Old Yesterday, 01:12 PM
pwilk20 is online now
Find More Posts by pwilk20
United States, NY, Queens County
Joined Nov 2011
Hi guys, little problem.
I upgraded my yak 130 to 8s. Something seems not right.
Stock freewing powerplant in plane numbers on 6s
2.2kg thrust
102 amps
2315 watts
Now my upgraded 8s powerplant. HET 650 65 1500kv, jetfan 90 ECO rotor in stock aluminum freewing housing. Again, in plane numbers
2.4 kg
88 amp peak, 82 settled
2750 watts
Do these thrust numbers look right? Only gained 200 g or so of thrust, amps are down that's good. Is there a difference between jetfan 90 ECO rotor and non ECO? And, could it be because it's in the stock aluminum housing that it doesn't produce the much higher thrust? Thanks.
Paul.
pwilk20 is online now Find More Posts by pwilk20
Old Yesterday, 01:36 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
2.2kg thrust
102 amps
2315 watts
2.4 kg
2750 watts
Paul.
Hi Paul,
I have no experience with the Freewing housing, but it's probably too big for the ECO rotor, Those rotors are turned down to fit the HET 9503 housing, which are smaller than the standard, Jetfan carbon housing.
You are probably losing thrust due to excessive tip clearance.
If you still want to use that rotor, get a HET 9305 V-2 housing that will accept the 39mm motor you have.
The motor should be run ar 0-6* timing (6* is ok for the 700-68-1500 on 8s,)
PWM: 12
You should be seeing about 100-105A installed in the jet.
My Freewing F-16 flies with very good power with the standard JF90/700-68-1500 on 8s ( 2x 4s, 60c, 5000's)
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Old Yesterday, 02:03 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
deleted --gary covered it all. -- hope that was spelled right-- just broke my glasses! Can't see squat.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Yesterday, 02:19 PM
efflux RC's Avatar
Joined Aug 2009
Paul,
MY error, sorry I misread your motor spec. (as most use the 700 series motors with the Jetfan rotors). you may be using the 650 since it fits your housing?
The only difference in my comments above is that you can use the Standard HET 9503 housing (for 36mm motors) or the V-2.
Mark the ECO rotors are machined down to fit the smaller I.D. of the HET housings.
They are not the same dia rotors as the standard Jetfan rotor.
I stopped offering the ECO rotors a year ago. E-jets no longer offers the JF90 "ECO" rotor as well.
Try not to confuse the The 90mm with the JF120 "ECO" that uses the same moniker to express the currunt JF120 as an economy version, since it utilizes a glass filled polymer for the housing, as opposed to a more expensive carbon fiber housing.
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Yesterday, 02:20 PM
efflux RC's Avatar
Joined Aug 2009
Ha ha!.....
I was typing while your were deleting.
No worries Mark.
Site Sponsor
Old Yesterday, 02:22 PM
Joined Dec 2008
Gary I didn't know that --both my JF 90's have stock CF shrouds..
Old Yesterday, 02:52 PM
heliclown is offline
Find More Posts by heliclown
Australia, NSW, Hillsborough
Joined Feb 2008
Hi Gary ( efflux)
Hi Gary , what timing and PWM would you recommend for this setup-
Jetfan 90mm HET 700-68-1500 -9S 60c 5000s in a glassed fly fly Mirage?
Thx ,Steve
heliclown is offline Find More Posts by heliclown
Old Yesterday, 03:10 PM
efflux RC's Avatar
Joined Aug 2009
Thx ,Steve
Hi Steve,
Since you'll be seeing higher amps on 9s, I'd suggest 0 (zero) motor timing.
PWM: 12
Site Sponsor
Old Yesterday, 03:42 PM
Joined Nov 2011
Thanks guys! This explains it, I bough the eco rotor awhile back. I did notice a bigger gap than usual, so I'll be buying the regular rotor now.
Paul.
Old Yesterday, 04:06 PM
Joined Dec 2008
Aside from the rotor gap,, why didn't you go with the 700-68-1500?
I just tested the Kv's on mine the other day-- I was happily surprised
it came out at around 1550Kv . Mine is going into a Flyfly F-86 -- should have some great performance on 8s-- And the plan is for full ducting too!
Old Yesterday, 10:02 PM
Joined Nov 2011
Well I saw Jepe Jets guy getting some awesome thrust numbers with the 650 68 1500 so I followed him. That's the only reason really
Paul.
Old Yesterday, 10:14 PM
efflux RC's Avatar
Joined Aug 2009
Thanks Paul.
FYI, Jepe Storm is a Jetfan "ECO" rotor in a HET 9305 housing.
Site Sponsor
Old Today, 11:35 AM
Joined Nov 2011
Looking forward to the rotor Gary
I took out the shrud getting it ready for the new rotor, I measured approximately 1.5mm gap between the blade and the shrud with the ECO rotor. Just looking at it does seem excessive.
Paul.
Sold ESM 80" T-28 Trojan Electric w/ Sound + Smoke realdeal Aircraft - Electric - Airplanes (FS/W) 10 Oct 06, 2011 02:15 AM
Sold brand new never used power 90 e flite brushless motor Jakedizzle Aircraft - Electric - Power Systems (FS/W) 0 Sep 12, 2011 11:07 AM
Discussion My prop is hitting the sound barrier... OR... tom66 Power Systems 11 Aug 13, 2011 01:54 PM
Discussion Wemotec Midi vs Stumax 90 - Sound Comparison dro56595@bigpo Electric Ducted Fan Jet Talk 36 Jan 09, 2011 09:12 AM
