Espritmodel.com Heli Air
Old Sep 20, 2011, 04:58 PM
Boca Raton FL
Joined Nov 2010
How to take out a stripped allen nut
I'm trying to swap my main landing gear and the little collar that is being held on by the allen nut seems to be stripped...
I tried 2 diff allen keys, and it just spins loose...
Tried putting tape on the key to make it little thicker, but it didn't work either...
so any ideas?
razorseal is offline Find More Posts by razorseal
Old Sep 20, 2011, 05:07 PM
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
Joined Aug 2009
If it's a 1.5mm screw, try using a 1/16" wrench. It's just a tiny bit bigger and may give you the traction you need.
If that doesn't work, see if you can grab the whole collar with pliers and twist/pull it off. If not, just Dremel it off and replace it.
C₄H₁₀ is online now Find More Posts by C₄H₁₀
Old Sep 20, 2011, 05:09 PM
C₄H₁₀'s Avatar
Joined Aug 2009
I just realized that my post above is EXACTLY the path I would follow in the real world. Normally when I post something like that it's a list of possible options, but that one was like I was holding the plane trying to physically solve the problem for myself. Interesting....
Old Sep 20, 2011, 06:09 PM
Medicinal Foam User
Wilfor's Avatar
150 mile house B.C. Canada
Joined Jan 2010
Sometimes a really small torx bit will go in and grab enough to get it out , either that or file down a bigger key untill it fits .
Wilfor is offline Find More Posts by Wilfor
Old Sep 20, 2011, 07:47 PM
USA, GA, Carrollton
Sometimes it isn't the hole that is rounded out but the wrench is rounded.
Grind off about 1/8 in. of the wrench and try again.
TFM70 is offline Find More Posts by TFM70
Old Sep 20, 2011, 08:59 PM
Joined May 2011
If you want to save the collar, you can get what is known as an "easy out" (available at any hardware store) Basically it is a reverse spiral bit that bites in the screw head when you twist out the screw like normal
outdoorsjd is offline Find More Posts by outdoorsjd
Old Sep 20, 2011, 10:13 PM
Build straight - Fly twisty
Whiskers's Avatar
Australia, QLD, Little Mountain
Joined Feb 2010
I agree with, "Grind off about 1/8 in. of the wrench and try again."
Leaving the grinding burr on the end of the tool sometimes helps too.
If that brings no joy, I have sometimes resorted to making a cut through the collar and into the screw, and then used a small cross-head (conventional) screwdriver to remove the screw.
An Easy Out usually requires a hole to be drilled into the screw. They can cause more problems than they solve. When they work... Great. When they break... You've got a thing harder than a drill jammed in the work.
Whiskers is online now Find More Posts by Whiskers
Old Sep 21, 2011, 12:30 AM
FFF CRASH ANALYST
Tstubbs's Avatar
United States, TX, Venus
Joined Aug 2011
cut it off with a dremel tool. That or use one of these. the small one is best for that
http://www.harborfreight.com/12-piec...set-95530.html
Tstubbs is offline Find More Posts by Tstubbs
Old Sep 21, 2011, 12:52 AM
Will fly for food
ilektron's Avatar
United States, CA, Carlsbad
Joined May 2011
Nobody has mentioned drilling the screw out. A last resort, but it works.
ilektron is offline Find More Posts by ilektron
Old Sep 21, 2011, 07:01 AM
domll's Avatar
Norwich.uk.
Joined Oct 2007
Sacrifice a allen key by glueing into the allen nut with epoxy.
domll is offline Find More Posts by domll
Old Sep 21, 2011, 10:36 AM
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
You can heat the Allen key and screw with a pencil torch or large soldering tool after to get the key out of the epoxy.
I have also crammed bits of aluminum foil in the hole, pressed the wrench in, and then removed. Sometimes a slight tightening twist first, before backing it out can help 'break' the fit to help loosen the screw.
It is almost always the key/wrench that rounded off, unless the screw cracked. Cut off the end of the key, but old machine shop trick is keep the key cool. If you overheat the key grinding it ( turns blue/black) it softens the metal and the keyy will never be good again. They are heat treated usually on good ones to keep them from rounding off in the first place.
Fred
Freddie B is online now Find More Posts by Freddie B
Old Sep 21, 2011, 06:00 PM
Maintain Thine Airspeed !
Wiltshire UK
Joined Apr 2010
Probably already tried this but tighten it first if possible as it sometimes breaks the "seal"
Also a sharp tap on the head of the screw with a small hammer to shock the threads a bit may help.
I uses to lose my temper with allen screws that screwed out of aluminium housings bring the hardened helicoil insert with them ;-(
Good luck!
Redbrickman is offline Find More Posts by Redbrickman
Cool How bout Building Avistar That Can Land Inverted?Some nut case done it,check it out Aga1978 The Builders Workshop 6 Oct 12, 2009 05:37 AM
How do i get out a lock-tited stripped allen bolt? scurrier Electric Plane Talk 16 Oct 26, 2004 01:57 AM
Help! Axi 2212 allen wrench bolt stripped button 3D Flying 9 Sep 06, 2004 02:09 PM
How to get the hex nut out of the pinion ericss Electric Heli Talk 4 Feb 17, 2002 11:28 PM
