Old Jan 23, 2013, 04:09 PM
tupeloflyer is offline
Find More Posts by tupeloflyer
Dixie Sky Devils AMA# 1015548
tupeloflyer's Avatar
United States, MS, Tupelo
Joined Oct 2012
The new Full range orange Rx R620
Has anyone tried the new R620 ORx's? Just wondering if they were twice as good as the old trusty R610? I know they cost 12 bucks whereas the 610 is still about 6... They claim it's a full range Rx, but I use the 610 on many parkflyer size planes and never lost sig or flew out of range. If they are better than the 610 with a Sat Rx, it will be worth 12 bucks I guess??
tupeloflyer is offline Find More Posts by tupeloflyer
Old Jan 23, 2013, 06:10 PM
gooby is offline
Find More Posts by gooby
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
gooby is offline Find More Posts by gooby
Old Feb 16, 2013, 12:33 AM
Burner147 is offline
Find More Posts by Burner147
Hold my beer, now watch this!
United States, IL, Schaumburg
Joined Dec 2012
I have bought 2 Orange R620 receivers. Though I am having issues with them in my PZ P-47. I have 5 channels working with 5th the gears no issue. The AUX will not work the flap switch on the DX6i. Also the satellite will not bind with the R620. They both will just stay red and you get no function out of anything.
Anyone had any luck?
Burner147 is offline Find More Posts by Burner147
Old Feb 18, 2013, 05:50 PM
gooby is offline
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
If both have a light on it means that they are bound, try binding both again but from further away. Sometimes if you are too close, the binding process messes up.
I'm wondering how much real range these receivers have. One guy got 1.5 miles with the R910 which should be the same except for the extra 3 channels.
Old Feb 18, 2013, 06:00 PM
Joined Dec 2012
I got this all working and figured out the issues. It was a bad satellite. To get Ch 6 to work for the DX6i for flaps. Go to Flaps - Normal - change 0 to 100. I found the flaps just stay at 50% and don't respond. After I mad this change they work fully and can put in any Land amount and they work great. It wasn't a matter that the flaps were normal or reversed. Found it weird since I didn't have to do for the Orange 610.
Using this with a satellite and the R620 it works beyond vision in my test. Not bad for about 35 bucks total.
Old Jun 05, 2013, 11:29 AM
nigelsheffield is offline
Find More Posts by nigelsheffield
yorkshire UK
Joined Oct 2007
The r610 has a sat port but it does not work if you lose signal to main rx but still have sat signal the rx does not work servos!
Is the r620 any better anyone?
nigelsheffield is offline Find More Posts by nigelsheffield
Old Jul 08, 2013, 10:01 AM
Xermalk is offline
Find More Posts by Xermalk
Sweden, Helsingborg
Joined Jun 2012
Anyone know what port is used on the R620 for S.Bus?
Xermalk is offline Find More Posts by Xermalk
Old Jul 17, 2013, 12:48 PM
JEANJACQ is offline
Find More Posts by JEANJACQ
Joined Oct 2012
look this test :
Test of Orange R615 and R620 receivers for DSM2 (5 min 25 sec)
JEANJACQ is offline Find More Posts by JEANJACQ
Old Jul 22, 2013, 09:09 PM
lazy-b is offline
Find More Posts by lazy-b
Manila, Philippines
Joined Jul 2004
JeanJacq, Thanks for posting your test video.
I hope you can open Both Receiver and lets take a look inside of the receiver, I wonder what make the R620 more expensive.
Orange R620 is not a full range receiver unless you install a Satellite receiver.
Orange R610 look like there are Dual Antenna, but I guess its only a Single Active Antenna, the Other Antenna is just a Ground Plane.
lazy-b is offline Find More Posts by lazy-b
Old Aug 01, 2013, 08:16 AM
JEANJACQ is offline
Joined Oct 2012
Hello LazyB,
The test was done without satelite and the plane flies to an altitude of about 200m
(nearly 660 feet)...: And no lost frames at all during both test flights with this the R620. (He tested and operated 4 )
JJ
Old Aug 01, 2013, 08:25 AM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Nope don't really think so, not does the test above show that. The Sat just offers signal diversity, not range.
Old Sep 03, 2013, 02:58 PM
JEANJACQ is offline
Joined Oct 2012
Hello,
What new experiences with this Rx ?
Old Sep 22, 2013, 12:50 PM
TreeDiver is offline
Find More Posts by TreeDiver
BrainFart RC-Pilot
TreeDiver's Avatar
Echt, Netherlands
Joined Aug 2003
Originally Posted by JEANJACQ View Post
Hello,
I have 10 active Orange 620 and no problems at all.
The longer aerial is great for my Pylon racer with lots of carbon.
Next to the R620 I have the R710, R410 and the newer 8 channel DSMX receiver of them (but not is use yet....)
I start also using the Lemon receivers (but is offtopic)
I don't fly gliders and maybe 500meters max. My planes get to small if I fly beyond 300meter
TreeDiver is offline Find More Posts by TreeDiver
Old Oct 22, 2013, 11:30 AM
jecchile is offline
Find More Posts by jecchile
jecchile's Avatar
Chile, Valparaiso, Viņa
Joined Dec 2007
Orange 620 receivers
Yesterday I received an Orange Tx T-SIX and 4 Receivers model 620... I read the manual and proceeded to do the BIND process... Everything worked OK as per the book... first, the receiver with the bind plug blinked really fast and after turning the Tx on, after a few seconds, the light on the receivers went solid, as it should be... a servo connected to the receiver worked fine.
Today, however, I put one of the receivers into a glider and noticed that the light on the receiver BLINKED at a steady pace... did a range test and everything worked fine but the receiver in the glider continued blinking at a slow pace (not as if had the bind plug inserted)...
Question: Is this normal?... I never had one of these receivers before so I canīt tell if there is something wrong. As I said before, the range test worked fine (More than 90 feet). I also tested a different receiver and it acts the same way...
Thanks for the help...
jecchile is offline Find More Posts by jecchile
Old Oct 22, 2013, 02:33 PM
BrainFart RC-Pilot
TreeDiver's Avatar
Echt, Netherlands
Joined Aug 2003
I had this also once, but can't recall what caused it. See below my 2 guesses.
My friend has the DX-7 and it happend to him as well with original RX.
So my two guesses are:
1) IMO it could also be that the transmitter is too close to the RX. With binding I noticed, that a bit distance works much better for binding.
So this typical phenomenal during binding, could maybe also cause this behaviour?
2) The transmitter was not on. Or it was on, but wrong program selected.
In short after you did bind a model:
A) put on the TX with the correct program selected. Next step is to connect the ESC to the battery. The led should be steady on and not flashing, to display a correct binding/connection. If it does blink/flashes, re-connect again.
Bye the way, interesting to know:
How to program the failsafe on Orange:
Orange RX with failsave of course . The R620 / R710 / R910
Program the failsafe on Orange 7 ch RX (1 min 28 sec)
Pre-set fail safe.
- Insert the bind plug in the receiver.
- Power on the receiver. Once the LED is flashing remove the
bind plug from the receiver.
- Once you have all sticks and switches in the desired positions on your
transmitter power on the transmitter holding the bind button. This will program the Receivers fail safe in the the positions that the radio was in at the time of binding.
For Sale .40 sport float kit nib for j3 cub. $45 shipped or trade for spekt rx full range mdtang Aircraft - Fuel - Airplanes (FS/W) 8 Mar 08, 2013 09:00 AM
For Sale NEW DX4e DSMX Mode 2/4 Full Range Tx Aphro Aircraft - General - Radio Equipment (FS/W) 0 Jan 04, 2013 12:59 AM
Sold Orange RX 9 Channel Full Range 35.00 Shipped boatdoc Aircraft - General - Radio Equipment (FS/W) 0 Jun 09, 2011 01:26 PM
Sold NIP HK Orange DSM2 Satellite Rcvr Make ur Orange RCVR Full Range $23 Shipped jmrust Aircraft - General - Radio Equipment (FS/W) 1 Nov 17, 2010 07:02 PM
Sold Spektrum AR6200 Full Range RX w/Satellite RX - Like New *$65 shipped* ptt81 Aircraft - General - Radio Equipment (FS/W) 3 Oct 25, 2010 05:00 PM
