Old Feb 11, 2016, 07:47 PM
Mad_Mike is online now
Find More Posts by Mad_Mike
Flight risk
Mad_Mike's Avatar
Canada, ON, Mallorytown
Joined Feb 2015
My AUW is 1305g.
That includes a battery(3/2200) weight of 188g so in comparison I'm at 1116g without the battery. Almost identical to yours.
I don't notice any difference in battery performance due to ambient temperature with this size battery and I've flown in -31C. Mind you, the battery is warm to start with and enclosed in foam during flight.
Daedalus might be right, cool batteries don't perform well. I've had 25% flight time with small batteries in Winter air.
I'm using the 8x4.5 counter rotating props that came with it FYI.
Mad_Mike is online now Find More Posts by Mad_Mike
Old Feb 12, 2016, 03:47 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
HobbyKing CL-415 Canadair 1390mm wingspan Foam Kit
You wouldn't have any problem starting with a warm battery (15C and up) as it will stay warm from internal heating while flying.
There's a fair bit of data and anecdotal evidence around showing what happens to LiPo batteries as they get close to the freezing mark. Individual batteries vary quite a bit, but broadly speaking the internal resistance roughly doubles at freezing temperatures. The capacity drops a bit but the main impact is on the ability to deliver current. The effect can be quite drastic, as in the case of one pack that hit LVC after just a few seconds flying, and showed a voltage drop of 4v under load.
I can't match your -31C flying. My coldest is about -23C (10 below F). No problems with batteries, just fingers, despite a transmitter mitt.
Daedalus66 is offline Find More Posts by Daedalus66
Old Feb 12, 2016, 04:46 PM
pmdevlin is offline
Find More Posts by pmdevlin
pmdevlin's Avatar
Wirral, UK
Joined Jan 2007
I thought about the lipos, hence mentioning the temp, also, they have not been charged since end of December, they did all have (4 packs used) pretty much slightly over 4.1v per cell, and after 6 mins the worst was 3.7v per cell, best 3.8v per cell, however it was the full throttle that was the concern, that video is pretty much flat out, with no wind, its speed not flight time that is the concern, if faced with a headwind I fear a distinct lack of power. The change of props didn't do anything, so I am thinking about the motors again. D2830/11 210W 21A Turnigy is what I have, so I think although it will be a bench test, I'll do a test of amps and watts. Mikes weight shows I'm not that heavy, and a 2600 gens ace 3 cell isn't that much heavier than the commonly used 2200, plus its what I use in the Catalina so a direct comparison. Some on here are hauling camera equipment around so the airframe is capable of carrying weight.
pmdevlin is offline Find More Posts by pmdevlin
Old Feb 12, 2016, 07:51 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
So what was the temperature of the batteries? Had they been kept warm (as they should) or allowed to cool to something like ambient (5C)? If the latter, I would certainly expect them to be down on power.
Old Feb 13, 2016, 08:02 AM
Flight risk
Mad_Mike's Avatar
Joined Feb 2015
My measured power is 290W total.
Old Feb 13, 2016, 10:50 AM
lthibault is offline
Find More Posts by lthibault
Luc
lthibault's Avatar
Joined Dec 2004
Struts
Originally Posted by Mad_Mike View Post
IMO the struts are necessary on this model unless you go to heroic lengths with internal bracing between the upper and lower plywood decks. The wire ones are crap; I made some with dowel, oak stringers, and some other bracketry to tie things together.
First 2 pics show those.
I'm going to look for that Gorilla tape.
I flew the CL-415 today on 3" of snow with an ice pellet crust which tore up the hull pretty badly for 2 takeoffs / landings.
Third pic shows the damage.
I'll re-glass it and tape over, same with the tip floats. otherwise it'll be powder only.
Here's a video of the diff thrust in action on soft powder - works really well!
https://youtu.be/uKCLgUJT14k
Hi - never used struts on mine and made several successful flights. I used epoxy to permanently glue the wings together in a slightly warped position.
lthibault is offline Find More Posts by lthibault
Old Feb 13, 2016, 10:53 AM
Luc
lthibault's Avatar
Joined Dec 2004
WOW 5 years and over 1900 posts on this ARF can you believe it?
https://www.youtube.com/watch?v=uMvG...EJGl6h&index=6
Old Feb 13, 2016, 03:27 PM
keffe1 is online now
Find More Posts by keffe1
Deranged long range
Sweden, Uppsala County, Uppsala
Joined Aug 2013
Tomorrow will see me re-maiden my canadair.. This time with a Cyclops tornado on board. Will be interesting to see how that goes.
keffe1 is online now Find More Posts by keffe1
Old Feb 13, 2016, 05:07 PM
pmdevlin is offline
pmdevlin's Avatar
Wirral, UK
Joined Jan 2007
don't know really, all I can say is the outside temp was 6 degrees, and they where in a metal box, ok, in the car until being used, but probasbly not much warmer.
Here are some stats, if someone can make something of these!
Motors are 210w 21a 1000kv.
Fresh and warm 2600mah 3 cell,
8x3.8 2 blade props
motor 1= 8774rpm motor 2 =8986rpm (taken with hand held rpm sensor)
esc's are connected with "y" lead with one bec disconnected, so these readings are as it appears at the battery. I have no idea if this is an average, or just the motor with bec, or the actual maximum
18.9a 209w
8x6 3 blade props, fresh warm battery
motor 1=8360rpm motor 2= 8342 rpm
21.3a 226w
Looks like to me the motors are pretty much all the way there. I also did a fresh throttle range test just to be sure.
Old Feb 13, 2016, 11:43 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
You said earlier you were using 8x6 three blade props and had plenty of power. Now you have 8x3.8 two blade. That's a big reduction of load on the motors, especially considering that they are only 1000kv and turning at only 8800 rpm. Add in cold batteries and you reduce performance still further.
Also, the pitch speed with that setup is only 32 mph. That's the theoretical maximum speed. The first thing I would do is go to 8x6 props. Second would be keep the batteries reasonably warm (insulated container, pocket, etc.). I think you might find that these two things would solve your problem.
Old Feb 14, 2016, 10:43 AM
pmdevlin is offline
pmdevlin's Avatar
Wirral, UK
Joined Jan 2007
ha ha 8x6, we are somewhere else on rcg talking about same thing!
Well the 3 bladers didn't really have more power, look at static stats from last night, they spin slower, and draw more amps, but do they drive forward better due to pitch? that's the bit I cant get in my head
3 blade props seem to be pushing the motors to the top end of their limit, albeit on a bench test, will two blades be more or less on amps and watts, propos are certainly the easiest and cheapest way to go without a doubt
Old Feb 14, 2016, 11:57 AM
Deranged long range
Joined Aug 2013
Puh, plane survived Cyclops tornado re-maiden. Had a few close calls before I figured out stabiliser responses were inverted...
Old Feb 14, 2016, 01:13 PM
pmdevlin is offline
pmdevlin's Avatar
Wirral, UK
Joined Jan 2007
whats a cyclops, ?
Old Feb 14, 2016, 01:18 PM
pmdevlin is offline
pmdevlin's Avatar
Wirral, UK
Joined Jan 2007
just tested motors solo for amps and watts. all quite similar
taking one motor
3 blade 8x6 11.4a 125w
8x3.8 stock 10.6a 114w
apc 8x6 10.9a 119w
pity I only have 1 apc8x6!
Old Feb 14, 2016, 01:54 PM
Deranged long range
Joined Aug 2013
Originally Posted by pmdevlin View Post
whats a cyclops, ?
Cyclops tornado is a flight controller. There is also a slightly older type called the Cyclops storm.
For Sale MR Aerodesign Canadair CL-415 Kit Complete Rudderman98 Aircraft - Fuel - Airplanes (FS/W) 5 Sep 18, 2015 12:01 PM
Found Canadair CL 415 kit,ARF, ARC,or plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 2 Nov 13, 2008 05:41 PM
Wanted Looking for a Canadair CL-415 ARF or kit, maybe plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 1 Oct 17, 2008 04:54 PM
For Sale Canadair CL-415 Kit NIB EAMRC Aircraft - Electric - Airplanes (FS/W) 1 Oct 29, 2006 11:36 AM
FS: Canadair CL-415 Kit Rudderman98 Aircraft - Electric - Airplanes (FS/W) 3 Oct 11, 2004 09:54 PM
