Old Oct 20, 2014, 06:52 PM
Manila, Philippines
Joined Jul 2001
Replacement lipo pack for Futaba 6ex
Found this lipo pack which HK advertised as a replacement for the nicad flat pack of the Futaba 6ex tx.
http://www.hobbyking.com/hobbyking/s...ipo_Pack_.html
My worry is that this is a 3s pack (11.1v) as compared to the original nicad pack of 9.6v. I don't want to damage any component of the tx if I do decide to use this. Anybody care to comment.
Thanks.
Gerry Santos is offline Find More Posts by Gerry Santos
Old Yesterday, 01:21 PM
Florida
Joined Aug 2004
Your fully charge nicad pack would be around 11 volts and a fully charge LiPo will be 12.6 volts. Check with Futaba to see if it will safely use the 12.6 volt LiPo.
Rodney is offline Find More Posts by Rodney
Old Yesterday, 02:05 PM
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Two 1 Amp diodes in series with the positive lead of the battery will reduce the voltage to the radio to 11.2V , almost the exact voltage as the 8 cell Nixx battery.
I would only recommend this for one that is good at soldering and is familiar with determining the polarity of diodes.
Using the two diodes also makes the factory set low voltage warning in the radio a better match for the 3S Lipo.
Also, if one does install diodes in the battery leads, then you have no choice but to charge through the balance connector. I consider that a good thing.
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Yesterday, 06:17 PM
Manila, Philippines
Joined Jul 2001
was reading through the reviews/comments files and one flyer mentioned that the lipo pack is a perfect fit for the 6ex. however no mention of any modification
Old Yesterday, 07:38 PM
crazy8s's Avatar
Pennsylvania, USA
Joined Sep 2008
Gerry,
Why not just keep the battery at storage voltage? Assuming you have a decent computerized Lipo charger just use the 'storage ' setting. A transmitter barely puts any load on a battery when in use so the storage voltage will stay for a long time and it won't harm the voltage regulator on transmitters that were not designed for Lipo batteries.
crazy8s is offline Find More Posts by crazy8s
Old Yesterday, 08:44 PM
RC Warjet
United States, CA, Jamul
Joined Mar 2013
Originally Posted by crazy8s View Post
Gerry,
+1 . LiPo's in older JR and Futaba 9.6V transmitters need to be kept below 11.4V to be safe. In a 2200mah battery, that will give you at least 10 hours of op time before the need to recharge.
Warjet1950 is offline Find More Posts by Warjet1950
Discussion Futaba 6EX PCM SpookyNumber1 RC Tanks 6 Sep 30, 2014 09:18 PM
Discussion Replacing the 7.2v Nimh battery pack w/ 7.4v 10000Mah Lipo battery pack.... Can I Makintrax RC Tanks 8 Dec 27, 2013 04:05 AM
Discussion Lipo replacement battery for Futaba 6ex? jesse78 Electric Plane Talk 0 Mar 23, 2012 01:35 PM
Wanted Tx lipo pack for Futaba 6EX snolord1 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 06, 2011 12:34 AM
New Product Finally a 2650mAh Lipo pack to replace Flat NiMH pack in Futaba & Hitec supi7 Radios 45 Oct 03, 2007 04:02 PM
