Old Aug 18, 2014, 09:09 AM
335driver's Avatar
USA, TX, Round Rock
Joined Dec 2006
Question
KV of motor
Is there a way to figure the KV of a motor ? Here's all the info---battery is 3S 2200mAH
30C ESC 60A motor MegaMotor 16/15/1 KV unknown WattMeter shows 53A and 530 Watts at WOT...
Any clues ?? 3 minute flight used almost 70% of battery.
Dick
335driver is offline Find More Posts by 335driver
Old Aug 18, 2014, 09:40 AM
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
http://www.megamotor.cz/v4/script/de...ge_id=lang_eng
Scroll down to see chart
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Aug 18, 2014, 10:37 AM
Canada
Joined Nov 2000
Tricky to find read that site
So it's 8000kv ?? Doesn't seem as even remotely correct for your use, if it's accurate
Beyond that... that's a smallish battery.
Bare is offline Find More Posts by Bare
Old Aug 18, 2014, 12:03 PM
Joined Dec 2008
Could also be one of these???
http://www.rc-base.com/engine/mega-m...ga-motor-16151
http://megamotorusa.com/BrushlessNew/ACn16-15-1.htm
http://www.icare-rc.com/mega_acn1615.htm#ACn_16/15/1
http://www.icare-icarus.com/Mega-Mot...151_p_676.html
I have no idea what the difference between them is, but Kv does seem to vary.
Old Aug 18, 2014, 12:11 PM
turbonut's Avatar
upland CA
Joined Dec 2004
I think there was 2 version of the 16/15/1. One for EDF .I need to check the old charts. Is this a 50mm or 60mm fan to get the numbers you have..seems very low. But then its been a long time since I ran one in a fan.
turbonut is online now Find More Posts by turbonut
Old Aug 18, 2014, 12:14 PM
Chris Nicastro's Avatar
Post Falls, ID United States
Joined Feb 2004
I have used the 16/15/2 in a Vassa 65mm EDF and an Alfa 55mm EDF and its a beast of a motor in its day years ago.
16 refers to the rotor diameter, 15 refers to the magnet length, and 1,2,3 etc is the number winds. Thats why the motor is pretty short. The longer version has more torque and is even better for EDF.
The /1 motor does have an 8000KV rating.
The torque will be low and the amp draw will be high so keep that in mind.
Which fan are you using that motor in?
Your numbers are typical of what Im describing for a motor like that. I would get 5min flights on the same battery pack specs you have with the /2 motor.
Also seems to me your at the limits of that set up because just the peak values are off the charts of what is acceptable.
12.6V X 8000 = 100800rpm
Even if I assume 80% efficiency thats still over 80000rmp
You couldn't turn a 4.75X4.75 prop without maxing out temps and amps very easily.
Chris Nicastro is offline Find More Posts by Chris Nicastro
Old Aug 18, 2014, 03:52 PM
335driver's Avatar
USA, TX, Round Rock
Joined Dec 2006
Thanks to everyone who responded... the one thing I didn't mention was the fan I'm using is a 60mm WM300. It does go pretty good but I don't like the high amps and the fact that everything is getting hot. Not good to run the ESC that close to rated Amps, I don't believe. I got this motor with a Wemo 70mm fan awhile ago, don't remember why I changed out the fan, but I fried a 40A ESC with the motor/fan combo I'm using now. Then I got this motor, the guy said in the Wemo fan, it was just to fast for him.
Old Aug 18, 2014, 04:01 PM
turbonut's Avatar
upland CA
Joined Dec 2004
Yea that is way too much for the WM fans..they like amps
Old Aug 19, 2014, 12:01 AM
335driver's Avatar
USA, TX, Round Rock
Joined Dec 2006
Well, I was very surprised to see the KV of this motor. Had no idea it was that high. I don't think it's turning 80K it's not that fast. And Velocity RC sells a 4600KV motor w/WM300 as a combo. I have another 300 with a 3000KV Het motor and it drew about 30 A and 320 watts w 75A ESC. I'm wondering if it might be better to swap out the motor/fan and see how it flies that way.
Old Aug 22, 2014, 03:25 PM
335driver's Avatar
USA, TX, Round Rock
Joined Dec 2006
I replaced the MegaMotor and was surprised to see it's a /2 which is half the KV as the /1. Don't know why I thought it was a /1. Anyhow, the specs for the /2 call for a 40A ESC but yet I was pulling 50+ Amps and in the specs Icare said for aerobatic plane 75mm impeller. So why the difference?
With 3S (say 12v) x 4600 KV = 55K rpm. Could it be fan choice?
Old Aug 22, 2014, 03:53 PM
turbonut's Avatar
upland CA
Joined Dec 2004
You could ask Gary at eflux he has a lot of numbers for the WM fan. But I know they are amp hungry. I have only tested /flown the WM400
Old Aug 22, 2014, 04:05 PM
Joined Dec 2008
I think when Icare said that, they may have been refering to prop size, not a 75mm rotor.
" Recommended propeller for aerobatic airplane ---impeller 75 mm " which is 2.952"
http://www.icare-rc.com/mega_acn1615.htm#ACn_16/15/2
Old Aug 23, 2014, 12:03 AM
335driver's Avatar
USA, TX, Round Rock
Joined Dec 2006
Cooler,,,,that's really what I thought but who knows "the shadow knows" (gotta be old to get that,right)
turbo, you must be right but why ? I just put my Wattmeter on a CS70mm 4 blade w /2W-20 on a 4S 2650 and it didn't go anywhere near the MegaMotor. Can it be the pitch of the rotor blades?
Also, what do you mean when you say they are amp hungry. Excuse my ignorance because I usually just use what the Mfg. recommends. I think the best running set-up I got is the E-Flite V15 w/3600 KV motor.
Old Aug 23, 2014, 12:35 AM
Joined Dec 2008
I was born -- Oct 1952- does that qualify??..
Old Aug 23, 2014, 12:00 PM
turbonut's Avatar
upland CA
Joined Dec 2004
By Amp hungry they pull more amps than other fans on the same KV motor. They have more pitch and very large/ wide cord blades. They have very good performance but are noisy.
Sold 3x new T-Motor 3506 650 kv motors flohio117 Aircraft - Electric - Multirotor (FS/W) 2 Nov 11, 2013 03:49 PM
Sold T-MOTOR 2212-1300 kv Brushless motor innov8tiveTech Aircraft - Electric - Power Systems (FS/W) 0 Nov 06, 2013 01:11 PM
Discussion High KV motor or Low KV motor? learninginverted Mini Helis 104 May 15, 2008 03:45 PM
Discussion 2 cells + high kv motor vs 3 cells + lower kv motor? onewoo Power Systems 9 Jun 16, 2007 06:03 AM
