Old Jan 06, 2015, 07:09 PM
JOHN 3:16
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Originally Posted by rainerm View Post
. The AutoG with 4s 1000mAh - try it out - it´s a blast!
What prop/esc are you using on 4s?
Stock motor I assume?
Sammy70 is offline Find More Posts by Sammy70
Old Jan 06, 2015, 10:23 PM
My head in the clouds!
United States, CO, Colorado Springs
Joined Mar 2014
I haven't tried it yet but I will be sure to put my detrum 40a in there when I do.
Cyclone Steve is offline Find More Posts by Cyclone Steve
Old Jan 07, 2015, 01:24 AM
Joined Mar 2014
Alright. Finally gave in and ordered 3 4s1000mAh 35c batts to try on my G and my Screamer!! Let the fun begin!
Old Jan 07, 2015, 01:26 AM
Joined Mar 2014
I'm thinking 4s will add just enough kick the 9x7 3 bladed prop.
Old Jan 07, 2015, 03:13 AM
south germany
Joined May 2009
I use an orange GWS HD 1080 with a Plush 40 A controller in my 4s setup. I had bad experience with the stock prop on 4s : it lost one blade during the flight. This cheap plastic part is more for decoration. If you fly with 4s, you need for normal cruising not more than half throttle - but for loops and barrel-rolls ( please only to left) the extra motor power is awesome! If once you tried the 4s, you´ll never go back to 3s.
rainerm is offline Find More Posts by rainerm
Old Jan 15, 2015, 06:05 PM
Joined Aug 2014
I'm about to buy this gyrocopter and want to make the battery out of 1S round 1200 mAh cells. I read it needs the 3S balance connector for the rotor-engine.
If I make a 4S battery I can attach 2 balance-plugs. A 3S for the rotor-engine and the 4S for charging and the voltage sensor (telemetry).
A pack made of these cells is probably lighter than a normal battery,
I can't order that propellore from the HK European store.
I can't even buy that size.
What are the dimensions of the original?
You also replaced the ESC. I think I have a 40A plush somewhere.
Probably wise to put that in immediately
Should I do a conversion immediately or is it fun to fly it with 3S to start with?
frater is online now Find More Posts by frater
Old Jan 15, 2015, 11:17 PM
crashing build's character.
United States, AL, Dora
Joined Mar 2008
what is the best way to balance the rotor blades?
onefastxp is offline Find More Posts by onefastxp
Old Jan 16, 2015, 06:09 AM
Bleriot's R Us
xairflyer's Avatar
Ireland, Donegal
Joined Nov 2003
If you look through the thread there is lots of different methods.
One I posted on page 50 post 743
xairflyer is offline Find More Posts by xairflyer
Old Jan 20, 2015, 11:17 AM
Build, crash, repeat...
lee292a's Avatar
USA, VA, Cedar bluff
Joined Dec 2002
Here's how I balance blades:
1. Weigh each blade to the nearest 0.1 g. I use a surplus triple-beam balance, although a cheap postal scale will work.
2. Find the CG of each blade, measured either from the hub or the tip
3. Add weight to the underside of each blade at the CG so all the blades weigh the same.
lee292a is offline Find More Posts by lee292a
Help! Slow-g slow stick auto gyro HyperHelis Auto Gyros 4 May 23, 2012 09:14 PM
Sold Zenoah G-23 w/muffler and FEMA auto start LotusTRBO Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jul 06, 2006 12:27 AM
Discussion Xero G Auto. epc2 Electric Heli Talk 2 Apr 01, 2006 08:08 PM
Video Xero G Auto. epc2 Electric Heli Talk 0 Apr 01, 2006 03:35 PM
