Old Dec 06, 2009, 01:32 AM
HeavyCruser9's Avatar
Adelaide,Australia
Joined Dec 2009
Build Log
My 1/72 scale USS Longbeach CGN-9
putting the "Heavy" back into Heavy Cruiser !!My ongoing build of USS Long Beach in 1/72 scale
HeavyCruser9 is offline Find More Posts by HeavyCruser9
Old Dec 06, 2009, 01:59 AM
Adelaide,Australia
Joined Dec 2009
Also can anyone tell me what LB's navigation light set up would be? and the location of her port & stbd lights I have heaps of pics but can't spot em..
Some pics of the real ship and friends!
Old Dec 06, 2009, 02:00 AM
tim slocum's Avatar
Central Missouri,USA Along the banks of the Missouri River
Joined Jun 2005
Looks like alot of fun, what scale 1/96th?
tim slocum is offline Find More Posts by tim slocum
Old Dec 06, 2009, 02:30 AM
Adelaide,Australia
Joined Dec 2009
1/72 scale bud shes just over 3m long ! (3.05) gonna need a bigger car!
Old Dec 06, 2009, 02:37 AM
tim slocum's Avatar
Joined Jun 2005
No wonder your building it in sections. I remember seeing someone build a 1/96th scale Missouri where it split down the middle. He couldnt fit it in his small car. Good luck and have fun, the Long Beach is an interesting looking warship.
Old Dec 06, 2009, 04:24 AM
Adelaide,Australia
Joined Dec 2009
Was thinking of using either a pair of graupner 700bb motors(the ones that can go to 19volts) or the big Graupner 900's which rev lower but have bag loads of torque.
Any one use these or can suggest a motor?, they'll be spinning 2 x 55mm 5bladed props. I have enuff space set aside for up to 8 12v 7Ah gel cells depending on how much ballast she needs !!!!! If I go with the 900's they will be run on 24 volts !!
Old Dec 06, 2009, 07:12 AM
Veni, Vidi, Feci
patmat2350's Avatar
Motor City
Joined Dec 2004
Here's another famous shot:
patmat2350 is offline Find More Posts by patmat2350
Old Dec 06, 2009, 07:22 AM
Veni, Vidi, Feci
patmat2350's Avatar
Motor City
Joined Dec 2004
Motors: Remember, the motor and prop don't care (or know) what they're bolted to... so don't size the motor to the ship, but instead, to the prop!
A given prop, if spun a given speed, will make a given amount of thrust. If that thrust is good for your hull and desired operating speed, fine. If not, spinning the prop faster than recommended risks cavitation and wasted power, or worse, blade-flinging. Need more thrust? Get a bigger prop and drive it appropriately.
If you check Raboesch's catalog, they'll tell you the max recommended speed for a 55mm prop is about 6400rpm. Such a prop at this speed can easily be driven by a 500 size motor with 3:1 reduction... required battery voltage entirely depends on your motor's windings... it's easy to find 500's (like a Speed 500 or any r/c car motor) that will spin 18-20krpm (to be reduced by the 3:1 box) on 7.2 or 8.4v.
If you want to use 12v gel cells (easy to live with and good ballast with lots of amp-hour capacity), you'll want to look for a motor that's happy on 12v.
If you want bigger motors for direct drive, just make sure they spin the props at about the right speed on your selected voltage.
Old Dec 06, 2009, 08:26 AM
"day ain't over yet-"
der kapitan's Avatar
Western N.Y. winemaking country
Joined Jun 2005
If you need info on this particular ship, why not talk to Loren Perry at Gold Medal Models? He built a 1/96 Long Beach some 25+ years ago---.
der kapitan is offline Find More Posts by der kapitan
Old Dec 06, 2009, 08:34 AM
tweety777's Avatar
Vlaardingen, The Netherlands
Joined Nov 2008
When cavitation is unavoideable you can use super-cavitating props.
They are trying to cavitate, but in such a way that the implosions which cause the problems are far behind the ship.
Then the hull remains in a safe distance from the danger.
I hope they are availeable in scale versions.
Greetings Josse
tweety777 is offline Find More Posts by tweety777
Old Dec 06, 2009, 09:09 AM
Adelaide,Australia
Joined Dec 2009
Thx patmat I know from the specs on the 900's they rev to approx 6500 (from memory) they also have about 60 Ncm of torque! so they should be spot on for direct drive, I might go for 60mm props we shall see when shes ready for that stage
Old Dec 06, 2009, 09:14 AM
Adelaide,Australia
Joined Dec 2009
I have stacks of good pics plus 3 issues of Model Boat mag from 2001 with photo walk round of her. now if I could work out where her port an stbd lights go i'd be stoked.
also can anyone tell me what the mast nav light set up would be for a warship of her size?
Old Dec 06, 2009, 10:18 AM
Leesburg, VA, USA
Joined Dec 2008
I'm building a 1/96 scale Long Beach in the 1980's configuration. http://www.wmunderway.8m.com/cgi/yab...num=1208703814 Are you doing the 1960's (TALOS, phased arrays) or 1980's version (Tomahawk, CIWS, HArpoon). I can't spot the nav lights in my pictures either. Here is my LB being escorted:
admiralbb62 is offline Find More Posts by admiralbb62
Old Dec 06, 2009, 06:07 PM
United States, MA, Lowell
Joined Dec 2008
The nav lights are just forward of the lower bridge wings.
Right above the Whale boat
Homeport is offline Find More Posts by Homeport
Discussion My 1/72 Revell build - Gato Class USS Cobia Steve2381 Submarines 78 Mar 25, 2010 11:41 AM
Build Log Sterling USS Missouri Build Steve Hanson Scale Boats 457 Jan 29, 2010 05:51 PM
Discussion USS Joseph Daniels Build Bikerider Scale Boats 18 Feb 09, 2008 08:44 PM
Discussion USS Monitor scratch build (photos) rangerdex Scale Boats 24 Sep 15, 2006 11:19 PM
