 04:32 AM
Help! HOBBYKING 5.8GHZ 200mW to MOBIUS ACTION CAM CONNECTION dhonwyn Aerial Photography 3 Feb 02, 2014 09:10 PM
Discussion Mobius Action Cam wmw Aerial Photography 4 Dec 19, 2013 02:54 PM
Discussion Mobius Action Cam - live preview on external device Firebird_PL Aerial Photography 10 Dec 05, 2013 01:52 PM
