Mar 08, 2013, 08:58 PM
Vero Beach, Florida USA
Joined Aug 2010
Hi Tom,
I will hook up my computer to the Guardian in the morning and send you the settings for 2D only, my radio is the Futaba 9C, not sure about the Spectrum as far as programming goes but it should work fine, probably only a bit different in the way to setup the radio. To select between 2D, 3D and off modes is only how you program your aux channel, +100, 0, -100.
Picture a servo hooked up to aux channel, when you select OFF the arm should be centered, 2D mode should rotate in one direction and 3D mode to the other. As you mentioned you don't want any 3D mode, assign your 2 way switch so OFF would center the servo and ON will move it to one side, in this case the 2D mode. This is also how the remote gain knob is setup. On a Spectrum radio you have to figure out how to map the channels with the switches you want for these functions, the gear switch is great for the ON/OFF control and any other knob for the gain will work fine. Maybe someone reading this who is familiar with the DX8 can jump in and help out with the radio programming.
I will get back to you on my settings in the morning.
Nils
