Old Mar 18, 2015, 11:59 PM
Bob6831 is offline
Find More Posts by Bob6831
United States, FL, Fernandina Beach
Joined Sep 2012
TX Dual Rates Setting vs Servo Control Horn Position
What is the difference between setting the range of control surface travel via using the Dual Rates on the Transmitter versus moving the z-bend of the Control Rod into a different position on the Servo Control Horn?
In other words, if I wanted to reduce the travel on my Ailerons of a new plane, should I change to Low Rates on my Tx (say to 50%) or move to comparable inner position on my Servo Horn? Which would be the better way and why. Would there be any difference for a 3D plane?
Bob6831 is offline Find More Posts by Bob6831
Old Mar 19, 2015, 01:10 AM
Joe Perrone is offline
Find More Posts by Joe Perrone
Joe Perrone's Avatar
doha Qatar
Joined Jan 2004
1) Changes in transmitter have more "granularity", ie, you can make a change in increments of 1%. Changes made at the servo arm position are of fixed amount, and probably much larger than 1%
2) It's been multiple decades since my statics & dynamics class, but I recall there's a mechanical advantage you get by being further out on the arm. Bringing the pushrod in closer would reduce that. I suspect most servos are powerful enough that this is not a problem, in practice
3) It's possible you gain a little control resolution (may not be the correct term) as you get in closer. For a 1 degree change in the position of the shaft, the closer in the pushrod is, the less the rod will move. Therefore, a 1 degree change results in less control surface movement, meaning finer control. I suspect this difference is insignificant for most fliers
4) Probably the reason people make the changes in the transmitter: It's really easy! You don't have to : expose the servo; some how get the rod off of the arm (unscrew; remove servo arm; remove rod, place it in different hole, replace?). Let's say you do that; and then don't like that (need more, need less). So you have to do it all over again. On the transmitter, it's push a few buttons...
I don't do 3d; but I believe 3d is possible due to the large control surfaces, large surface movements, and gobs of power.
- Large control surfaces implies you want as much torque as possible; you may be going the wrong way by bringing the pushrod in closer.
- Large movements? Well, you lose that by moving the pushrod in
- Gobs of power; this would have no impact on that aspect
- Fine control resolution; I suspect 3d planes really need to have this, so moving in closer would get you that. But I suspect the better solution is a really good servo made for the job
Regards
Joe Perrone is offline Find More Posts by Joe Perrone
Old Mar 19, 2015, 03:57 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
The way I see it, a servo signal from the transmitter goes in increments, usually small enough that the servo movement appears to be smooth. When you reduce the rates on the transmitter, you're reducing the number of increments and, as a consequence, the total distance the servo arm travels. Reduced number of increments will mean in theory you've got less-precise control over the position of your control surface.
So if you want to permanently change the travel of a control surface, the best way is to adjust the links at the servo arm or at the control surface, and leave the transmitter rates at 100%. Dual rates should be kept for instances where you want to be able to change the control deflection from your transmitter.
abenn is offline Find More Posts by abenn
Old Mar 19, 2015, 07:51 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Agreed. The point of dual rates is to allow you to have loads of movement sometimes and less at other times.
If you just want less movement overall then you do it by either changing the mechanical set up or by setting the overall travel amount in the transmitter. No need for two rates.
Steve
slipstick is offline Find More Posts by slipstick
Old Mar 19, 2015, 08:13 AM
mcnowhere is offline
Find More Posts by mcnowhere
Look out below
mcnowhere's Avatar
United States, OR, McMinnville
Joined Aug 2011
If you do it mech on the plane you can't change rates while it flight.
For 3d don't reduce endpoints on tx do it in the d/r.
http://www.rcgroups.com/forums/showp...count=22436%22 #7 endpoints on tx "endpoints should be very close to maxed out. Some radios will go to 120%, some to 140 or 150. Whatever, it just needs to be maxed out."
I had a link but lost it on geometry of servo vs control horn. The gist of it is you loose power from the servo if the geometry is wrong.
mcnowhere is offline Find More Posts by mcnowhere
Old Mar 19, 2015, 08:21 AM
Look out below
mcnowhere's Avatar
Joined Aug 2011
ahh found it
http://www.modelairplanenews.com/blo...set-up-servos/
By having full travel to drive the control surface, you maximize the servo’s precision and power. This setup works best with the pushrod in the outer servo-arm and control-horn holes.
Avoid moving the pushrod closer to the surface on the control horn; moving it would reduce the leverage applied by the servo
Help! Flight modes vs Dual Rate vs Retracts (confused!?) GooberRC Radios 4 Oct 19, 2014 08:53 PM
Sold Dubro 882 hd dual control horn system joedoan Aircraft - General - Miscellaneous (FS/W) 1 Oct 27, 2013 10:19 PM
Discussion Control horn settings versus Tx settings Chris_F Electric Plane Talk 7 May 24, 2011 12:08 PM
Sold 3 MX-50HP Ball Bearing Micro Pro Servos, Control Horn Sets and Gear Sets JohnM Aircraft - General - Radio Equipment (FS/W) 2 Jan 02, 2006 02:11 PM
Gallery Dual rates set to high.....Linked control surfaces Aero-Nuts Your Plane Photos 0 Oct 15, 2004 09:21 AM
