Old Apr 08, 2009, 12:53 AM
vleisie is offline
Find More Posts by vleisie
boerie roll
vleisie's Avatar
Johannesburg, South Africa
Joined Apr 2007
Build Log
Quickbuild style Mirage F1
Here is my quickbuild style Mirage F1. (Thanks for the inspiration Tomhe).
It was designed in Google Sketchup for 6mm depron and the standard 6” prop power set-ups. I used only elevons, which seem to work fine, simplifies construction and keeps the weight down.
The rounded intake shape is very simply made from thin plastic sheet.
Details:
Span: 25”
Length: 42”
Flying weight: 14oz (light build, 2208 motor, 1250mah 3s battery)
Prop slot fits 6” props.
Control throws (measured as shown in picture):
Elevator: 40mm up/40mm down. 30% Expo
Aileron: 60mm up/60mm down. No expo.
The first flights went very well. The plane is stable and tracks straight. Rolls are very straight also. The roll rate with only elevons seems adequate for my “scale” flying style. As with the full size plane, all-out manoeuvrability is not the model’s strong point.
I have not checked the stall behaviour yet, but it slows down well for easy landings.
vleisie is offline Find More Posts by vleisie
Old Apr 08, 2009, 05:29 AM
Frojd is offline
Find More Posts by Frojd
Frojd's Avatar
Sweden, Västra Götaland, Goteborg
Joined Aug 2005
Nice plane, great work!
Frojd is offline Find More Posts by Frojd
Old Apr 08, 2009, 07:40 AM
vleisie is offline
boerie roll
vleisie's Avatar
Joined Apr 2007
Thanks Frojd!
Old Apr 08, 2009, 08:52 AM
Turbobeaver is offline
Find More Posts by Turbobeaver
Ottawa,Canada
Joined Dec 2003
Very nicely done indeed Vleisie.Love the added touch of including the canopy decal with your plan as well.thanks for sharing your endeavours with the rest of us.Are there any plans in the works to shoot some inflight video?Nice job all around .
Turbobeaver is offline Find More Posts by Turbobeaver
Old Apr 08, 2009, 10:35 PM
zhnme523 is offline
Find More Posts by zhnme523
Malaysian Flier
Selangor, Malaysia
Nice... sure built it...
zhnme523 is offline Find More Posts by zhnme523
Old Apr 09, 2009, 08:25 AM
vleisie is offline
boerie roll
vleisie's Avatar
Joined Apr 2007
Thanks again for the kind comments.
Old Apr 09, 2009, 09:16 PM
Esprit440 is offline
Find More Posts by Esprit440
Supersonic hover
Esprit440's Avatar
Michigan, United States
Joined Sep 2003
Really nice! I printed the plans today, now I just need some building time.
Thanks for making them!
-Matt
Esprit440 is offline Find More Posts by Esprit440
Old Apr 10, 2009, 12:24 AM
vleisie is offline
boerie roll
vleisie's Avatar
Joined Apr 2007
On the building side:
* As always, a light plane will fly better, particularly when it has small wings like the F1.
* The wings will need some stiffening with spars of your choice, but take care to ensure that all the tabs still line up. Make sure that the wing root joint is strong, as the wing is not continuous due to the anhedral.
* Size the motor cut-outs for your choice of motor and motor mount.
* Take a bit of time before assembly to figure out how you will mount the electronics. Cut slots for wires and velcro straps before assembly, access is limited afterwards.
Good luck
Old Apr 10, 2009, 01:29 AM
zhnme523 is offline
Malaysian Flier
Selangor, Malaysia
Starting to build it but not sure the CG point.. Try and error I guess..
Old Apr 10, 2009, 06:36 AM
vleisie is offline
boerie roll
vleisie's Avatar
Joined Apr 2007
I've added the CG position and control throws I am using to the first post.
Old Apr 11, 2009, 12:12 AM
zhnme523 is offline
Malaysian Flier
Selangor, Malaysia
Thanks... Upload later on.. already cut but haven't glued it yet..
Old Feb 01, 2011, 05:30 AM
DrMobile is offline
Find More Posts by DrMobile
Joined Oct 2010
Its seem most easy plane to build.
I am starting building this plane.
anyone here plz review this plane and
which paint have u used on depron
br.
DrMobile is offline Find More Posts by DrMobile
Old Feb 08, 2011, 01:30 AM
subhan.nasir is offline
Find More Posts by subhan.nasir
Nasir Khan
Australia, NSW, Fairfield
Joined Feb 2009
very nice....thumbs up
subhan.nasir is offline Find More Posts by subhan.nasir
Old Feb 10, 2011, 01:39 AM
Nasir Khan
Joined Feb 2009
Details:
Span: 25”
Length: 42”
Good work, could you post 100% and 200% scale plans of the jet?
Old Apr 25, 2014, 02:02 PM
JoeSlow is offline
Find More Posts by JoeSlow
Joined Oct 2013
Here is my finished plane, before instaling the electronics.
JoeSlow is offline Find More Posts by JoeSlow
Build Log Littlescreamer Mirage F1 Cr/ct Buildthread GGRN Pusher Prop Jet Models 229 Dec 28, 2014 09:39 AM
Any Mirage F1 3 views available? thulizulu Electric Ducted Fan Jet Talk 5 Apr 30, 2014 03:50 PM
Video Littlescreamer Pj Mirage F1 Cr/ct GGRN Electric Plane Talk 7 May 11, 2008 08:51 AM
Yippee! EDF55 Mirage f1 Bryce From Nice Electric Ducted Fan Jet Talk 10 Jul 05, 2006 10:29 AM
Help! Mirage IIIC and/or Mirage F1 paper model kits? armourgod Pusher Prop Jet Models 2 Jun 06, 2006 02:17 AM
