Old Yesterday, 09:41 AM
Salvi's Avatar
France, Lorraine, Thionville
Joined Aug 2013
Question
Short circuit on Turnigy Accucel-6 ?
Hello,
By mistake, I unplugged the positive wire load on the charger leaving the connected battery, causing a short circuit as the charger does not work (it lights but does not detect battery and does not launch load).
Have you an idea of the component that was burned?
Regards,
Salvi
Salvi is offline Find More Posts by Salvi
Old Yesterday, 05:52 PM
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Your description does not give enough information. I suggest you remove the cover and examine the circuit board to see if you can find an obvious failure.
Post photographs of any area that appears defective.
However that charger is relatively inexpensive and it probably is not worth attempting a repair. Be prepared to buy a new one.
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Discussion Turnigy Accucel 6 Bush Pusher Batteries and Chargers 0 Dec 31, 2014 10:42 AM
Question Is there a how to guide for use of chargers like the Turnigy Accucell 6 and Imax char tedbyers Batteries and Chargers 8 Nov 19, 2014 08:46 PM
Sold Turnigy Accucel 6 with power supply killerforhire Aircraft - Electric - Batteries & Chargers (FS/W) 4 Nov 05, 2014 05:28 PM
Discussion Turnigy Accucell 6 issue Tunechi Batteries and Chargers 3 Oct 20, 2014 12:27 AM
Discussion Turnigy accucel 6 on SEALED LEAD ACID battery dhonwyn Batteries and Chargers 1 Oct 03, 2014 05:19 AM
