Old Feb 21, 2015, 10:55 PM
TEAM HILLBILLY
Somethin' Extra's Avatar
United States, MN, Fairmont
Joined May 2013
3mm
Somethin' Extra is offline Find More Posts by Somethin' Extra
Old Feb 23, 2015, 12:31 PM
Exodus 4:13
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
Forgive cross post with another 3dhs thread
Maidened the 48" Edge 6S beastie yesterday. Actually was a very good day. 14 batteries thru 5 planes at the field. No wind and 60 degrees and warmed up to 80 (sorry frozen northern people) The only bad thing was I forgot my alligator clips for my charger & couldn't juice up any batts.
Was not used to using my Taranis, so it felt a bit weird to fly.
Wattmeter showed 550W on a fresh charge so that's about par for the course for a 3S setup on a 48" bird using the omega 130 / motrolfly dm2815. But peak amperage was just over 23A. 2.5 min test / trim flights used 350 mAh so flight times should be right around 7 minutes... pretty OK for a light electric bird. 14x7 prop hauled it around with authority and had good vertical performance. The batteries fit easily in the tray to get the CG right, no problems balancing.
Good post stall in harrier in this plane but I'm not comfortable with a new airframe screwing around too much with low and slow. After a bunch more flights I'm sure I'll get to learning more with it .
bhoov128 is offline Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Feb 23, 2015, 12:33 PM
TEAM HILLBILLY
Joined May 2013
Bhoov do you have a sim? Its a lifesaver for learning 3d. If it can teach me to 3d it must work
Old Feb 23, 2015, 01:22 PM
Exodus 4:13
bhoov128's Avatar
Joined May 2012
Yeah I have RF 7.5. But real life flying is a bit different, and so is getting used to a particular airframe.
Old Feb 23, 2015, 01:47 PM
I live my life 12oz at a time
arnav's Avatar
United States, FL, Miami
Joined Nov 2011
I agree. it is like that for me as well. Too easy in the sim.
arnav is offline Find More Posts by arnav
Old Feb 23, 2015, 02:19 PM
Exodus 4:13
bhoov128's Avatar
Joined May 2012
I can hover for about 15 seconds max in real life. In real flight I can hover until the power company shuts off service because I stood there hovering long enough to not pay the bill.
Old Feb 23, 2015, 03:20 PM
TEAM HILLBILLY
Joined May 2013
in quick edit crank up the throws on the 51 slick to between 50-70 on rudder and elevator (all about how your plane is setup in real life) and between 30-45 on ailerons (again personal preference) and power to 110-150% is realistic for me. feels way more relistic compared to my 51. it will actually cranshaft on RF then.
New Product 3DHS 41" Edge "$99 Buck Huck" Ducati Mechanic 3D Flying 17299 Mar 27, 2012 04:37 PM
Sold 3dhs 41' edge buck huck bnf JBuck Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2011 07:58 AM
Sold 3DHS 41" EDGE - ORANGE - 99 Buck Huck 6L6Amp Aircraft - Electric - Airplanes (FS/W) 14 Aug 22, 2010 08:45 PM
