Old Nov 29, 2015, 11:20 PM
Holey42001 is offline
Find More Posts by Holey42001
Discombobulated Me
Holey42001's Avatar
Joined Jul 2015
Best setup for 210 ish frame?
Hi all I recently acquired a machine that cuts wood rather nicely and cut a birch plywood frame roughly 210mm motor to motor. Max prop size is 4 inches. This quad I am not going for efficiency but for performance. Any idea on the best setup while remaining in a friendly price range? Any help is greatly appreciated!
Holey42001 is offline Find More Posts by Holey42001
Old Nov 30, 2015, 05:55 AM
Zillawill is online now
Find More Posts by Zillawill
United Kingdom
Joined May 2014
RCX2205 and littlebees would be good
Zillawill is online now Find More Posts by Zillawill
Old Nov 30, 2015, 08:37 AM
Discombobulated Me
Holey42001's Avatar
Joined Jul 2015
I heard the 2205 were not the best for durability, but I'll check them out. Also if the are 2350kv wouldn't that be a touch slow for 4x4.5 props? Thanks for the response!
Old Nov 30, 2015, 12:10 PM
Discombobulated Me
Holey42001's Avatar
Joined Jul 2015
Those 2205's do sound good...but I will need to modify the frame a bit. But that's ok I'll do some more research. Thanks for the tip!
Discussion Travel size frame (350-ish) that can carry a GoPro/gimbal? wsalopek Multirotor Talk 0 Jul 26, 2015 03:25 PM
Discussion Which 250 Quad frame for 50$ range..ish cswann821 Mini Multirotors 8 Jun 17, 2015 04:44 PM
Wanted Looking for a cheap(ish) Tri frame 3d astronaut Aircraft - Electric - Multirotor (FS/W) 2 Jun 24, 2013 11:39 PM
Discussion best controller for a newbie-ish pilot. Mr Bloppy Radios 6 Apr 25, 2010 05:00 PM
Help! Low Amp, High(ish) Speed setup for Terry LuckyDay Power Systems 7 Dec 19, 2006 08:38 PM
